8th Apr 2016, 4:48 pm | #1 |
Ekco ARG134 radiogram.
I've a found a new home for my Ekco ARG134 radiogram. No electronic problems to sort out, all that was done in 1999. The cabinet was also at the same time French polished. It still looks good after almost seventeen years.
So the 'gram looks good but unfortunately the radio chassis is nothing special. U40 series valves are employed which means a series heater chain and the usual live chassis technique. Not nice. I'm going to do something about that, a 1 : 1 mains isolation transformer will be fitted. It is essential that this component if fitted because the radiogram is to be used as a display item. Not sure what to do about the Collaro three speed auto changer. Leave it in or replace it with something more modern. DFWB. Last edited by FERNSEH; 8th Apr 2016 at 4:54 pm. |
8th Apr 2016, 4:57 pm | #2 |
Re: Ekco ARG134 radiogram.
I would leave the Collaro in place, but earth the deck for safety.
A newer deck never looks 'right', far better to keep it original. Mark |
8th Apr 2016, 5:03 pm | #3 |
Ouch - oh no, do leave that Collaro autochanger in. A newer one will spoil such an authentic unit. Does it work? You can get replacement catridges easily. EKCO really did us a lot of "U" series chassis and most unusually in big Radiograms like this. This was made before the Pye takeover and C. O. Stanleys merry men were to be found wandering around in White Coats! Edward
8th Apr 2016, 5:21 pm | #4 |
Are you sure it's live chassis? Ekco went through a period of using a string of U series valves attached to a transformer winding - not an autotransformer, a fully isolated transformer.
8th Apr 2016, 5:33 pm | #5 |
Paul is right, the chassis is isolated from the mains in this model.
8th Apr 2016, 5:36 pm | #6 |
Presenting A New Triple-Speed Auto-Radiogram...
The 78s are ready to go, can't wait Mr Fernseh! |
8th Apr 2016, 5:53 pm | #7 |
Hi Paul,
your right there is a mains transformer but I'm not sure if is a double wound one for complete isolation. Definitely U40 series valves though. Yes, I will use the original record deck. That's decided. There only question. Will the original pickup be OK on modern LP records and is it possible to fit an alternative PU cartridge? DFWB. |
8th Apr 2016, 6:58 pm | #8 |
See snip below.
8th Apr 2016, 7:04 pm | #9 |
From that diagram, the transformer certainly appears to be a double wound one, but myb advice, FWIW, is to check that it actually is what it appears tobe!
8th Apr 2016, 7:07 pm | #10 |
Certainly does no harm to check.
8th Apr 2016, 7:07 pm | #11 |
That advert shows a Garrard deck so the deck may have been changed or was an alternative at the time.
Which model of Collaro and which cartridge is fitted? |
8th Apr 2016, 7:53 pm | #12 |
I'll check out the type of Collaro deck tomorrow. The radiogram is stored upstairs above the shop and to gain access you have go to the front of the shop and into the street, not wise on a Friday evening.
The Ekco A160 table radio employs U40 series valves and has a double wound mains transformer. Nevertheless, it would be wise to check that these is no direct connection to the mains. DFWB. |
8th Apr 2016, 8:04 pm | #13 |
8th Apr 2016, 9:00 pm | #14 |
Trader Sheet 947 is the one you want. It's on both Paul's and the BVWS discs AFAIK.
David, the veneer on the front of the machine is stunning, even nicer than on the pic in the ad in post 6. Nick. |
8th Apr 2016, 9:22 pm | #15 |
Hi Nick,
that's what this radiogram is all about, it's appearance and those beautifully book matched veneers on the front panels. I had to decide which radiogram to keep in my collection, the RGD 1046G or this one. The Ekco looks better than the slightly staid looking but worthy RGD. The RGD wins because of it's excellent amplifier and the better radio receiver. Despite the simple radio receiver and single output valve the Ekco gives a good sound from it's 10" loudspeaker. DFWB. |
8th Apr 2016, 9:40 pm | #16 |
Yes, agreed.
This is basically the well-known A104 in disguise. N. |
8th Apr 2016, 11:39 pm | #17 |
This may have the Collaro RC131 3 spped autochanger. The ideal cartridge for this is a stereo-compatible BSR X5M which will play both Mono and Stereo records safely. Edward
9th Apr 2016, 12:33 am | #18 | |
9th Apr 2016, 9:42 am | #19 |
9th Apr 2016, 9:59 am | #20 |
There was also a shortage of wood at the time, so this would have added to the price.
I seem to remember that purchase tax ran as high as 40% in the post war period! Given the rather basic electronics, it is amazing how good the sound quality is in comparison with the table radio that shared the same chassis. A big speaker in a large cabinet makes a huge difference. Mark |
