3rd Feb 2023, 11:24 am | #1 |
Winthrop President
Hello.
This is my first time posting and hope it is okay to ask about a music centre that may not have been built in the UK - a Winthrop President music centre. I have attached a photo, this is not my music centre but is the same model. The music centre works great apart from the turntable - it feels as thought it is completely seized - no give or wobble in it at all. Would anyone have any ideas how to fix it? Apologies if I am in the wrong place. We acquired the music centre yesterday and my 17 year old loves it and would really like to be able to play his LPs on it. Any suggestions would be gratefully received Many thanks, K. |
3rd Feb 2023, 2:12 pm | #2 |
Re: Winthrop President
It's an early 1970's BSR C Series deck. If you mean it will not turn. Service Sheets are available from this site once we have pinned down the model number. If you mean you can't lift the platter (turntable) off, then advise us. What skills so you have with these? It should be an easy fix if you are familiar with these.
Edward. |
3rd Feb 2023, 10:22 pm | #3 |
This turntables are usually gummed up by old solidified grease, so I suggest this. Take the aluminium disc out of the centre (it is held in either by three small lugs that slip under the surrounding rubber, or it may be simply glued on, so take care, or you will damage the very thin disc). Then slide off the "C" clip that holds the turntable on. Pull out the centre spindle, but if it is stuck, leave it, it will come free after the next step. Now you need to apply heat to the centre of the turntable. If you have a hair drier, that is ideal. Hold the drier next to the centre of the turntable for a minute or so, then try to turn the turntable, but if it is reluctant to turn don't force it, or you will cause considerable damage to the mechanism, but apply more heat and after a few attempts, you should be able to pull the spindle out, and lift the turntable off. If this is successful, clean the hole in the turntable and the centre shaft it sat on with alcohol or WD40, apply fresh sewing machine or hair clipper oil to both (NOT WD40!), replace the turntable, "C" clip and aluminium disc, and hopefully this will have cured the problem, but if not get back to us.
Barry Last edited by Audio1950; 3rd Feb 2023 at 10:29 pm. |
3rd Feb 2023, 11:01 pm | #4 |
I usually find that the whole deck is gummed up, including the arm bearings, cam (the large gear), the speed change, the on/off/auto mechanism and possibly the motor.
4th Feb 2023, 2:44 am | #5 |
Tesco stores sold this Winthrop music centre in the 1970s. I haven't seen one for many years. Unusually it has both cassette and 8-track tape systems. The turntable was made in England by Birmingham Sound Reproducers (BSR). The same turntable unit was fitted to many different stereo systems, not just Winthrop, so if you need spare parts or even a complete replacement unit, it shouldn't be too hard to find another one.
It will need dismantling, cleaning and relubricating, as described above by Audio1950. A tip : I've found liquid cigarette lighter fuel (not gas) helps to dissolve the sticky grease. You can then wipe it off with paper kitchen towel before re-oiling. Be aware things can get messy. Lighter fluid is highly flammable - ventilate the area. |
4th Feb 2023, 3:20 am | #6 |
That unit looks very familiar - and the name too. I think I remember having one in for repair decades ago.
Everything suggested regarding how to go about the service/repair of the record deck is correct. I would just reinforce the bit about NOT forcing the turntable round until it's completely free to turn and be lifted off by the application of heat to the centre bearing as described. I think this is the deck that has a particularly weak arrangement whereby the turntable main bearing unit is a press fit into the deck plate and forcing the turntable to turn when it's tight causes the whole bearing to rotate and come adrift from the deck plate. If this happens then it's game over for the entire record deck. There's various methods of trying to bodge it back in again, but it's best not to bust it in the first place. |
4th Feb 2023, 10:52 am | #7 |
4th Feb 2023, 11:25 am | #8 |
Chaps, what is the dial thing bottom left on the BSR deck? looks like it's one of the dustbug pivots, but a funny place for it to be
Regards Joe "Hayer Joe, where ya going with that deck in your hand?" - Jimi Hendrix Experience |
4th Feb 2023, 12:12 pm | #9 |
It certainly looks like a "Dustbug" pivot. The more obvious location at the rear looks like there is a transit screw head(?) in the way.
If nothing it suggests a careful previous owner, as might the single play only spindle fitted.
5th Feb 2023, 11:29 pm | #10 |
Deck is a BSR C141R. This looks a nice unit.
Regards, Ben. |
