#1 |
Hello forum.
I just received my new antique radio ![]() It is in good general conditions and never was opened or repaired before. The seller message me he only managed to tune into MW stations with a very simple AM arial loop. To be honest im afraid to plug it before check the capacitors so i haven't tried it yet. Yesterday i have found on line the schematic and i removed the speaker / chassis. A question now. In the schematic it is mentioned only the uf capacitors value. Not the voltage . How i will replaced them? Aby idea? |
#2 |
Just a reminder you must not publish information available on this site see rule B8
Cheers Mike T
Don't care if it was a bargain why's it in my kitchen ![]() Mike T BVWS member. www.cossor.co.uk |
#3 |
The service sheet available top right does give voltages around the valves,so that should give you a guide.Quickly downloadable.
Possibly depending where in the circuit put another 100 Volts or even a bit more to achieve the working voltage of the caps.
G8JET BVWS Member and V.M.A.R.S |
#4 |
Electrolytic capacitors generally have a voltage written on the case.
If you intend to fix this radio by replacing all the capacitors, rather than doing tests, then I suggest that you do not replace any capacitors having a value less than 0.001uF. These capacitors are generally in the RF part of the circuit and normally reliable. If you replace them you may upset the alignment of the set. Lots of useful information here:- https://www.vintage-radio.com/repair...ion/index.html
Graham. Forum Moderator Keep the soldering iron hot. |
#5 |
Very broadly, 630v DC for the axial wax ones on the underside of the chassis. You may sometimes come across one or two rated at 1000v, often with values of or around 0.01uf.
For the smoothing electrolytics, which do not always need to be replaced, 500v should be suitable for most sets. The voltage rating is always on the capacitor somewhere. For the wax capacitors it may be hidden under a layer of dirt which needs to be gently scraped off. Gabriel |
#6 |
Hi. I have also one of these radios in my collection. Bought it from an Oxfam charity shop years ago. Will have to have an attempt to restore it.
regards Mike |
#7 |
Thanks for the information guys. All very helpful.
I will upload more and clear pictures from the chassis internal view later. I will try to not change all the capacitors. I will make some tests before any chance. The electrolytic may be in good condition because the seller didn't mention any hum sound.. One cable from down inside it is detached. I'm not that good to understand where it goes ![]() I know my English are not very good also so I will add pictures to make all this more understandable. Have a nice day everyone |
#8 |
And the project is completed !
I have check and change 11 paper capacitors (was all leaky) and unfortunately it was necessary to change and the electrolytics but without to removed them.... The radio has unbelievable powerful sound with nice bass. It receive strong signal in all bands long, medium , short. I used it already several hours and it is extremely stable. I haven't meet any problem with the repair process. After capacitors replacement it worked immediately. The only 2 minors problems I have are... 1) The radio it has 6 station button presets . This 6 buttons are adjusted each through one screw . I have found stations through this but the signal is extremely week and the external antenna dose not change nothing. It gets much louder only when i touch the 6 button chassis. This happens only when i choose the presset buttons function. Otherwise the Radio works perfectly and extremely powerful. My second problem is in the first front left switch. This switch has 4 selections -high fidelity -Normal -Bass -Foreign When i chose the foreign nothing changes... I believe this happens because one wire of the switch it was detached and i can't configure where his position was ![]() I will upload pictures with the cable and with the Radio . Unfortunately i can't read the schematic ... Sorry for my English....i try my best ![]() |
#9 |
Here you can see the detached cable.
I haven't moved it . It is in the same position as i have found it. If someone can understand where it goes it will be very helpful. In the next day's i will upload a video so you can see the radio better. |
#10 |
It could be that the antenna isn't being connected to the push button unit properly or the RF section of the push button unit isn't being properly connected to the control grid of the mixer (V1) when the wave change switch is set to the Selector position, check that the switch contacts for S5 and S17 are making good contact and that L28 is ok.
For the wire that's disconnected.....where in the circuit does the connected end connect to ? All the above refs. are as per the Trader service sheet 399. Lawrence. |
#11 | |
![]() Quote:
To be honest i don't understand what you mean with the disconnected cable . The cable starts from the "fidelity, Normal,Bass,Foreign" switch . I believe it has to do with the "Foreign" position because is the only position where nothing changes when i choose it. |
#12 | |
![]() Quote:
In the Foreign position, 6 switch contacts are in circuit so it would be good if we know which contact the connected end of the wire is connected to. Lawrence. |
#13 |
The cable starts from here...
#14 |
#15 |
#16 |
For the other problem with the low signal in the 6 preset buttons i have check the Selector position, the switch contacts for S5 and S17 and the L28.
Plus i rechecked all the connections in new capacitors, resistors and cables. Can't find any problem. All seems to be in position. Maybe somehow it has to do with the disconnected cable .. I can't think something else. At least the rest works amazing ! |
#17 |
S37....According to the Trader sheet schematic the wiper of S37 should connect to the tap on the volume control (R15) and the contacts should be connected to R30 so far as I can make out.
On the switch diagram, the wiper connection for S37 is the one nearest the centre of that diagram. Lawrence. |
#18 | |
![]() Quote:
So i disconnected it again .... |
#19 |
Looking at the last photo posted it looks like the volume control (R15) might have been replaced with a standard pot (no tap) hence nowhere for the disconnected wire to connect to, I would have thought that if it was connected to the "ground" end of the pot (the one you've highlighted as a possible connection) then the Foreign setting would have an effect if the rest of the negative feedback components and connections are ok.
The disconnected wire shouldn't affect the reception when using the press buttons. Lawrence. Last edited by ms660; 26th Oct 2020 at 6:43 pm. Reason: Extra info. |
#20 |
So it is better to leave it disconnected ?
