15th Jan 2022, 6:48 pm | #1 |
Looking for data for R.C.A. 16957 transistors
Hi l have some of these R.C.A. 16957 transistors it is a TO3 NPN
I cannot find any data in my books or on the internet so it is over to you! Thanks Keith |
15th Jan 2022, 7:25 pm | #2 |
Re: Looking for data for R.C.A. 16957 transistors
Could be an specific selected part. I don't recognise that number format; RCA's normal whole number system began with a 4
Maybe someone else can shed more light. Craig
Doomed for a certain term to walk the night |
15th Jan 2022, 8:28 pm | #3 |
The "RCA Transistor Manual" 1967 edition confirms what Craig said, it only has RCA parts starting with 40xxx and the usual 1N, 2N etc, could it be a custom coded part for an equipment manufacturer?
David |
15th Jan 2022, 11:55 pm | #4 |
I think you might need to try looking in late 1970's early '80's RCA databooks.
You also need to add RCA in front of the number as despite the regular 40xx, 2N style numbers everybody remembers, they did many others including 'Bxx' prefixes. Here is a section of a full page ad from Practical Television January 1985 listing them for sale. |
16th Jan 2022, 11:22 am | #5 |
Re RCA 16957 transistor, the 1969 data book supports the 40xxx guidance offered by "Factory". A clue about application could be that RCA tended to use TO3 packaging mainly for domestic type applications such as audio and TV time bases. I would suspect that it is an OEM spec number.
Orakle42. |
16th Jan 2022, 1:10 pm | #6 |
RCA also shows TO-3 types for various industrial applications in the databook I have. Unfortunately I couldn't find anything on the 16957.
16th Jan 2022, 7:05 pm | #7 |
I've got several RCA T03 trannys with a 16 prefix, EG 16182 & 16799 for instance as well as a few 40409's & 40251''s, been trying to ID them for years. Thing is we all probably have a few drawers of obsolete NOS trannies but most of which can be subbed for modern parts. That said with the recent shortage of parts, now might be the time to list them on Ebay.
Andy.
16th Jan 2022, 10:54 pm | #8 |
Quite common to use "special" numbers for specific customers. Grundig thyristors were all "in house" numbers. Fairly certain they were RCA.
That advert from Television. Was it "Sendz" components? I THINK he is still tading, I purchased an audio chip for a flat screen TV from him just a few years ago. If he is, he may still have them. Nearly all his stuff stuff came from UK manufacturers, presumably their overstock. He knew the basic data (ie, these are BD243) and I had loads off him. Never a failure. Les. |
17th Jan 2022, 1:08 am | #9 | |
No - P. V. TUBES 104 ABBEY STREET, ACCRINGTON LANCS No RCA transistors listed in the SENDZ ad of that edition, but, it might be short a few pages. |
17th Jan 2022, 2:01 am | #10 | |
Both according to my ECA vrt volume 2 edition 2004 (should get a new set one of these days). |
17th Jan 2022, 9:03 pm | #11 |
RCA 40251 & 40409 are in the 1967 "RCA Transistor Manual" I have here;
40251 40409 Do you want the outline drawings too? David |
18th Jan 2022, 7:37 am | #12 |
Thanks Martin & David, that's grand.No joy though on the OP's RCA tranny?
Andy.
18th Jan 2022, 1:00 pm | #13 |
Unfortuntely not. ECA 2004 mentions some 16xxx types but not this one. My only RCA databook from 1977 doesn't mention it either.
18th Jan 2022, 8:41 pm | #14 |
Not in the 1994 D.A.T.A Digest Transistor databook either.
David |
22nd Jan 2022, 2:38 am | #15 |
Relaying from a Dutch forum: Anyone ever encountered an RCA 21270? Google has 1 entry that suggests it was used as an audio output in an organ, which makes sense as it is a TO-3 type. Other markings are 274 where RCA is normally stamped and VHU7416440 where the date code is normally stamped. RCA isn't stamped on the transistor but on the box.
22nd Jan 2022, 4:52 pm | #16 | |
That's interesting to know. I used to buy loads of components, panels, TV spares etc from them when I was in the repair business. I assumed Sendz closed down around the time of TELEVISION magazine's demise. When I was buying stuff from them they were at 63 Bishopsteignton, Shoeburyness, Essex. Just had a search and appears the business is in London Road, Southend, Essex but can't seem to see a website or phone number. I wonder if they advertise or just rely on local custom. Maybe other members have dealt with them recently? Regards, Symon |
22nd Jan 2022, 8:06 pm | #17 |
Symon, it is a few years (perhaps 5 or 6) and he had a young chap looking after his"computering" side. I may have used the old TV mag phone number, but whatever I ended up with this young chap. I told him I knew David quite well, and did a fair bit of business with him through the '80s. Not sure if he gave me a different number, or just passed mine onto him. Anyway we had a bit f a chat, and he supplied me the audio chip I needed.
I have the old phone number on the tip of my tongue, but not quite certain. Starts 01702, and a 992 in there as well was it 330992?? Probably not.. Les |
23rd Jan 2022, 12:02 am | #18 |
This is listed as current in 2021 at the London Road address.
In order to confuse the number harvesters, it is written in reverse so start at the right hand side of the number -281979 11770- (0771.............) |
23rd Jan 2022, 5:23 pm | #19 |
Hi Thank you for all your efforts trying to find information on this transistor.
Keith |
28th Jan 2022, 1:07 pm | #20 |
Found a reference at least to it here ...
From the June 1987 Television magazine, searching for 'RCA16957' |
