2nd Dec 2022, 4:40 pm | #21 |
Re: Pure Chrome tapes
I mean, reading what 'everyone' has to say they do seem to be problematic one way or another.
3rd Dec 2022, 1:06 pm | #22 |
Quite agree, except that there isn't a Dolby plug-in that really works, in my experience at least. Irksome as it is, a decent external Dolby is the best approach to post-dub processing, even with the additional d-a/a-d conversion. When you've got a Prism, that doesn't matter...
3rd Dec 2022, 1:10 pm | #23 | |
3rd Dec 2022, 1:14 pm | #24 | |
4th Dec 2022, 2:40 am | #25 |
As far as I can make out from reading the relevent comments on another forum, the later pseudochrome cassettes required more bias than the original chromes, but less pre emphasis. So basically a recorder ideally calibrated to a chrome tape would need to have its bias reduced and its pre emphasis boosted, both re pseudochromes. I have cassette decks where bias can be easily changed, but I dont think I have one where pre emphasis can be easily changed, as it can on pro reel to reel decks. Maybe this is part of the problem generally. I guess an auto calibrate deck would have a better chance if it altered both bias and pre emphasis, as well obviously as record gain, in its calibration routine. I've had very little to do with chrome cassettes so again this is new for me.
4th Dec 2022, 2:58 am | #26 |
The thread seems to focus on the old 1970's BASF Chromdioxid tapes, but there's also BASF Chrome tape Called "Pro II", which may be a much later product. I've never tried them; has any else?
I bought a used Harmon/Kardon machine a while ago and the BASF Pro II tapes are on the preferred list for that, though they called up TDK SA as their reference Cr2O3 tape B
4th Dec 2022, 11:14 am | #27 |
I vaguely remember that BASF made some sort of pseudochrome tape towards the end of their time as a manufacturer. Maybe they finally came to terms with the industry. I don't have any experience with these tapes.
4th Dec 2022, 5:39 pm | #28 |
I just took a look on ebay; first impression is that BASF Pro II was/is a North American thing. Lots for sale there but none in the UK. Here, there's a BASF tape called 'Sound II', which might the European badge?
But on a machine referenced on SA, no great incentive to try. B
4th Dec 2022, 5:52 pm | #29 | |
https://www.45spaces.com/audio-compa...hp?r=aud487826 Never really a fan of BASF after a lot of issues with their 1970's offerings such as dropout and oxide shedding, but from about 1980 they overcame these problems. BASF CR-E II was excellent and correctly biassed did marginally outperform many contemporary pseudochrome formulations. https://www.45spaces.com/audio-compa...hp?r=aud826970 Rich
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be! |
8th Dec 2022, 1:54 pm | #30 |
A few things to bear in mind:
USA BASF products from the late 70s into the early 80s specifically had dreadful quality control which was sorted some time around 1982. That lead to BASF gaining a poor reputation in the USA from which they never recovered even though the tape made for the rest of the world was universally excellent. There was also an outright lie spread by 3M regarding BASF professional video tape which spread to include BASF audio tape and cassettes, regarding CrO2 damaging heads. This was a quickly debunked lie circa 1980 but still persists to this day. There is a drop in sensitivity of a few dB over the first 3-5 years of a CrO2 tape's life. thereafter it should remain stable. Careful (or automatic) calibration can still bring these older cassettes to make excellent recordings. If you have a Yamaha KX deck you also have "play trim" which adjusts the playback EQ before the Dolby circuit to further help compatability. There was and remains nothing wrong with CrO2 cassettes when used as intended. The problem is that the Psuedochromes are used in a different manner and most people became used to them rather than genuine chrome cassettes. Recording technique is simply different. CrO2 gets a bad rep for all the above reasons. But the fact remains that if you use it as intended, it's still great. Far lower noise floor than any other cassette tape formulation ever devised. Type IV metal cassettes had a higher noise floor than types I or II but could also take higher recording levels and record slightly higher frequencies. Ultimately they were the best *if* you had a deck capable of exploiting their strengths. Which was generally the mid to top range decks with better heads and beefy bias and record amp circuits. Not just any deck with a type IV switch. Even then, a good type II (chrome or pseudochrome) would probably give 95+% the performance of a type IV. |
