17th Oct 2017, 10:58 am | #221 |
Re: Audiophoolery. 'Cable Break In' - I never knew that!
Dohh.. Peter Walker! (Richard walker was the great angler!)
17th Oct 2017, 11:04 am | #222 | |
No Longer a Member
I was referring to the case where an Engineer becomes involved in remarks and audiophoolery claims of things like sonic performance, that they know for sure have no basis in science and are not true, but they are still prepared to push those for advantage. |
17th Oct 2017, 11:36 am | #223 | |
Cheers, GJ
http://www.ampregen.com |
17th Oct 2017, 12:02 pm | #224 |
For example he said that all good amplifiers sound the same. He later went on to contradict and/or qualify that statement: Last page, top of second column:
http://www.quadrevisie.eu/quadinfo/pdf/a24.pdf
17th Oct 2017, 12:05 pm | #225 | |
Cheers, GJ
17th Oct 2017, 12:21 pm | #226 | |
He says that "if you took ten modern amplifiers, set the levels correctly and avoided overload, about five of them would sound the same, the other five wouldn't". That's modern amplifiers, not good amplifiers. Later on Walker agrees with Atkinson when Atkinson says "I'm starting to suspect that perhaps there aren't many good amplifiers around." Walker set a very high standard for 'good'. But just to be clear, which is the bit which is outrageous, stupid and factually wrong ? None of it sounds like any of those things to me, I'm afraid. Cheers, GJ
17th Oct 2017, 12:36 pm | #227 | |
17th Oct 2017, 1:01 pm | #228 | |
Yes I think it's wrong. If there is mutual benefit, then the advice and the sale can still be offered, providing it is qualified: "Look, nobody quite know why, and I can hardly tell any difference myself - but lots of people find that using direction-oriented speaker cables results in a noticeable improvement after 20 hours of running-in. That's why I sell the cable." I do occasionally have an open mind myself to things which science can't explain yet - I bought a set of magnetic leg wraps for my chronically lame horse some years ago. No reason why they would work, and whether they made her any more comfortable, only she knows, but for £60 I was less concerned about why they would make a difference as to doing anything possible to help her. (When I told vet, he said, "Well if it makes you feel better using them, Peter, then use them!" Which is perfectly fair.) |
17th Oct 2017, 1:04 pm | #229 |
Never mind the earth screening, the important thing with all this stuff is that it's folks feet that should be connected to earth
Lawrence. |
17th Oct 2017, 1:36 pm | #230 |
No Longer a Member
Re: 'Cable Break In' - I never knew that!
This has to be one of the most impressive posts on this entire thread. joebog1 could have sold his white jacketed OC81's to audiophiles for 40 GBP along with colorful descriptions of how they amplify audio, but he knows they are not worth nearly that, so he offers them for free. Now there is a Engineer who inspires honor, dignity & trust.
17th Oct 2017, 1:44 pm | #231 | |
*ground, could be chassis, common, 0V, reference or loads of other things. |
17th Oct 2017, 2:16 pm | #232 | |
But with balanced cable, the guiding principle is to connect the shield directly to the chassis at each end, enshrined in an AES standard and championed by Neil Muncey in 1994. Having said that, there is a more recent alternative view which connects only the signal source end of the cable shield in balanced systems (see for example Linear Audio, V10, pp25-36). Ott, as previously mentioned, gave an excellent presentation given to the AES in 2008 covering both balanced and unbalanced cabling, hum, noise, RF susceptibility etc etc. http://www.audiosystemsgroup.com/AES-RFI-SF08.pdf Of course we have strayed off the topic of cable burn-in. Now some years ago I was keeping an open mind about this, and bought a kit of bits from Hagermann in the US for not a great amount, and built it into a box. I've done AB testing of identical cables of various constructions (BNC-BNC for SPDIF, balanced and unbalanced signal cable and speaker cables). I am happy to report that I could discern absolutely no difference whatever between burnt in and virgin cables. The burn in device collects dust. |
17th Oct 2017, 4:42 pm | #233 | |
[QUOTE=kalee20;983481]
The only fly in the ointment is me, standing a little distance off, listening, wearing my Dr Evil hat, and wondering "In what way was that directional cable made directional?" David
17th Oct 2017, 7:05 pm | #234 |
The misleading bit, well a total lie, is that the cable has directional properties at all, apart from the arrow on it. OK at RF a tapered line is directional, audio?, untapered?, unmatched?, you are having a laugh.
17th Oct 2017, 7:52 pm | #235 |
and whether it's possible to get an un-rectifier to go with it so that it works with ac. Or is there such a thing as directional ac?
Stuart The golden age is always yesterday - Asa Briggs |
17th Oct 2017, 8:44 pm | #236 | |
As this thread goes on and on the "explanations" of audio foolery get flakier and flakier. I am enjoying it, so are the engineering department at work. We had a competition for the most ludicrous hifi gadget, that got silly, now it is for the most expensive bit of wire, so far it is $5000 for a one metre phono to phono cable, stereo mind you. |
17th Oct 2017, 9:11 pm | #237 |
17th Oct 2017, 9:18 pm | #238 |
yesanby, I have been trumped! Must be worth more as it has be broken in, the fools.
17th Oct 2017, 9:22 pm | #239 |
I suppose defying the laws of physics requires something quite expensive. It's not clear what "exceeds all expectations" means. If I expect it to be cr*p then would it be total cr*p or just a bit better than cr*p?
17th Oct 2017, 11:20 pm | #240 | ||
No Longer a Member
[QUOTE=Radio Wrangler;983525]
