Reply
Old 27th Jul 2021, 3:32 pm   #1
manofkent
Default Goblin 854 teasmade spits water from lid.
I am trying to resurrect my mothers old Teasmade. It is fully working EXCEPT when the kettle boils, quite a bit of water spits out of the hole in the lid before pressure builds up enough to force the water out of the spout.
Should there be a rubber safety bung or similar in this hole (about 3mm)?
manofkent is offline   Reply With Quote
Old 28th Jul 2021, 7:38 am   #2
Mike Phelan
Mike Phelan's Avatar
Default Re: Goblin 854 teasmade spits water from lid.
The hole is there to allow steam to escape until pressure builds up sufficiently to be transferred into the teapot, and therefore must not be blocked.
What model is your Teasmade and does it work OK?
Mike.
Mike Phelan is offline   Reply With Quote
Old 2nd Aug 2021, 9:42 am   #3
Herald1360
Herald1360's Avatar
Is the kettle being overfilled, perhaps?
Is there supposed to be an internal shield to stop steam bubble generated splashes from directly reaching the vent hole?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline   Reply With Quote
Old 2nd Aug 2021, 10:51 am   #4
Rubberfingers
Is the spout totally clear, without an excessive build up of limescale?
Rubberfingers is offline   Reply With Quote
Old 20th Aug 2021, 6:37 pm   #5
manofkent
Thanks for the suggestions. There was an internal baffle on the lid which had been rotated allowing two holes to coincide. Now it works fine after adjusting the spring (under the kettle) tension.
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
