Old 10th Jun 2021, 8:56 pm   #1
unitelex
Default Method for colouring and texturing epoxy resin
I found by experiment that I could tint normally clear epoxy resin very easily using laser toner powder (laser printer).
I needed to achieve a dark anthracite colour to fill in a chipped surface.
I am aware that black epoxy is available but did not have any nor did I want to purchase a tube especially for this very small job.
I used black toner powder, added while mixing the clear adhesive and hardener together. While setting I noticed that the result was going to end up too glossy compared to the base material so while it was still tacky I dusted the surface with more toner giving a matt look. The results were surprisingly good.
I have not tried with magenta, blue or yellow toner or any blending of these.
Best Regards
Chris
unitelex is offline   Reply With Quote
Old 11th Jun 2021, 11:08 am   #2
emeritus
Default Re: Method for colouring and texturing epoxy resin
When I was a student, in the lab at STC where I did work experience, every bench had a small tool box which included a pack of Araldite and a small jar of Titanium Oxide powder that they used to mix with the Araldite where a white finish was required. I have coloured Araldite brown to fix some earthenware plant pots by grinding a piece of broken pot in my wife's kitchen pestle and mortar to a very fine powder.
emeritus is offline   Reply With Quote
Old 14th Jun 2021, 4:34 pm   #3
greenstar
greenstar's Avatar
I wonder how to achieve a brown bakelite colour and whether filing/grinding bakelite to mix with it would achieve that? I guess this has been done effectively.
greenstar is offline   Reply With Quote
Old 19th Jun 2021, 12:07 pm   #4
chriswood1900
I think you might need to be careful where you get the old Bakelite from, as some used asbestos fibres as the filler and if ground up they may present a health hazard.
Chris Wood
BVWS Member
chriswood1900 is offline   Reply With Quote
