22nd Dec 2013, 4:45 am | #1 |
Circuit Improvement (Tone Correction).
In many valve radios there is a tone correction capacitor connected from the plate of the output pentode to chassis earth.
This is a highly stressed component. It not only has to withstand the plate voltage but added to that are the positive excursions of the audio output which can add one or two hundred volts at several watts of audio. If this high voltage should cause the capacitor to fail, the output transformer could burn out and the rectifier become damaged. This dire situation can be entirely avoided by rewiring the tone correcting cap directly across the output transformer primary where it will continue to act as a tone corrector. John. |
22nd Dec 2013, 9:54 am | #2 |
Re: Circuit Imrovement
True but I think it may go to earth for purposes of stability, to prevent parasitic oscillations in the output stage.
Peter |
22nd Dec 2013, 11:47 am | #3 |
Re: Circuit Improvement (Tone Correction).
Hmm. Any output stage which requires a whacking great capacitor from anode to deck for stability purposes is a pretty poor design. As to tone "correction", a misnomer for excessive top cut, this could be achieved by placing a cap from the control grid to ground, although that would not disguise any effects of el-cheapo output transformers or over-stretched output stages!
22nd Dec 2013, 6:26 pm | #4 |
The tone correction capacitor as wired in the conventional position after the output valve provides some correction for the inductive load of the loudspeaker. It should (and sometimes did) also incorporate a series resistor when it becomes a Zobel network.
From a signal point of view, it's immaterial whether the capacitor is across the transformer primary or the valve - but I would always wire the capacitor across the transformer primary. This protects the transformer in the event of capacitor failure and gives a lower quiescent DC voltage across the capacitor. The peak voltage across the capacitor can be +/- 2 x HT voltage - so a suitably rated high voltage replacement should be fitted. Leon. |
22nd Dec 2013, 6:39 pm | #5 | |
One of my standard tests of a rebuilt medium-wave radio is to disconnect the aerial, short the AGC line to earth (so the IF chain is running at full gain) and turn the volume up to max then tune around 2x the IF - 900KHz - 1MHz - If you get any hint of instability - whistles, screeches, swishes, changes in the pitch of the background 'mush' or motor-boating - you have decoupling issues which need to be fixed! The anode-to-earth capacitor on the O/P stage is one device to control this feedback - often the problem can be further tamed by wiring a low-value resistor (10-50K) in series with the audio feed to the O/P valve's control-grid, with maybe a low-value (50pF)capacitor between said grid and cathode. |
