26th Nov 2022, 10:13 pm | #1 |
Rigonda VL100 sound offset adjustment help.
I've just bought one of these communist delights ( implied sarcasm ) I now have it up and running which is apparently miraculous. The sound however is off and I need to wiggle the sound offset a bit now my russian not being up to much I have no idea where it is does anyone have knowledge of these sets??
26th Nov 2022, 11:16 pm | #2 |
Re: Rigonda VL100 sound offset adjustment help.
Hi.
I have four of these sets. Is it one for the UK market with our 6 MHz sound? If it is I'd say it's most likely that some of the components around the intercarrier sound section are out of spec or the alignment is out. I don't have an alignment sheet but in the past I've noted carefully where the cores are sitting and then carefully adjust and look and listen if anything changes. If I am able to get any info from my contact in Poland I'll update the thread.
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member |
26th Nov 2022, 11:29 pm | #3 |
Hi
I do have the manual in Russian, It's in PDF format but I'm not sure if I'm allowed or whether I can upload the PDF's here. Perhaps a moderator can let me know. Other than that send me a PM with your email address. EDIT sorry I cant upload here as its from the Radiomuseum. Look for Bimex 1000 Èlektronika there for the relevant info.
27th Nov 2022, 11:44 am | #4 |
I have the manual for it but it's so russian I can't make my mind up what to twiddle lol it's not far off my video sender set up when tuned to it provides sound but it's a tiny bit off but direct to the RF on the digibox nothing
27th Nov 2022, 12:38 pm | #5 |
On the schematic L13/14 and L15/16 are marked as 6.5MHz so I guess they are your tweaking targets.
Peter |
27th Nov 2022, 1:21 pm | #6 |
That's a massive help . Just out of interest do these normally take an absolute age for the tube to kick in? This thing's on for about three minutes before a picture appears.
27th Nov 2022, 2:30 pm | #7 |
Sorry, I can't remember. Mine's been dead for several years. I don't think they take an absolute age to warm up though. I'd have thought less than 1 minute. I guess you need to check the supply rails at switch on.
Peter |
27th Nov 2022, 2:46 pm | #8 | |
You must have better eyesight than me!
27th Nov 2022, 3:39 pm | #9 |
Hi Trevor,
I don't know where I got my schematics from but I needed to patch two sheets together to see the full circuit. The resolution is very marginal and had to guess a little at the number text on the schematic. I'm not sure if it appear here but I'll try adding it. Yes, my copy is a little better than what you see below. Peter |
27th Nov 2022, 8:05 pm | #10 |
Hi Peter
Indeed the ones I have are marginal and I have difficulty focusing on them. Well done in spotting the coils. Mine are all to the Soviet standard with a VHF Turret tuner, three work well but the fourth has a tired tube, allegedly the main set in a Moscow apartment for many years.
27th Nov 2022, 9:47 pm | #11 |
Well twiddling those two has made absolutely no difference at all I still have sound and no picture or picture and no sound I'm wondering never both at the same time I've tried it on both the output of the Digibox and on my video sender and it's the same on both all my other TVs are fine with either
27th Nov 2022, 11:16 pm | #12 |
Back in the TV-DX days you could inject a 0.5MHz signal (oscillator using an IFT) to get the 5.5 or 6.5 MHz sound with 6MHz TV.
28th Nov 2022, 11:15 am | #13 | |
If you have a scope you could probably see whether it's 5.5MHz or 6.5MHz. Peter |
