Old 10th Jun 2021, 9:56 pm   #1
unitelex
Default Method for colouring and texturing epoxy resin
I found by experiment that I could tint normally clear epoxy resin very easily using laser toner powder (laser printer).
I needed to achieve a dark anthracite colour to fill in a chipped surface.
I am aware that black epoxy is available but did not have any nor did I want to purchase a tube especially for this very small job.
I used black toner powder, added while mixing the clear adhesive and hardener together. While setting I noticed that the result was going to end up too glossy compared to the base material so while it was still tacky I dusted the surface with more toner giving a matt look. The results were surprisingly good.
I have not tried with magenta, blue or yellow toner or any blending of these.
Best Regards
Chris
unitelex is offline
Old 11th Jun 2021, 12:08 pm   #2
emeritus
Default Re: Method for colouring and texturing epoxy resin
When I was a student, in the lab at STC where I did work experience, every bench had a small tool box which included a pack of Araldite and a small jar of Titanium Oxide powder that they used to mix with the Araldite where a white finish was required. I have coloured Araldite brown to fix some earthenware plant pots by grinding a piece of broken pot in my wife's kitchen pestle and mortar to a very fine powder.
emeritus is offline
Old 14th Jun 2021, 5:34 pm   #3
greenstar
greenstar's Avatar
I wonder how to achieve a brown bakelite colour and whether filing/grinding bakelite to mix with it would achieve that? I guess this has been done effectively.
greenstar is offline
Old 19th Jun 2021, 1:07 pm   #4
chriswood1900
I think you might need to be careful where you get the old Bakelite from, as some used asbestos fibres as the filler and if ground up they may present a health hazard.
Chris Wood
BVWS Member
chriswood1900 is offline
Old 28th Aug 2021, 9:59 pm   #5
vintage_8bit
Unhappy Re: Method for colouring and texturing epoxy resin
Today I was repairing a garden water feature clay pot. I used Araldite rapid. I coloured it with a couple of drops of Bolgers spirit based wood dye. It mixed easily and the mixture cured as normal. I was quite pleased with the result, more for thoughts on future use. Colin
vintage_8bit is offline
Old 28th Aug 2021, 10:47 pm   #6
Bazz4CQJ
Bazz4CQJ's Avatar
It might be the case that a solvent colourant additive could have a more uncertain effect on the adhesive strength than a finely powdered solid. I bet that somewhere in the Arts and Craft world there is just the right stuff.
B
Bazz4CQJ is offline
Old 29th Aug 2021, 2:01 am   #7
Refugee
Refugee's Avatar
Where I live you can dig up clay that is a good match for plant pot repairs once dries and mixed with epoxy.
Refugee is offline
Old 26th Sep 2021, 7:04 pm   #8
Ernest1
I found cheap watercolour paints crushed up work well and the range of colours are easier to get close.
Ernest1 is offline
Old 26th Sep 2021, 9:48 pm   #9
kellys_eye
I've seen methods of colouring PVC using wax dyes which would seem to suggest they would mix well with epoxy. Since these dyes are all available in a full pantone range (many suppliers will make a mix to your requirement) the options seem endless.
Getting hold of a CMYKW selection (cyan, magenta, yellow, black and white) should allow anyone to mix 'any colour' on spec.
You can also get 'glitter' in gold/silver - almost powder-like - to make a metallic finish.
kellys_eye is offline
