7th Dec 2019, 5:26 pm | #281 |
Re: Baird T5 restoration project.
That's the control panel veneered.
The front panel is the next part to receive attention. DFWB. |
7th Dec 2019, 11:40 pm | #282 |
Tomorrow the front panel will be prepared for the application of veneers.
The wood grain pattern will be a continuation from the upper control panel. DFWB. |
8th Dec 2019, 1:05 pm | #283 | |
No Longer a Member
I have never warmed to many of the Gorilla glue products as they evolve gas and foam up while setting. It is impossible to beat Titebond for re-veneering, it acts like a far superior PVA: https://www.stewmac.com/Materials_an...and_Adhesives/ The Luthier suppliers have always had more advanced glues due to the difficulties of restoring musical instruments. They also have excellent woodworking tools too that are difficult to get elsewhere. |
8th Dec 2019, 4:17 pm | #284 |
"It is impossible to beat Titebond for re-veneering, it acts like a far superior PVA"
Stewmac ships products to the UK. https://www.stewmac.com/StewMAX/Stew...embership.html DFWB. |
9th Dec 2019, 11:25 pm | #285 |
After checking the remains of the original front panel we find that the edges around the aperture of the timebase controls are not veneered but simply painted brown. First picture. The same applies to the T23.
The second picture shows the veneer sheets selected for the front panel. Since these pictures were taken the veneers have been glued to the panel and are presently under the special press made for the job. DFWB. Last edited by FERNSEH; 9th Dec 2019 at 11:34 pm. |
10th Dec 2019, 5:17 am | #286 | |
No Longer a Member
https://www.stewmac.com/Materials_an..._Material.html https://www.stewmac.com/Materials_an...Materials.html I used some of this material for a vintage amplifier replica: http://worldphaco.com/uploads/UX-171...amplifier..pdf |
10th Dec 2019, 3:38 pm | #287 |
The veneered front panel.
DFWB. |
10th Dec 2019, 3:48 pm | #288 |
That's beginning to look like a T5!
Peter |
10th Dec 2019, 5:45 pm | #289 |
Hi Peter,
now the detailing must be removed from the damaged front panel and transferred to the new one. Some T5 sets don't have this feature and resemble the more austere looking T23. The attachment is a reworked picture from post No 5. DFWB. |
13th Dec 2019, 1:51 am | #290 |
The attachment shows the decorative strips are now transferred to the new front panel. Two are missing so replicas will have to be made.
DFWB. |
13th Dec 2019, 7:16 am | #291 |
No Longer a Member
Fit the replica of the CRT mask I think, rather than the old worm infected one. There is a logical reason. You want the restoration to last as far as possible into the future and look as good as possible too.The old worm infected wood is not consistent with these two objectives.
19th Dec 2019, 11:41 am | #292 |
Close up picture of one of the decorative strips. There's evidence that work has been done in the past to correct woodworm damage. The holes and filler came to light after the dark lacquer was sanded off.
DFWB. |
22nd Dec 2019, 6:25 pm | #293 |
Visited the local B&Q store yesterday and found the wood strips we're looking for to replace the missing and damaged decorative strips on the front panel and controls door. The edges of the new strips will need squaring up to match the existing parts.
DFWB. |
22nd Dec 2019, 6:44 pm | #294 |
Difficult to tell from the photos, but pretty sure the B&Q ones are pine and the original ones are perhaps alder. Dyed and lacquered they will be perfect.
22nd Dec 2019, 6:58 pm | #295 |
Hi Steve,
The strip is pine but as you say when it's dyed and lacquered they will be perfect. It's 8 foot long so there is plenty there to do some dye colour experimentation. DFWB. |
22nd Dec 2019, 7:37 pm | #296 |
I'd try wood dye first to get a good base colour as near as possible, then fine tune the colour using coloured varnishes/lacquers, mixing them if necessary to obtain the correct hue.
10th Jan 2020, 1:54 am | #297 |
stevehertz wrote: "I'd try wood dye first to get a good base colour as near as possible, then fine tune the colour using coloured varnishes/lacquers, mixing them if necessary to obtain the correct hue."
The original decorative strips were pinned and glued into position yesterday. The replacement strips will receive special attention in the manner Steve suggests. Later today the new panel will test fitted in the cabinet. DFWB. |
11th Jan 2020, 2:13 am | #298 |
Showing the new front panel fitted in the cabinet.
DFWB. |
11th Jan 2020, 9:35 am | #299 |
It's going to be very good!
Peter |
15th Jan 2020, 4:43 pm | #300 |
Although the new side panels looked OK, after applying French polish I wasn't entirely satisfied with the appearance of the surfaces. On Monday it was decided to use the remainder of those veneer sheets bought last year to improve the look of the sides. Also, as the front panel is covered with those decorative strips the grain pattern of the veneer is almost covered up. At least the new veneers can be seen at the sides. I haven't book matched the veneer because the original panels weren't done in that manner.
DFWB. Last edited by FERNSEH; 15th Jan 2020 at 4:51 pm. |
