Old 23rd Nov 2009, 9:31 pm   #1
Tractorfan
Tractorfan's Avatar
Default Strange plugs & sockets at Lewis's Liverpool
Hi All,
When I was a kid my mum occasionally took me to Lewis's department store in Liverpool. I used to marvel at the escalators and it was the first time I saw a security closed circuit television camera. However, what stuck in my mind was that they seemed to have a type of mains socket I've never seen before or since. There were two twin gang sockets at the foot of every stone effect column and some in the ceiling too. The socket itself was a round pin affair with the earth pin much nearer the centre line than the usual BS546 sockets and I think it was the same size as the current carrying pins. The sockets were a circular bakelite insert about 2.5 to 3 inches in diameter on a metal oblong plate. They weren't Wylex or D&S but something quite different. The last time I visited Lewis's a lot of them had been changed to standard 13amp sockets.
It's sad, I know, but when it came to plugs & sockets I was quite observant as a ten year old . Maybe a forum member was an electrician for Lewis's and has one in his or her bitbox
Cheers de Pete
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 24th Nov 2009, 1:58 am   #2
ben
ben's Avatar
Default Re: Strange plugs & sockets at Lewis's Liverpool
Now that brings back memories. used to always go to Lewis's, and Blackler's! long gone now, sadly.
Are you sure the plugs aren't just the smaller of the BS546,as shown here? even as late as the '90s, these were still used at our uni hall of residence!
Regards,
Ben.
ben is offline
Old 24th Nov 2009, 2:14 am   #3
paulsherwin
paulsherwin's Avatar
We *are* talking about Scousers here Pete
More seriously, there were lots of nonstandard mains sockets around at the time you're talking about. The 13A mains socket rapidly became standard in commercial premises after WW2, but many buildings had separate ring mains for things like floor polishers and vacuum cleaners. It was considered desirable to keep these appliances off the 'standard' supply - maybe it still is.
Paul
paulsherwin is online now
Old 24th Nov 2009, 2:52 am   #4
Darren-UK
I have misty recollections of things like this. As Paul says, I believe it was something to do with permitting certain applicances to be connected only to certain power points.
Darren.
Darren-UK is offline
Old 24th Nov 2009, 10:00 am   #5
Mike Phelan
Mike Phelan's Avatar
Ben - your link doesn't seem to work; Wikipedia cannot find it.
Mike.
Mike Phelan is offline
Old 24th Nov 2009, 10:46 am   #6
julie_m
I think the idea was to make sure that certain things -- tills, revolving display stands, the managing director's coffee maker -- would not be unplugged by cleaners in search of a power point, nor knocked offline if a malfunctioning Hoover or polisher blew a fuse in the distribution board.
Oh, and I've fixed the link to the BS546 plug pictures: Try this one.
julie_m is offline
Old 24th Nov 2009, 11:18 am   #7
ben
ben's Avatar
hmm, dunno what happened - here it is
Regards,
Ben.
ben is offline
Old 24th Nov 2009, 11:22 am   #8
Mr Moose
Hello,
MK still make BS546 plugs and sockets in 2A, 5A and 15A the 2A socket is here http://www.mkelectric.co.uk/en-GB/Pr...s/K770WHI.aspx
Yours, Richard
Mr Moose is offline
Old 24th Nov 2009, 12:31 pm   #9
mikelect
mikelect's Avatar
I know the 15amp version of these plugs are still used in India and South Africa maybe a hangover from colonial days.
Mike
I'm not a complete idiot, some parts are still missing
mikelect is offline
Old 24th Nov 2009, 12:41 pm   #10
yesnaby
yesnaby's Avatar
Hello,
Yes, I had a 15A one in South Africa, it seems to have gone missing now. I also had a 5A one (and wall socket) in the UK, will have a rummage, but I think that is lost as well.
Michael
yesnaby is offline
Old 24th Nov 2009, 1:16 pm   #11
cmjones01
BS546 plugs are still well-used for applications like switched lighting circuits. They have the advantages of being legal, distinctly different from normal 13A sockets so people don't plug other things into them, and *not* locally fused. This last one is important in applications like stage lighting where the plugs may be rather inaccessible, and every circuit is protected by a fuse at the dimmer anyway.
I've seen lots of modern 5A and 15A BS546 sockets in theatres, and 2A ones are common in window displays, sockets for standard lamps switched by the main light switch in hotel rooms, and the like.
Chris
cmjones01 is offline
Old 24th Nov 2009, 2:15 pm   #12
bobsterkent
bobsterkent's Avatar
a friend of mine moved into a 4 year old flat and this had 2amp sockets fitted for standard lamps around the house, meant we had to change the plugs on his lamps before we could plug them in
"Oh yes I love television, all those wiggly lines"!
bobsterkent is offline
Old 24th Nov 2009, 3:26 pm   #13
Darren-UK
Following on from Chris in #11, you often see 3A and 5A fittings used for lamps and other ambience - related items in places like restaurants and public houses. Instances seem to be becoming more common, almost like a revival of what many would see as vintage or outmoded technology. I suppose an added advantage is that it gets around the irritation of people putting 13A fuses into 13A plugs regardless of what the correct rating should be.
Darren.
Old 24th Nov 2009, 9:35 pm   #14
McMurdo
McMurdo's Avatar
We had Lewis's (Lewis Bros, later bought by Owen-Owen) here in Hanley as well (not to be confused with John Lewis) and I also remember non-standard 13A wall sockets, however our branch had the ones with Horizontal earth pin and vertical L&N which I think were made by Walsall.
Kevin
McMurdo is offline
Old 25th Nov 2009, 9:14 pm   #15
Tractorfan
Tractorfan's Avatar
Hi All and thanks for your interest & replies.
True, Paul,- Scousers, eh?
I've had loads of experience with BS546 plugs & sockets (I've even got a box of 'em the cellar including a 16amp South African one and a 15amp wooden adaptor!) and the one's in Lewis's were definately not those.
The one's I'm thinking of had the N & L holes on the centreline of the circular bakelite plate and the earth hole (possibly the same diameter or smaller) was just a bit higher.
Just to add to the confusion, my primary school had a smaller version for the 100volt line speaker system in each classroom to distinguish it from the BS546 mains socket alongside.
Cheers de Pete
Old 25th Nov 2009, 10:23 pm   #16
russell_w_b
russell_w_b's Avatar
Would this be what you remember?
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 28th Nov 2009, 12:01 am   #17
Michael Maurice
Michael Maurice's Avatar
Slightly OT When travelling on the London Underground, I used to see different type of 13 Amp plug IIRC the earth pin was horizontal, and the live neutral were vertical.
Has anyone else seen these before?
Michael Maurice is offline
Old 28th Nov 2009, 1:16 am   #18
Herald1360
Herald1360's Avatar
Like these, perchance?
https://www.vintage-radio.net/forum/...3&postcount=27
Chris
Herald1360 is offline
Old 28th Nov 2009, 9:56 am   #19
russell_w_b
Originally Posted by Michael Maurice View Post
'Has anyone else seen these before?'
Yes. They're Walsall gauge, and were used in the BBC extensively. We used them at transmitter sites for maintained bay and rack supplies - still do, in fact. Studios (someone will confirm, no doubt) used them for different applications.
We have a drawer-full of them at work. Our are non-fused. Just the sort of thing to put on your granny's kettle lead for an April Fool!
Regds,
Russell W. B.
G4YLI.
Old 28th Nov 2009, 10:23 am   #20
Jack Spark
Its quite common for shops etc to use unusual sockets.
I did a couple of days recently installing seasonal tills for a well known retailer, all had unusual variations on the 13A socket. I asked my colleague why and he said that it is to stop the staff unplugging the till/chip n pin or other bit of kit and using the socket to charge their phone.
J
Jack Spark is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
