Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Where To Get Sets and Parts
Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay).
Old 28th Oct 2021, 4:00 pm   #1
David G4EBT
David G4EBT's Avatar
Default Film Free Waterslide Laser Printer Decal Paper
Although I don't have a laser printer, but for anyone who does have a laser colour printer and might want to experiment in printing decals for radio tuning dials, I've just become aware of a new product which might be more suited for tuning dial reproduction than the normal laser or inkjet waterside decal paper.
As anyone who has attempted to create a new dial on glass using conventional waterslide decal paper will know, though the image may look excellent when still on the backing paper, once slid onto glass, the image is 'wishy washy' and quite hopeless.
Some time ago, having had a lot of success in creating and fitting decals on white and clear in-jet decal paper, (more commonly called 'transfers' in the UK), applied onto solid backgrounds, I spent quite a lot of time and not a little expense in experimenting with creating radio dials - not so much for radios that I was restoring, simply for those for which I had reasonable scans, such as the KB FB10 'Toaster' radio and the ubiquitous Bush DAC90A 'money pit'.
The decals (printed in reverse of course for application to the rear of the dial glass), looked excellent while still of the backing paper, but when applied to the glass, the artwork lacked opacity, was wishy washy, and fell well short of what was desired. (The original dials would of course have been screen printed - not decals).
I've no idea whether this new paper will produce better results, but thought I'd give it a mention. Steps 1 to 5 are the same as with normal waterslide decal paper (which can be had for both ink-jet and laser printers is white and clear), but steps 6 onwards only apply to this new paper:
Step 1 - Print your text or images in reverse mode onto our new special film free decal paper.
Step 2 - Cut them out
Step 3 - Dip in water
Step 4 - Take out and slide your decal on, picture side against the surface.
Step 5 - Smooth away any water from under the decal with a cotton wool ball and allow to dry hard.
Step 6 - Place into a home oven at 110c for 15 mins.
Step 7 - Remove and allow to cool, over night is best.
Final Step - Catch the edge of the decal films special top surface and gently peel away to reveal your decal embedded into its surface with no film.
It isn't cheap and applying waterslide decals is an acquired skill.
The title infers that you slide the transfer off the paper but if you do that, it will crinkle up. As anyone who has used decal paper will know, having soaked the paper until the decal will slide on the backing paper, you need to hold it in the position that you wish to apply it, and slide the backing paper from beneath the decal, gently smoothing the decal onto the surface to remove all bubbles.
I guess the decals might be a little more durable, but whether the colours are more solid is anyone's guess. When applied to the rear of a dial, durability isn't an issue - what matters is opacity.
1 Sheet - £3.99
3 Sheets - £10.99
10 Sheets - £24.99
https://mrdecalpaper.com/products/fi...paper-clear-a4
I've attached pics of reverse scans of two Bush DAC90A dials, and a KB FB10 'Toaster' radio, which all looked fine when still on the backing paper, but were dismal when slid off onto glass, and far short of what is called for.
Hope that might be of interest to someone.
Name:	DAC90A later version dial Reversed.jpg
ID:	244463   Click image for larger version
Name:	DAC90A Early Brown Dial Reversed_edited-1.jpg
ID:	244464   Click image for larger version
Name:	KB FB10 Dial Scans.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 29th Oct 2021, 11:16 am   #2
Gabe001
Default Re: Film Free Waterslide Laser Printer Decal Paper
Thanks David. Having bought from them I got notified about this by email and it's made me curious.
I have read a restoration thread on a bush dac10 on someone's website (not this forum, cannot remember where) and the restorer got around the problem of the solidity of the colours by doing 2 waterslide transfers on top of each other. Something I may attempt in future if needed. I suppose placement is crucial.
Gabe001 is offline
Old 29th Oct 2021, 11:50 am   #3
vidjoman
I guess that a laser printed image would have a greater solidarity of colour than an inkjet and look better on glass when backlit.
vidjoman is offline
Old 29th Oct 2021, 12:58 pm   #4
Radio Wrangler
Radio Wrangler's Avatar
Now, do you make two images and transfer them individually to the glass, or do you run the same sheet through the laser printer twice and then make one transfer onto the glass?
Experimentation needed!
Radio Wrangler is offline
Old 29th Oct 2021, 2:02 pm   #5
Gabe001
From the write up, the former
Link here -the process is described towards the bottom of the page
https://www.vintage-radio.com/recent...ush-dac10.html
Gabe001 is offline
Old 29th Oct 2021, 4:51 pm   #6
The former I guess, I don't think any printer picks up to the accuracy needed.
Old 1st Nov 2021, 1:01 pm   #7
DonaldStott
DonaldStott's Avatar
Thanks David for this update.
In the past I tried to replicate a radio tuning dial for a Bush DAC10 but, as you predicted, the results turned out to be very 'wishy-washy'!
I'll certainly try the paper you suggest and give it another go.
BVWS Member
DonaldStott is offline
