19th Mar 2020, 11:34 am | #1 |
Freezer spray
Sometimes you need freezer spray to help locate a thermally intermittent component. However it's pretty pricey, especially if you don't use it often. However - Poop Freeze to the rescue! It's available in B&M and similar discount shops for £1.99 or cheaper and, as far as I can tell, is the same and doesn't leave a residue.
It's meant to freeze your dog's poo, in case you're interested, though maybe that's too much information! |
19th Mar 2020, 1:53 pm | #2 |
Re: Freezer spray
Great tip and truly multi-functional for the dog owners amongst us. Thank you.
Alan |
19th Mar 2020, 2:41 pm | #3 |
Re: Freezer spray
Well, someone with a freezer spray canning business must have been really trying hard to find new market opportunities...
The mind boggles. Perhaps somewhere there will be "The museum of preserved dog muck" I imagine the entrance fee won't be too expensive. B&Q, screwfix, Toolstation etc. sell high capacity cans of freezer spray intended for freezing pipes so that sections can be isolated to allow a bit of quick plumbing work before things thaw. David Edit: Just seen Steve's reply. I go in for slightly larger pets, and use a shovel. More ecologically sound than aerosols...
19th Mar 2020, 3:28 pm | #4 |
Re: Freezer spray
Great tip thanks Glyn
19th Mar 2020, 3:50 pm | #5 |
Re: Freezer spray
19th Mar 2020, 4:06 pm | #6 |
Re: Freezer spray
The type for freezing pipes was recently being sold at a whopping £19.00 at my local plumbers merchants!
If smoking is so bad for you, how come it cures kippers? |
19th Mar 2020, 4:07 pm | #7 |
Re: Freezer spray
Cheers glyn
I'll get a can next shop, bonnie the boxer will approve!. Greg.
Picture, sound?, DOOR. |
19th Mar 2020, 4:32 pm | #8 |
Re: Freezer spray
Find a fisherman who's given up the sport!
I just happened to be at an ex-fisherman's house a few years ago and he had a few cans of bait freezer and insisted on giving me three cans that he no longer had need of - perfect, but you can't fit a nozzle extension to these cans. |
19th Mar 2020, 4:44 pm | #9 |
Re: Freezer spray
You might find the spray-heads of those cans interchangeable with ones that do take a straw.
19th Mar 2020, 7:47 pm | #10 |
Re: Freezer spray
Any idea what the gas is Google reveals it is CFC free, but no more. It has to be a liquid at room temperature and within the pressure limitations of a thin aluminium aerosol can.
B
19th Mar 2020, 9:57 pm | #11 |
Re: Freezer spray
Someone found it to be highly inflammable. I saw some footage of it acting like a flamethrower, I think it was on youtube.
19th Mar 2020, 10:10 pm | #12 |
Re: Freezer spray
Many non-food and non-medical aerosols use propane or butane as the propellant so flame throwing capabilities are no surprise.
Alan |
19th Mar 2020, 11:56 pm | #13 |
Re: Freezer spray
But the exit fee might. I'd better stop there.
20th Mar 2020, 9:10 am | #14 |
Re: Freezer spray
Easier to pick up if solid after your pet,that is why.I am sure it will work just as well on components too.
20th Mar 2020, 9:36 am | #15 |
Re: Freezer spray
Could the spray designed for electrical component chilling use a different formula? Maybe a formula that doesn't leave any conducting film behind, or is somehow less likely to attract moisture as it chills?
Not really an issue if you just need it to stiffen up dog turds! |
20th Mar 2020, 10:28 am | #16 |
Re: Freezer spray
I note that CPC are discontinuing the formulation we're used to, and going over to something more environmentally friendly, at a higher price. So when I last bought some a few weeks ago, paradoxically, it was cheaper to buy Ambersil's old formula, rather than cheap and cheerful ProPower, which was formulated using the new one.
Nick. |
20th Mar 2020, 10:38 am | #17 |
Re: Freezer spray
There really isn't anything complicated about these sprays and no magic ingredients are needed. Purified butane (cheap to produce) will work as well as anything and won't leave a residue. They all rely on the temperature change that takes place when a pressurised or liquefied gas is released from that pressure as described by 'the ideal gas law', sometimes called the 'general gas equation'. Messrs Boyle, Charles and Avogadro did the hard work. The effect is readily demonstrated by releasing air from a car tyre whereupon the resulting stream of air feels cold. Physics lesson over.
Alan |
20th Mar 2020, 2:50 pm | #18 |
Re: Freezer spray
Another use for butane is de-greasing and clearing out blind holes (dents to be pedantic) simply shove a lighter refill into it.
22nd Mar 2020, 9:19 am | #19 |
Re: Freezer spray
Just do like I do. Get a can of air duster and turn it upside down. instant freeze. About 3.00 USD here, VS about 7.00 for freeze.
Exact same stuff here. Difference is the length of the tube inside the can. Short tube for duster, but when can is inverted, comes out freeze. That info was given to me by a mfg. rep years back. |
22nd Mar 2020, 2:23 pm | #20 |
Re: Freezer spray
Was available at Poundland, probably still is.
https://www.vintage-radio.net/forum/...d.php?t=126222 |
