14th Oct 2018, 10:10 am | #21 |
Re: Cleaning video heads etc
I use paper also.
14th Oct 2018, 1:05 pm | #22 |
I used a £5 note. Tips rarely extended to a tenner. Modern plastic banknotes probably won't work.
-- Graham. G3ZVT |
14th Oct 2018, 2:02 pm | #23 |
Once, when desperate, a bit of card + vodka.
14th Oct 2018, 3:07 pm | #24 |
anyone ever used p40 paper?
14th Oct 2018, 10:56 pm | #25 |
I take it you mean thermal printer paper, similar to any other paper I'd think.
14th Oct 2018, 11:21 pm | #26 |
For heads which are not too heavily soiled I often found that playing a 'Chrome' or especially a 'Metal' tape all the way through, if necessary more than once, was enough to clear the problem, the premise being that these types were inherently more abrasive than standard tapes.
27th Nov 2018, 12:20 am | #27 |
It brought back some memories reading this of my days on the bench. I used to find what worked best for me was my finger nail. I used to hold the nail on my fore finger against the rotating head as it played a tape. Always cleared the most stubborn head for me.
7th Feb 2019, 8:37 pm | #28 |
To clean video heads i always used a very small square of shamieleather and acetone, dirty heads wont play anything, clean worn heads play good recordings but play own recordings badly with black/white marks on. I hope this helps.
8th Feb 2019, 12:23 pm | #29 |
I'd be seriously concerned that the acetone would dissolve the vanish insulation on the coil winding!
-- Graham. G3ZVT |
8th Feb 2019, 12:27 pm | #30 |
I never use anything other than IPA.
13th Jun 2019, 11:50 am | #31 |
I use chamois sticks which I used to get from Grandata when they were still trading and aeresols of cleaning fluid and new video heads, or I use medi swabs which are soaked in isopropol fluid.
As for symptoms dirty or snowy picture or sound without picture. I have got a LG-LV880 which I had five tries at cleaning before I got a clear picture, but the drum was nearly brown which I think was the result of the back tension set too high. |
21st Aug 2019, 11:21 pm | #32 |
We used the medical wipes stored in a small plastic bag to keep them moist
16th Sep 2020, 8:19 pm | #33 |
16th Sep 2020, 8:34 pm | #34 | |
Re the suggestion to use acetone, acetone is one of the "big gun" solvents which adversely affects many plastics, totally dissolves some. Not to be used unless everything else has failed I think. B
16th Sep 2020, 9:02 pm | #35 |
Meths is slightly greasy as is white spirit, they will clean the heads but I reckon Isopropyl Alcohol is better and have seen mention of it in genuine JVC workshop manuals.
24th Sep 2020, 8:17 pm | #36 |
Something that I've also found are very good (if you can 'acquire' them) are medical pre-injection swabs, small foil packets, non-linting, use once affairs.
My dad swore by this method for cleaning video/cassette heads in the day... actually cleaning most things come to think of it.... |
24th Sep 2020, 8:59 pm | #37 |
Not just the heads but the entire drum and tape path often need cleaning. I service VCRs after many tapes have run through them. Cleaning the full tape path can take some time. Often the pinch roller needs to be removed for a decent clean. Sometimes a capstan motor needs to be removed to properly access and clean its capstan shaft. Some buy a fancy external time base corrector when the problem may often be a dirty tape path.
25th Sep 2020, 2:07 am | #38 |
A build up of oxide on the capstan shaft can cause the tape to ride-up and crease.
Tobacco tar was worse than tape oxide for causing excessive friction. I clean all the posts, guides drum A/C head etc with IPA, actively avoiding the actual heads on the drum. These then got the paper treatment, a banknote was my preference, applied dry, moderate finger pressure oscillating the drum too and fro with the other hand.
-- Graham. G3ZVT |
25th Sep 2020, 3:49 am | #39 |
I always used a chamois swab with PRB video head cleaner and also denatured alcohol on cotton swabs. (I buy the medical ones with the 6" wood shafts, as they are long and get into places the paper shaft ones can't and the cotton does not fall off easy).
25th Sep 2020, 4:52 am | #40 |
At the TV & VCR rental outfit I worked for, we were issued with chamois swabs on ice lolly style sticks along with little bottles of alcohol. The sticks always seemed to be the wrong tool for the job.
-- Graham. G3ZVT |
