Old 4th Jul 2020, 5:51 pm   #1
MooseUK
Unhappy Tuning Scale Glass Replacement
During a recent recapping I managed to put a three pin plug through the tuning scale glass of my 1955 Baird 301. Don't ask me how. I have looked about and not surprisingly have not been able to find a replacement. I thought I would try this forum, but I would also welcome any advice on how best to stick the glass back together to achieve the best results. I have all the large pieces, but there will be some small gaps.
MooseUK is offline
Old 5th Jul 2020, 9:11 am   #2
vinrads
Default Re: Tuning Scale Glass Replacement
I have used super glue, I think there is one especially for glass , lay the glass on a sheet of polythene on a flat surface assemble the parts dry first, when you have glued it and it has cured you can fill the gaps to above the surface of the glass , again when cured slice surplus off with a fine blade, of course a scan of one would be better ,you never know someone may oblige, good luck .Mick.
vinrads is offline
Old 5th Jul 2020, 6:38 pm   #3
MooseUK
Thanks for the advice. I have ordered some "Glass" superglue and will do as you suggest. I have also put the pieces together on my scanner bed and scanned them, but it is a long job to photoshop all the cracks out and recreate the damaged text - it would be much better to have a scan of an undamaged one as you say.
MooseUK is offline
Old 5th Jul 2020, 7:11 pm   #4
Michael Maurice
Michael Maurice's Avatar
I have had similar problems in the past. I have had the glass superglued together, then I got it professionally scanned, then sent that off to get a new dial made. Its not cheap but it will look like new.
Forum Moderator
Michael Maurice is offline
Old 15th Jul 2020, 10:13 am   #5
PaulR
PaulR's Avatar
Araldite also make a glass glue which I have used successfully
Paul
PaulR is offline
Old 18th Jul 2020, 10:16 pm   #6
Freya
Freya's Avatar
Second vote for the clear glass Araldite, it works great for filling gaps if used in conjunction with sellotape on the non printed side. Stick with tape first then support so gaps flop open and apply glue, keep on flat surface like pane of glass, not advisable to remove excess glue that squeezes out on painted side. A razor blade removes any excess from sellotape side.
Stephen
Freya is offline
