Old 27th Nov 2021, 11:49 am   #1
DonaldStott
DonaldStott's Avatar
Default Bush DAC90A bulbs
From time to time it seems to be the case that the 3.5V 0.15A bulbs for the DAC90A are impossible to find?
Managed to blow both bulbs after accidentally shorting two valve pins!
I have substituted some 6V 0.15A bulbs meantime?
Anyone found a current source for these (pardon the pun)?
BVWS Member
DonaldStott is offline   Reply With Quote
Old 27th Nov 2021, 6:58 pm   #2
Ed_Dinning
Default Re: Bush DAC90A bulbs
Hi Donald, I previously used some RS led bulbs, 6v rated and wired in parallel as the take a low current. Purists may not like these as the have too "white" a glow, but work well.
The auto transformer I designed for these sets will power either a series pair of the 3,5v bulbs or a parallel pair of 6.3v 50mA lamps. These are fed from the 6.3v tap on the transformer and are much better voltage stabilised than in the series heater chain configuration. The bypass resistor is then removed
Ed
Old 28th Nov 2021, 6:35 pm   #3
yestertech
yestertech's Avatar
I still have some of these from a batch I had made some years back
PM me if you're still in need.
Andy
yestertech is offline   Reply With Quote
Old 29th Nov 2021, 4:48 pm   #4
agardiner
agardiner's Avatar
Andy, at risk of you being flooded with requests, do you have many? I could certainly use some if available. Was going to resort to the 6V parallel method.
agardiner is offline   Reply With Quote
Old 29th Nov 2021, 5:04 pm   #5
DonaldStott
Thanks Andy - PM sent.
Still looking, but meantime:-
3.5V 0.2A vs 6V 0.15A
Discuss in the context of the Scale lamps shunt value?
BVWS Member
Old 29th Nov 2021, 7:30 pm   #6
electrogram
I use 6v - or are they 6.5v - 100ma in series , with a 180 ohm shunt
electrogram is offline   Reply With Quote
Old 29th Nov 2021, 8:29 pm   #7
Ian - G4JQT
Ian - G4JQT's Avatar
I've not tried it - or bothered to check the maths - but didn't someone recently say they just re-wired the DAC90A bulb holders for 6.3V 150 mA in parallel? It seems too easy a solution I must admit!
Ian
Ian - G4JQT is offline   Reply With Quote
Old 30th Nov 2021, 5:12 pm   #8
yestertech
yestertech's Avatar
PM sent
A.
Old 7th Dec 2021, 6:36 am   #9
AD360 Rob
AD360 Rob's Avatar
Ian
I think that was me Ian, someone else had wired the lampholders in paralell which caught me out when I replaced the lamps with the correct 3.5v 150mA ones. I put it back to standard.
Rob
AD360 Rob is offline   Reply With Quote
