Old 19th Nov 2022, 9:08 pm   #21
Techman
Techman's Avatar
Default Re: Elizabethan LZ 34 R2R Checkout
The large oval speaker looks to be about right for the Elizabethan as far as I remember. I think the smaller round speaker on the elliptical baffle is from the Ferguson 3248 and if it is then it's obviously wrong. I think I've got a couple of these recorders, possibly branded HMV, but they're difficult to get to at the moment.
I knew Collaro and Magnavox became one and the same one way round or the other.
Techman is offline
Old 20th Nov 2022, 12:14 am   #22
DMcMahon
DMcMahon's Avatar
Yes obvious now that the round speaker in the Ferguson 3248 is not the original.
DMcMahon is offline
Old 20th Nov 2022, 12:43 am   #23
DMcMahon
DMcMahon's Avatar
The 3248 Service manual lists a 8 Ohm elliptical speaker and 8 Ohm is shown on the schematic, the fitted round speaker is 4 Ohms.
DMcMahon is offline
Old 20th Nov 2022, 11:11 pm   #24
ricard
ricard's Avatar
Originally Posted by Techman View Post
It rumbles along nicely like all BSR TD10 tape decks do, just turn the music up and you won't notice it.
I should mention that I've replaced the main idler in a TD-10 machine that I have, with a Philips idler from an EL3547 (the EL3542 and similar machines with the same mech chassis (EL3536 among others) have three of them, and the EL3546 also has an idler of the same type). The outer diameter and shaft diameter are identical, but the shape of the hub is different, meaning that some creative work with some washers or shims is needed to get it to work properly. Still, these older Philips idlers predate the 'goo' era and tend to be reasonably supple still, so in my case it was a definitive improvement over the original but very much hardened one.
ricard is offline
Old 21st Nov 2022, 4:39 pm   #25
af024
Your thread spurred me on to take a look at mine, which, I discovered, had a seized up joystick from standing unused for years! The problem wasn’t so much the joystick, but the reel table pivot arms. Just like BSR record deck platters, the two dissimilar metals had bonded together, well that plus hardened grease and that has stopped them swinging. I soon sorted that out though.
First of all I can confirm that the big oval speaker that you show is the one that’s fitted in mine, so that puts that one to bed.
Secondly, and this is more of a question really, what sort of gap is there between the bottom of the motor and the underside of the casing? The gap in my example is less than 1mm. No wonder that the ventilation grille has all crumbled away! I initially thought that the motor had dropped due to rotted rubber mounts, but they seem to not be deformed, ok they might be a bit hard, but they don’t look squashed. Also, if the motor had dropped, the stepped motor pulley wouldn’t be engaging properly with the capstan idler on all speeds (which it is), although, the position of the motor pulley in relation to the fast forward idler (removed in the photo to show the capstan idler more clearly), does seem to suggest that the motor has dropped (as the idler is only just engaging with the upper most part of the pulley. All that is weird though because the pulley is all one piece, so how can the FF pulley step be a bit lower than it should be whilst the other parts of the pulley are in the right place? It points to the FF idler being I the wrong place, but that cannot be adjusted (apart from taking the lower shim/washer out, which doesn’t move t much).
Looking closely at the underside of the cabinet, especially with the straight edge against it, it looks like it’s slightly bowed inward, so that doesn’t help.
Naturally, given the close proximity of the motor to the grille, I’m reluctant to fit my newly sourced replacement.
I might see if I can pack the motor up a little, but I can’t see me being able to get the clearance that I think it needs. Good game eh.
Finally, not withstanding the above, my machine has never been particularly good at fast forwarding. Obviously it would help if it was meshing with the central part of the pulley as opposed to close to the top edge, but regardless, I thought I’d try a little experiment. I removed the FF idler wheel, clamped it in a drill and gave it the rough-up treatment on its running edge using Scotchbrite whilst spinning it. I then cleaned it with IPA and gave it a thin coating of ‘Plasti Dip’ which has given it a renewed rubber coating. It works a treat!
I’ve just done a new sample recording at 7.5 ips and I was totally blown away by the reproduction. Very impressive indeed!
ID:	268500   Click image for larger version
ID:	268501   Click image for larger version
ID:	268502   Click image for larger version
ID:	268503   Click image for larger version
Now where on earth did I remove that from?
af024 is offline
Old 21st Nov 2022, 7:36 pm   #26
DMcMahon
DMcMahon's Avatar
Interesting information and thank you for the speaker confirmation.
My gap is around 40mm so huge compared to yours, see first photo. My ventilation grill is good condition.
The distance from the end of the motor to the chassis main metalwork is around 70mm.
My chassis sits on 4 semicircular 3mm thick rubber spacers under the 4 the securing screws. These look very homemade, looks like they have been made from circular washers cut in half. If these were not fitted the chassis would only sit around 3mm lower so the motor gap would only reduce to around 37mm so still huge compared to yours.
ID:	268518   Click image for larger version
Name:	Deck securing rubber spacers.jpg
ID:	268519   Click image for larger version
DMcMahon is offline
Old 21st Nov 2022, 8:35 pm   #27
Techman
Techman's Avatar
The ventilation grille in the bottom of the case of mine is smashed and you can see the bottom of the motor just behind it. I'd never given it that much thought other than it had either got brittle plastic syndrome or perhaps had been bashed against something while being carried or had been stood on something uneven at sometime in the distant past. I've just been looking through some old pictures in my files to see if I'd taken any of the innards when I originally worked on it and I had, remembering that mine is a slightly different model with different mounting fixings. Also how bad the idler was in mine. There are several more pictures.
ID:	268521   Click image for larger version
ID:	268522   Click image for larger version
ID:	268523   Click image for larger version
Techman is offline
Old 21st Nov 2022, 9:28 pm   #28
DMcMahon
DMcMahon's Avatar
The internal height of my wooden case is 140mm and the chassis fixings are 35mm down from the top edge of the case. Techman's chassis fixings look much lower.
DMcMahon is offline
Old 21st Nov 2022, 10:13 pm   #29
af024
Thank you guys. There's something really weird going on here - such a massive difference! When I get a moment I'll take it all out of the box again and do some comparisons. Mmmm...
Oooh, that idler's really got it bad hasn't it. I wonder why some go like that and others don't?
af024 is offline
Old 21st Nov 2022, 11:58 pm   #30
DMcMahon
DMcMahon's Avatar
If yours is similar to Techman's then it looks like the chassis is secured lower down in the case and possibly your cases are not quite as deep as my case, so resulting in the base of the motor getting much closer to the base.
DMcMahon is offline
Old 22nd Nov 2022, 9:26 pm   #31
af024
Well I’ve managed to take the chassis out again to make some measurements.
At the moment I can’t see what’s different, but something surely must be. Perhaps the entire box isn’t so deep on mine?
I certainly can’t lift the entire deck up, so it can’t be down to that. I can’t see how to lift the motor either. I did at least spot a screw adjustment for the height of the idler that drives the flywheel/capstan, so at least I can see that if I could lift the motor and/or its pulley upwards to better align the FF idler against the motor pulley, there would then be the capability to re-align the capstan flywheel with the motor pulley steps. Looking how the FF idler sits in relation to the motor pulley and the take-up spool platter rim, it looks very much like the FF idler is sitting a bit high, but there’s no adjustment for that.
So two mysteries really, why is the motor so low in the chassis and why is the FF idler sitting a little too high? It’s weird stuff for sure. I guess I won’t be fitting my spare grille anytime soon!
Anyhow, conundrums to one side, I thought I’d report on the effectiveness (or otherwise) of the rubber coating I applied to the rim of the FF idler wheel. It actually works a treat. It’s nice and grippy and FF works better than it ever has in all the years that I’ve had it in my collection. It has just fast forwarded an entire 7.5 inch spool without any problems whatsoever. The transformation is really quite impressive.
I’m not sure about the look of the spring that’s mounted on the joystick mech though. Perhaps it’s in backwards or something?
All good fun.
Sorry about the poor focus on some of the photos - the camera drives me mad. It’s supposed to auto-focus, but it fails to do so more often that I’d care to mention! There’s no manual override either.
ID:	268578   Click image for larger version
ID:	268579   Click image for larger version
ID:	268580   Click image for larger version
ID:	268581   Click image for larger version
af024 is offline
Old 22nd Nov 2022, 9:27 pm   #32
af024
More photos ...
ID:	268583   Click image for larger version
af024 is offline
Old 22nd Nov 2022, 9:29 pm   #33
af024
More photos ..
ID:	268585   Click image for larger version
ID:	268586   Click image for larger version
ID:	268587   Click image for larger version
ID:	268588   Click image for larger version
af024 is offline
Old 22nd Nov 2022, 10:26 pm   #34
DMcMahon
DMcMahon's Avatar
Your Joystick spring position looks the same as mine.
Your photo 4 in Post 31 shows the chassis mountings are around 80mm below the top of the case, mine are 35mm, so this means your chassis sits 45mm lower.
Your photo 2 in Post 31 shows your external case depth is around 135mm, mine is 145 so another 10mm more on mine.
Also your photo 5 in Post 33 shows your chassis sitting below the top of the case while mine is nearly 10mm above the top of the case (as per photos in Post 1).
So basically your case mounting distance for the chassis is very different.
Name:	Joystick spring.jpg
DMcMahon is offline
Old 23rd Nov 2022, 4:42 pm   #35
af024
Hello David,
Thank you for that. Yes I see what's going on now. What a difference that makes - how interesting!
I don't think I can jack mine up in any sensible way, so I think I'm stuck with it. I suppose I could at least mount some internal wooden battens to the bottom (on the inside) to straighten out the slightly bowed-up bottom. That might make 2-3mm difference and give the grille a bit of clearance, although it won't be much of course!
At least the spring looks similarly installed (it also has different ends and it looks like mine is installed the same way as yours in respect of that also). My spring looks a bit sprained in comparison though.
Interestingly, now that I've had chance to compare you FF idler position with mine, they look as though they are both pretty much in the same place, so I'm not so worried now. I would have preferred it sitting a little lower, but that's the way it is I suppose. Also, now that my rubber spray has well and truly sorted out FF, I'm sufficiently content to not mess about anymore (unless in the fullness of time it starts sheading the new rubber coating of course!
This has been a very useful thread. Thank you for posting!
Kind regards,
Andy
af024 is offline
Old 23rd Nov 2022, 4:50 pm   #36
af024
Oh, I nearly forgot, it may also be the case that the cabinet widths are also different. I say this because if I fit a 7 inch reel on mine, the rim of it stays inside the confines of my cabinet. One of your photos looks as if your reel overhangs the cabinet sides a bit. Of course I'm guessing as to what size reel you have on there, so I could be wrong. The extremities of my cabinet width measures 405mm.
I wonder if that's why people talk about a MK1 and a MK2?
af024 is offline
Old 23rd Nov 2022, 8:38 pm   #37
DMcMahon
DMcMahon's Avatar
Yes I noticed that your cabinet width is wider, mine is 385 mm and the reels were 7".
The only reference to Mk. 2 I have seen, refers to improved electronics, no idea if any changes to the case/cabinet.
Think I have seen references to different cabinet styles for similar recorders, i.e. sometimes more than one variant of cabinet for the same/similar model.
I wonder if you removed the chassis mounting brackets and modified them to L shape then fit them to the side battens (that the brackets currently secure to the underside of the battens), this would raise the chassis height quite a bit.
You would have to do careful measurements/checks to see how that would affect how the top panel parts would fit.
DMcMahon is offline
Old 24th Nov 2022, 2:14 pm   #38
af024
Hello David,
Thank you for your further thoughts and cabinet measurement.
If I were to try and jack it up a bit, somehow I think I'd also have to separate and reposition the metalwork that contained the pots and sockets etc downwards else there would be a large gap around the wooden surround.
All good fun eh.
Not until this thread did I realise that there were two different chassis positions and two different cabinets. You learn something every day!
af024 is offline
Old 25th Nov 2022, 10:22 am   #39
DMcMahon
DMcMahon's Avatar
What is the consistency of that rubber conditioner/replenisher like ? is it like emulsion paint or thicker like gloss paint or thicker still ?
Wondering how easy it is to get a uniform coating.
For an idler that only drives the Take Up reel table for fast forward winding not so important but for an idler that drives the capstan flywheel during Play more important for Wow & Flutter performance.
DMcMahon is offline
Old 25th Nov 2022, 11:05 am   #40
af024
Hello David,
It sprays on and at that stage its quite fluid. As it dries it tensions up and any slight imperfections that might have been present on first spraying get stretched out to nothingness. Obviously its best to try hard to apply a consistent coating by uniformly rotating during spraying and trying to remember where you started, but so far I've not had a failure.
Prior to spraying this particular idler wheel, I too had wondered about a more critical application, so I sprayed a condemned idler in a BSR record reproducer deck to see. I was amazed! I have to say, it grips like a goodun and there's no bump, wow or flutter that I can perceive as a result. It's probably the best BSR deck I've come across in many years for cycling right through without any slowing down or stalling.
I might try a pinch roller at some point. I think I have a sick one in a Philips N1500 that might benefit. Now that will be a test!
What I don't know of course is how long it will stay attached to the original rubber surface, but so far so good.
It's not so much a replenisher like "Rubber Renew", but an actual rubber coating. I'd say its a bit like emulsion paint consistency when first sprayed, but that rapidly changes as it dries. In fact I had to be pretty quick smartish in removing my masking paper else it would have made all that a permanent feature! I'm not sure you'd get any time to fettle with a paint brush, so you're committed with the spraying I'd say.
af024 is offline
