View Poll Results: Which type is your TV22?
TV12 12 22.22%
TV22 Mk I 32 59.26%
TV22 Mk II 24 44.44%
TV22 A 10 18.52%
Multiple Choice Poll. Voters: 54. You may not vote on this poll
Old 28th Jul 2022, 7:09 am   #81
Duke_Nukem
Duke_Nukem's Avatar
Default Re: Survey of TV22 ownership
I've previouls mentioned my TV22's looks like I need to add the following:
1) TV32 - Restored/working last time I tried a few years ago
2) TV62 x 2, one basically working, the other needs restoring.
@Panrock Do you want serial numbers ? If so I will try and get to the sets (incl 12/22's) and advise.
TTFN,
Jon
Duke_Nukem is offline
Old 28th Jul 2022, 8:51 am   #82
Panrock
Panrock's Avatar
Yes Jon, serial numbers are always welcome. Thx Steve
https://www.radiocraft.co.uk
Panrock is online now
Old 14th Aug 2022, 7:26 pm   #83
Roland Huisman
I have two TV22F sets. But the TV22F is not what you asked for in the initial post...
If you are interested I can look up the serial numbers for you.
Regards, Roland
Roland Huisman is offline
Old 14th Aug 2022, 7:44 pm   #84
Panrock
Panrock's Avatar
Yes please! What line standard is the TV22F?
Thanks, Steve
Old 14th Aug 2022, 7:50 pm   #85
Roland Huisman
Hi Steve,
The TV22F is ccir 625 lines fm sound with eq80. I will look up my serial numbers and I know of another few in existence. I might have also numbers of these as well. In one of my sets was also the original schematic. Quite happy with that because these things seem to be quite rare... Up to now it is the only part of documentation I ever found.
Edit: is there any information in the serial number about production locations for example?
One of the numbers is 103/00145 that set is also in a topic here...
https://vintage-radio.net/forum/showthread.php?t=64715
Regards, Roland
Old 14th Aug 2022, 8:23 pm   #86
Panrock
Panrock's Avatar
Thanks Roland. Is that an FM tone correction time constant of 80 µs - or it used EF80 valves? It would be most interesting to see the schematic. Thanks, Steve
Old 14th Aug 2022, 8:26 pm   #87
ronbryan
The EQ80 is an FM detector.
http://www.r-type.org/exhib/aaa0951.htm
Ron
ronbryan is online now
Old 14th Aug 2022, 8:34 pm   #88
Panrock
Panrock's Avatar
Thanks for putting me right there Ron. It would be interesting to know the TC none the less. I believe UK FM radio used 75 µs and UHF TV 50 µs. Steve
Old 14th Aug 2022, 8:47 pm   #89
Roland Huisman
Hi Steve,
I've uploaded the TV22F schematic to https://elektrotanya.com/ some years ago but I've attached it here to this post now.
Regards, Roland
Old 14th Aug 2022, 9:41 pm   #90
Roland Huisman
The two Bush TV22F which I have:
103/00145 (mentioned in #85 and also described on this forum)
103/00017
103/00036 (known to be in the Netherlands, but is modified. I have thought on buying the set back then but the PL33 was replaced by a PL82 or a 84 and the PZ30 was replaced by a PY83. AQlso the ferrite core war removed from the tuning coils, there were trim capacitors placed instead over the coils.
103/? Another Dutch collector has a TV22F set, but I don't know the number.
So at least four of these sets are in the Netherlands. Serial numbers are quite low...
Regards, Roland
Old 14th Aug 2022, 9:50 pm   #91
Panrock
Panrock's Avatar
These will be included in the next edition of the table. Again, thank you. S
Old 15th Aug 2022, 11:34 am   #92
German Dalek
German Dalek's Avatar
I have 3 BUSH TV 22.
One with the Pico-valves, one with the Noval-valves and the rare
F-version for CCIR!
Sorry, but I will take some time to send you the chassis-numbers!
Regards,
German Dalek
And now something completly different:
MARC BOLAN, he was/is the real king of Pop Music!
German Dalek is offline
Old 15th Aug 2022, 11:41 am   #93
German Dalek
103/00017
Regards, Roland
Hi Roland,
This is very intersting, my tuning ferrite cores are broken, received them inside a
little bag, when I picked it up from Amsterdam.
Because I see some trouble to glue them (all parts are there), I should decide
for tuning caps, too.
I really like to get some informations, to copy the change.
Regards,
German Dalek
Old 17th Aug 2022, 10:58 am   #94
Roland Huisman
Originally Posted by German Dalek View Post
This is very intersting, my tuning ferrite cores are broken, received them inside a little bag, when I picked it up from Amsterdam. Because I see some trouble to glue them (all parts are there), I should decide for tuning caps, too. I really like to get some informations, to copy the change.
The only information I have are the attached pictures from the set. I hope it helps. These are called Philips toltrimmer in Dutch.
Regards, Roland
ID:	262960   Click image for larger version
ID:	262961   Click image for larger version
ID:	262962   Click image for larger version
ID:	262963   Click image for larger version
Old 17th Aug 2022, 11:35 am   #95
German Dalek
Many thanks Roland to share these pictures!
These tuning caps are wellknown in Germany and you will find them
mostly in radios.
The original construction is very flimsy, these cores are easy to crack when
tuning the set.
Regards,
German Dalek
Old 22nd Aug 2022, 9:03 pm   #96
Panrock
Panrock's Avatar
Here is the latest update. Thanks to all contributors so far.
TV12A ...4
TV12AM ...2
TV12B ...6
TVF12A ...1
Total all TV12: ...13 {poll = 10}
Total TV22 Mk I ...22 {poll = 28)
Total TV22 Mk II ...17 {poll = 20}
TV22 (not decl.) ...3
TV22A ...1 {poll = 8}
TV22F ...5
TV22U ...1
Total all TV22: ...49
Total TV32 ...4
Total TV62 ...14
Steve
Old 21st Nov 2022, 1:07 pm   #97
Wargenb
Hello,
thank you for the interesting list.
I'm in possession of a TV22F with s/n 103/00197 in good condition which should make it the 6th known in existence, right
I've had it since early 70's and used it for watching Denmarks at the time major broadcast channel.
It's been on display only since the 80's and I'm hesitating to wether powering it up or not. I've read some useful tips here in the forum and will do some checkup on the set later on.
It lacks the power cord which has been lost during one of our numerous relocations over the years, so if anyone have one to spare I'd be happy.
Höllviken is in the south of Sweden btw.
ID:	268481   Click image for larger version
Wargenb is offline
Old 21st Nov 2022, 7:33 pm   #98
line sync
Hi steve
I notice you have 3 tv22`s listed as "not decl".
My tv22 that i mentioned on page 3 of your survey is a mk1.
Robin
line sync is offline
Old 21st Nov 2022, 7:50 pm   #99
Panrock
Panrock's Avatar
Thanks for the updates chaps! These will be included in the next edition of the list.
Steve
Old 21st Nov 2022, 8:44 pm   #100
peter_scott
peter_scott's Avatar
Sorry Steve,
I see that I never gave you the serial numbers of my shrubs.
TV22 83/28483 Working with HKS transformer and LOPT stripped of overwind and voltage doubler EHT added.
TV32 120/08541 Working generally as standard.
Kind regards,
Peter
Name:	P1040617 (Medium).jpg
ID:	268528   Click image for larger version
Name:	P1040602 (Medium).jpg
peter_scott is offline
