Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 28th Feb 2021, 11:01 pm   #1
Rileyman
Default Underlining or overlining a word - how?
Whenever I try to underline a word on this website all I get is a screenful of gobbledegook ! I'm using my wife's Laptop (it is allowed) and normally use Ctrl + u when typing elsewhere . Any ideas ?
Laurie.
Rileyman is offline
Old 28th Feb 2021, 11:04 pm   #2
AdrianH
AdrianH's Avatar
Default Re: Underlining a word - how?
If you go to advanced options you can underline words in that screen, highlight the word or words you want then just click on the U with the bar underneath.
Adrian
Asking questions and learning, or trying to!
Youtube EF91Valve
AdrianH is offline
Old 28th Feb 2021, 11:12 pm   #3
Radio Wrangler
Radio Wrangler's Avatar
without the advanced screen I'll just highlight the word underline and I'll click the underline symbol in the message box header. It's now bracketed that word with breakout commands to go into underline mode and then to come back from underline mode. It all looks like regular text with no underline going on. That change is done when you post.
Hang on, here goes...
Edit, yup, it worked! and now I've opened an edit on the message, that word has gone back to regular text with the underline/not underline commands bracketing it.
Italics and bold work in exactly the same way.
Radio Wrangler is online now
Old 1st Mar 2021, 12:18 am   #4
Terry_VK5TM
Terry_VK5TM's Avatar
A picture paints a thousand words
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 1st Mar 2021, 12:26 am   #5
Paul Stenning
Administrator
Paul Stenning's Avatar
If you want to type the underline tags rather than using the editor, put [U] before the word and [/U] after the word.
You can do the same for bold using [B] [/B] tags and italic using [I] [/I] tags.
And to type these codes without them doing their thing, as I did here, use [NOPARSE] [/NOPARSE] tags (which aren't on any buttons in the editor).
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 1st Mar 2021, 12:35 pm   #6
SiriusHardware
As a matter of interest is there a way to overline text as opposed to underlining it? I know the editor doesn't have that feature but can it be done with something along the lines of ...text...?
SiriusHardware is online now
Old 1st Mar 2021, 12:57 pm   #7
paulsherwin
paulsherwin's Avatar
Overlining isn't available as far as I know.
Members should be aware that the mods aren't very keen on pointless and unnecessary formatting, so should use such features sparingly.
paulsherwin is online now
Old 1st Mar 2021, 1:58 pm   #8
A case of...
STYLE
CONTENT
Old 1st Mar 2021, 5:17 pm   #9
SiriusHardware
Overline would come in useful when discussing microprocessor signals, as it is usually used to signify an active-low signal line or chip pin signal (for example 'CE' with overline would mean an active-low chip-enable signal).
Old 1st Mar 2021, 5:44 pm   #10
Paul Stenning
Administrator
Overlining isn't a HTML styling option that can be applied with HTML tags, which is why there are no BB tags for it (the system translates the BB tags in square brackets to HTML tags for display).
The best approach in that case would be to decide on an alternative way for your post such as -CE or /CE, or use a colour, and state at the start that this method implies active low. Or type it in something that does support overlining etc and save as a PDF to attach here. Not ideal but that's all we can do here.
Paul Stenning
Old 1st Mar 2021, 6:06 pm   #11
I find the non existence of a BAR (negative) option amusing, all of the computers to render HTML use logic with them.
Old 1st Mar 2021, 7:24 pm   #12
SiriusHardware
No problem, I just wondered if it was something which existed in the command set but had no specific button shortcut. As Paul says, there is a (sort of) convention to use _SIG or /SIG to indicate an active low signal line where overlining is not available, such as in plain text.
Old 1st Mar 2021, 9:24 pm   #13
I use /sig in plain, memory efficient unambiguous text too, no rendering required. I also spell out things like OHM and MICRO and MILLI if there is any possibility of confusion. So far I have yet to find a recent (last 40 years) high (or low) level programming language that uses anything but plain 127 (probably a lot fewer) ASCII text characters for input.
Old 1st Mar 2021, 10:35 pm   #14
Rileyman
Many thanks,everyone, for all the info. --- for the moment I'm OVERWHELMED , but tomorrow, I will get some practice in.
Regards,
Laurie. (a novice!).
Rileyman is offline
Old 2nd Mar 2021, 12:21 am   #15
Paul Stenning
Administrator
OK, for overline try [o]Overline[/o] which should give overlined text like this between the tags.
This is the letter O not the number zero.
Having discovered this https://html-shark.com/HTML/Overline.htm I have added 'o' as a custom BB code but not tested it thoroughly. In particular I have not tested it in conjunction with other tags/styling. If it works OK I will add a button for it in due course.
Paul Stenning
Old 2nd Mar 2021, 12:57 am   #16
SiriusHardware
Default Re: Underlining or overlining a word - how?
Thanks Paul, I really didn't expect you to go to those lengths but since you've been kind enough to do that, I will give it a try when the opportunity arises.
Old 2nd Mar 2021, 11:30 am   #17
Station X
Station X's Avatar
overlined bold text
OVERLINED BOLD COLOURED TEXT
OVERLINED BOLD COLOURED QUOTED TEXT
Graham. Forum Moderator
Station X is offline
Old 2nd Mar 2021, 12:15 pm   #18
Paul Stenning
Administrator
Overlined and underlined
There is now a button in the editor if you click "Go Advanced". It is on the far right, not with the other styling ones, because that's where the system puts custom ones.
Name:	Editor with overline.png
Paul Stenning
Old 2nd Mar 2021, 1:07 pm   #19
SiriusHardware
Much appreciated, thanks.
