Old 18th Nov 2021, 11:06 am   #1
GMB
GMB's Avatar
Default How to consolidate flaking paint?
I have run into this again and still do not have a solution.
So does anyone have a method for stabilising paint that is cracking and flaking off something? I have often run into this problem with meter scales, where the paint clearly doesn't like to stick to the scale material.
I am asking about ways to avoid repainting or changing it completely, but how to conserve the original paint e.g. where the damaged area is not so bad - but will get worse in time.
GMB is offline
Old 18th Nov 2021, 11:19 am   #2
FIXITNOW
FIXITNOW's Avatar
Default Re: How to consolidate flaking paint?
I missed the over using an aerosol can off clear lacquer / vanish , just several light coats to stick it all together
FIXITNOW is offline
Old 18th Nov 2021, 8:48 pm   #3
stitch1
stitch1's Avatar
On a recent repair programme they were using something designed to do this, not sure if this would work on dials.
https://www.toolstation.com/zinsser-...E&gclsrc=aw.ds
John
stitch1 is offline
Old 19th Nov 2021, 3:17 pm   #4
The Philpott
The Philpott's Avatar
I recall that-
-The thicker the paint flakes are the easier it is.
-If the flakes are concave or convex from heat saturation it's almost impossible.
-I used clear car paint lacquer in one case, sprayed into the cap then dabbed on. That was 5 years ago and it hasn't yellowed yet. I used it quite wet to allow it to wick under the flakes if possible. Prone to drying rather more quickly than we would like.
Dave
The Philpott is offline
