Old 18th Jan 2022, 4:24 pm   #21
Mark1960
Default Re: The PICL V2 - a development of Karens 2007 original
Size limit for 4 layer board is 50mm x 50mm for $2, so I guess the question should be why Phil’s board was priced at $2 for 5 one time.
Mark1960 is offline
Old 18th Jan 2022, 4:39 pm   #22
Phil__G
I've been using JLC for ages and recently I've had three separate PICL orders from them. All were between £2 to £2.70 per board. I've had some quite large M6802 boards from them at £2.60 each and my Cosmac Elf replicas (7" square?) were only £3 each. I think there must be an expensive option that you've accidentally selected Mike, its easily done...
Phil
Phil__G is online now
Old 18th Jan 2022, 5:11 pm   #23
Phil__G
...all delivered prices
Oh, and if you say "yes they can place their logo" its cheaper, and they hide it quite well.
Old 18th Jan 2022, 7:13 pm   #24
Mark1960
I think you are comparing the price for five, excluding carraige, with the price each including carraige when you order five. Also comparing $ to £.
Mark1960 is offline
Old 19th Jan 2022, 10:07 am   #25
Slothie
Default Re: The PICL V2 - a development of Karen's 2007 original
I suppose I should chip in and mention I recieved Phils board ages ago and built it. I haven't found a use for it just yet, but you never know! Its a fab little board, and having the flag LEDs on board makes it easy to make the traditional "led blinker" of the controller world....
Slothie is offline
Old 19th Jan 2022, 11:45 am   #26
Phil__G
Originally Posted by Mark1960 View Post
I think you are comparing the price for five, excluding carraige, with the price each including carriage when you order five. Also comparing $ to £.
Sorry what I meant was, the price examples above are divided down to 'per board' costs including delivery from a batch of usually 5 or 10. My most recent PICL order (of three batches so far) was for 10 boards and cost £27 delivered, £2.70 per board - cheap as chips! (is that an obsolete phrase now, during the silicon crisis?)
Another 'economy factor' is unless I'm in a rush, I usually go for the cheapest delivery option, the one that they hide, or say 'not recommended'. Its barely slower (if at all) and much cheaper. Its not the stereotypical Yorkshireman, its cos I'm retired on a low income so it all helps! Also it galls me to see the courier make more money from my order than JLC do!
Originally Posted by Slothie
I suppose I should chip in and mention I received Phils board ages ago and built it. I haven't found a use for it just yet....
I've found it handy for testing SC/MP routines via the Intel loader, having the resident monitor means you can fiddle with values such as delays, loop counters etc without constantly reassembling & reloading. The standalone 'auto-run' thing is fun too
Of all Karens projects I find it the most fascinating - its simplicity appeals to my simple mind - yet it has everything the 1976 SC/MP enthusiast would have wanted - plenty of memory, a monitor & NIBL basic
Phil
Old 20th Jan 2022, 2:44 pm   #27
Slothie
After writing that last post I remembered that back in the day at school we had a RML 380Z that hosted a number of languages including Li-Chen Wang's tiny basic (which is essentially what NIBL was derived from). I started writing a Star Trek program for it, which was a challenge given there is a single array that was essentially just peek-and-poke at physical memory (the '@' operator in NIBL). I wish I had a listing of what I did, it was partially functioning..... I will have to have another go maybe!
Slothie is offline
Old 22nd Jan 2022, 1:50 am   #28
Mark1960
Well I finally finished building the board Phil gave me. Took a couple of tries to get it running thanks to a bad mini usb connector on my serial adapter, and also not setting caps lock, local echo and options for CR/LF. I guess I should really read the manual again before turning it on, but far too impatient for that.
Next step is to try and confirm I can assemble the PIC code and still have it working, then try and understand Karen’s code. That might take a while.
Mark1960 is offline
Old 22nd Jan 2022, 1:58 pm   #29
Michael - K8LH
Could one of you Gentlemen there in the U.K. get a price for the attached PCB at JLCPCB, please? I'm curious if JLCPCB will honor the 'special' 100x100 mm PCB pricing in the U.K., as they do here in the U.S., with boards that have a 4.0-inch (101.6-mm) dimension.
TIA. Cheerful regards.
Michael - K8LH is offline
Old 22nd Jan 2022, 3:28 pm   #30
Michael - K8LH
Yippee! Congrat's on bringing up the PICL/NIBL system, Mark.
While studying Karen's source code, I've found it helpful to include the macro generated code in comment lines. Example below.
Regards... Mike
Code:
; Execute SCMP instruction (19)
; NB PCLATH must be set to HIGH OPVEC
XHALT
XPPC0
XNOP
EXEC    INCPC                   ; increment program counter       |
;       | INCF    P0HI,F        ;                             (1) |
;       | INCFSZ  P0LO,F        ;                          (2)(1) |
;       | DECF    P0HI,F        ;                           ~ (1) |
        MOVF    P0HI,W          ; get address hi              (1) |
        ANDLW   B'11110000'     ; ROM ($0000..$0FFF)?         (1) |
        skpnz                   ; no, skip, else           (2)(1) |
        GOTO    L8              ; branch (ROM)              ~ (2) | 7/8?
;  get opcode from RAM (used as index into opcode vector table)
        RDRAM   P0HI,P0LO       ;                                 |
;       | movf    P0LO,W        ;                             (1) |
;       | movwf   PORTC         ; address lo lines            (1) |
;       | movf    P0HI,W        ;                             (1) |
;       | iorlw   B'11100000'   ; /CS1 = 1, /OE = 1, /WR = 1  (1) |
;       | movwf   PORTD         ; address hi + control        (1) |
;       | andlw   B'01011111'   ; /CS1 = 0, /OE = 0           (1) |
;       | movwf   PORTD         ; read RAM                    (1) |
;       | nop                   ;  "                          (1) |
;       | movf    PORTB,W       ; WREG = RAM byte             (1) |
;       | bsf     PORTD,5       ; /OE = 1                     (1) |
;       | bsf     PORTD,7	; /CS1 = 1                    (1) |
        MOVWF   PCL             ; jump (opcode vector table)  (2) | 20?
;  get opcode from ROM (used as index into opcode vector table)
L8      RDROM2  P0PT1,TMP,HIGH OPVEC
;       | call    P0PT1         ; RDROM1 P0HI,P0LO            (2) |   < 16F18877 code >
;         | movf    P0HI,W      ; ROM address hi              (1) |    movf    P0HI,W   (1)
;         | addlw   NIBL/256    ; set address hi & 'page'     (1) |    addlw   NIBL/256 (1)
;         | movwf   PCLATH      ; for GOTO or CALL ops'       (1) |    movwf   FSR0H    (1)
;         | movf    P0LO,W      ; ROM address lo              (1) |    movf    P0LO,W   (1)
;         | movwf   PCL         ; return opcode ($00..$FF)    (4) |    movwf   FSR0L    (1)
;       | movwf   TMP           ; save temporarily            (1) |     ~
;       | movlw   OPVEC/256     ; set address hi & 'page'     (1) |    movlp   OPVEC    (1)
;       | movwf   PCLATH        ; for GOTO or CALL ops'       (1) |     "
;       | movf    TMP,W         ; opcode used as vector       (1) |    moviw   FSR0++   (2)
        MOVWF   PCL             ; jump (opcode vector table)  (2) | 24 movwf   PCL      (2)
Old 23rd Jan 2022, 11:22 am   #31
Phil__G
Here's your starter for ten Slothie:
Li-Chen Wang's original "TinyTrek" for Palo Alto Tiny Basic:
http://www.dunnington.info/public/startrek/startrek.asc
and the original article: (its the same listing)
https://archive.org/details/1976-07-...p?view=theater
I do the same Mike, personally I find Karens heavy use of macros quite hard to follow, but thats just me!
Here's your quote, as usual, mostly delivery charges (to UK). The 'cheapest' option (my favourite!) saves you £10 (this is for a long-standing customer, no 'first order' offers)
Old 23rd Jan 2022, 3:54 pm   #32
Mark1960
The number of boards needs to be reduced from 10 to 5 to get the special pricing.
Mark1960 is offline
Old 23rd Jan 2022, 4:04 pm   #33
Phil__G
Personally I think the actual manufacturing cost is very cheap, most of the overall cost of the order is carriage!
Old 23rd Jan 2022, 4:23 pm   #34
Michael - K8LH
Thank you for checking, Phil. It's nice to know I don't have to reduce the PCB size on one of my board designs in order for UK users to get JLC 'special' pricing.
Would you be willing to discuss PICLV2 hardware and code modifications (publicly or privately)? I've got several ideas but I can't really test them out until my PCB order arrives in a couple weeks.
In a nutshell... I'd like to test using a 2-pin Red/Green LED and current limiting resistor directly across the Rx and Tx pins as the Serial I/O indicator. Then I'd like to tie the RAM /CS1 pin to ground and control the RAM just with the /OE and /WE pins. Those changes will free up two pins which could be used to address a 32K RAM. Also, since the new PIC I'm using has 32K (words) of flash memory compared to 8K on the '877 or '877A, I'd like to include your KitBugPlus (KB+) Monitor in flash and load it into RAM at startup. Of course the extra RAM (and PIC flash memory) might provide the opportunity for a "PAGE2.SYS" machine implementation, or used to 'save' and 'load' 4K "pages" to/from flash memory. Finally, I've got simpler Serial routines (see below) and a fixed delay subsystem that supports easily changing the serial baud rate with almost any PIC clock frequency.
Please don't be afraid to say "****** off". I understand not everyone has time, patience, or interest in such things.
Cheerful regards, Mike
Code:
;  Serial input. Character returned in ACC, EXT, and WREG.        ~
RXX
        call    getSer          ;                                 |00
        HOME    EXEC            ;                                 |00
; Character returned in ACC, EXT, and WREG. DelayCy() uses TMP.
getSer                          ; 9600 baud timing (0.16% error)
        btfsc   PORTE,SERIN     ; start bit (0)? yes, skip, else  |00
        goto    getSer          ; loop (wait for start bit)       |00
        bsf     PORTE,SERLED    ; activity LED 'on'               |00
        DelayCy(104*usecs/2)    ; delay 1/2 bit time              |00
        movlw   9               ; 8 data bits + 1 stop bit        |00
        movwf   ACC             ; bit counter                     |00
getBit
        DelayCy(104*usecs-7)    ; 104 usecs -7 cycle loop         |00
        clrc                    ; assume '0'                  (1) |00
        btfsc   PORTE,SERIN     ; a '0' bit? yes, skip, else  (1) |00
        setc                    ; set to '1'                  (1) |00
        rrf     EXT,F           ; b0 first, b7 last           (1) |00
        decfsz  ACC,F           ; done? yes, skip, else    (2)(1) |00
        goto    getBit          ; get another bit           ~ (2) |00
        rlf     EXT,F           ; shift stop bit out              |00
        bcf     EXT,7           ; clear bit 7 for NIBL            |00
        movf    EXT,W           ; copy RX char to ACC             |00
        movwf   ACC             ;  "                              |00
        bcf     PORTE,SERLED    ; activity LED 'off'              |00
        return                  ;                                 |00
;  Serial Output. Tx character in ACC. Uses EXT & TMP.            ~
TXX                             ; 9600 baud timing (0.16% error)
        movlw   10              ; 1 start + 8 data + 1 stop bit   |00
        movwf   EXT             ; setup bit counter               |00
        clrc                    ; C = 0 (start bit)               |00
        goto    TxBit           ; send start bit                  |00
TxLoop
        DelayCy(104*usecs-10)   ; 104 usecs -10 cycle loop        |00
        setc                    ; always shift in a 'stop' bit    |00
        rrf     ACC,F           ; put data bit in Carry           |00
TxBit
        movf    PORTE,W         ; read port                       |00
        iorlw   1<<SEROUT       ; set TxPin to '1'                |00
        skpc                    ; if data bit = 1 skip, else      |00
        xorlw   1<<SEROUT       ; set TxPin to '0'                |00
        movwf   PORTE           ; precise bit timing intervals    |00
        decfsz  EXT,F           ; all 10 bits? yes, skip, else    |00
        goto    TxLoop          ; send next bit                   |00
        HOME    EXEC            ;                                 |00
Old 23rd Jan 2022, 7:10 pm   #35
Mark1960
I agree, I don’t know how they can make pcbs at those prices. I think they must be using the waste areas of larger panels, or its just a loss leader, maybe both.
I usually group a few designs together to save shipping costs and try to avoid DHL as they keep adding customs handling charges even on orders below the tax threshold. First design is $2 usd for 5 and I think $4 for 5 for additional designs so I tend to make the first item an experimental 5 and then 10 for additional designs. One thing to watch for is that the weight of the order can increase shipping charges when grouping boards in an order.
Mark1960 is offline
Old 23rd Jan 2022, 7:52 pm   #36
Phil__G
Hi Mike, as I've always said, if its ok with Karens pals its fine by me, my own approach as a relative newcomer here was one of caution so I tried to do it with minimal changes to Karens work, but its since become clear that everyone seems to approve, so go for it!
Another address line or two would be great, then with 32k, page2.sys would probably be the favourite, although since Kitbug+ and Page2.sys are quite separate, theres no reason not to have both!
Its possible someone might not want the complexity of page2, or need page 2 for some other power-on auto-run application, in which case KB+ would handle M/C stuff.
KB+ was deliberately kept small, with 32k it could be expanded into a full-blown monitor - but then we're back to Page2.sys!
Re the red/green - directly connected, I'm not sure - my CH340G datasheet only says that VOH & VOL are in spec at 3mA so i dont know what you could actually draw from the CH340G on the PICL receive line. Unless you mean via drivers?
TBH a PICL transmit LED alone is fine - if theres traffic its lit, if not, there isnt
Beware of losing the NIBL 'keyboard interrupt' if tightening or speeding-up the serial routines!
Phil
Old 23rd Jan 2022, 10:22 pm   #37
Slothie
They aggregate several boards from many customers onto one panel. That's why if you select anything but the default choices it can dramatically increase the cost. It's only recently that the colours other than green have been "free", presumably because volumes have gone up so much.
Slothie is offline
Old 23rd Jan 2022, 11:17 pm   #38
Mark1960
Hi Mike,
if you want to increase the address range you proably want to move /OE and /WE so the higher address lines can be written to the port in a single operation instead of adding extra bit manipulation that might break the cycle timing.
It could be possible to use only /WE, and ground both /OE and /CS, though the timing might be awkward. Most bytewide ram the /WE will override /OE. You would need to set up the write address while still in read mode with data bus as inputs to pic. Activate /WE, then set data bus to output data, deactivate /WE and as soon as possible change data bus back to inputs to pic. There is a risk of output contention between pic and ram, so might be chancing damage to one or both.
Mark
Mark1960 is offline
Old 24th Jan 2022, 3:42 am   #39
Michael - K8LH
Yes, exactly. You would want to use RD5 and RD6 as address lines and assign the RAM /OE and /WE lines to other port pins.
I thought about that, too, Mark. It's not impossible to mitigate the contention problem. I also thought about combining the /CS1 and /OE line. However, I'm concerned that some unknown nvRAM chips might act like a 28C256 where the /OE and /WE signals must be mutually exclusive.
I hope to test several different possibilities once I have boards.
I also spent some time today playing with a new compact (2.1"x3.0") PCB layout, just for fun. If I load RAM with Phil's KB+ Monitor, or any other software, from PIC flash memory during startup I can eliminate the expensive nvRAM chip and use a skinny RAM chip installed under the PIC. Anyway, it's just an idea...
More later... Stay safe. Mike
Name:	Pocket PICL R2.jpg
ID:	250374   Click image for larger version
Name:	Pocket PICL R2 Traces.jpg
Old 24th Jan 2022, 9:21 am   #40
Mark1960
I think I’ve seen a few projects stacking skinny ram under a 40 pin processor, but not sure I would want to solder the ram, or double stack the 40 pin socket to allow the ram to be in a socket too.
It might be nice to pick a low cost case and design the board to fit the case. I was thinking maybe a 2.5 inch portable disk case but they aren’t really deep enough. I did get a couple of extruded aluminium cases and plan to use those for an INS8060 NIBL project, possibly using a pcb panel to mount switches and leds.
Mark1960 is offline
