31st Jan 2023, 12:00 pm | #1 |
Teac x-7r
Morning all, my above player has not been used for some time, sat on my shelf in the front room warm and dry.
Went to use it, not playing the tapes, it seems that tape heads not in contact with the tape, heads not dropping down when play selected. Before i attempt to dismantle it, is there anybody here that has experience of this and the repair. As always any and all help appreciated from the members Snowy |
31st Jan 2023, 2:46 pm | #2 |
Re: Teac x-7r
I don't know this machine, but I can tell you for a fact that a classic issue with Japanese tape machines of this era is dried up grease. It can sieze up assemblies like glue. My advice would be to power it down and go through each moving part in turn, checking that it moves up / down / around freely. If something is seized due to dried grease, it won't do it any good if it's powered, as it'll stress driver circuits / solenoids etc.
edit - there are likely many areas you'll have to look into, not just grease. But if the machine hasn't been stripped / degreased / regreased before, it'll likely need it! |
31st Jan 2023, 5:18 pm | #3 |
Re: Teac x-7r
Indeed it sounds as if the pinch roller carriage has gummed up. You may need to apply heat or IPA to the junction of the sliding plates to free them, then strip and relubricate with something like Superlube. It's not unduly difficult, but laborious.
31st Jan 2023, 6:18 pm | #4 |
Re: Teac x-7r
Thanks gents, one of the reasons i purchased this particular item was that the old grease had been removed and replaced with a modern equiv.
i have had it approx 6 or 7 years, i have also purchased a replacement rewind motor as towards the end of the process it requires assistance some 3 years ago. got a new puppy so my time is in demand by her at the moment. regards |
31st Jan 2023, 6:54 pm | #5 |
Re: Teac x-7r
I think this deck has the same mechanism as one of my TEAC's if so the heads and pinch wheel are brought into contact with the tape by a motor via a drive belt, in mine the belt had broken.
Graham |
31st Jan 2023, 7:00 pm | #6 | ||
Re: Teac x-7r
I have stripped and re-greased a number of TEAC X-decks in the past that have then stuck again after a few years disuse. In fact, there's one right here, awaiting that very same treatment. As you are returning a machine to service you might be considering changing the belt, given that the deck is rather finicky about belt condition. The original part is still available from TEAC but only in the USA, which won't ship direct to UK buyers. I believe the P/N is 5534692001 but check first. Beware replica belts; some will work OK for a while but then won't shift during reverse, others are too tight and stress the rather lightweight motor. Some I bought a few years ago from a reputable tape spares supplier soon turned to goo (before I realised that TEAC USA still stocked the OEM belt.) Be careful not to mix up left and right hand parts and note the spacer under one screw for angling the capstan motor if you disturb it. Last edited by Lucien Nunes; 31st Jan 2023 at 7:10 pm. |
31st Jan 2023, 11:31 pm | #7 |
Re: Teac x-7r
ISTR that after disassembly and cleaning there are three metal parts at each pinch roller whose holes need to be lined up precisely to allow a pin to slide through them. It can be a little tricky.
It's a more complicated mechanism than older A series Teac machines, although they too suffered from dried out grease in the pinch roller mechanism. |
1st Feb 2023, 9:07 am | #8 |
Re: Teac x-7r
Thanks Tim, i might yet take it get it done 'professionally', too good a machine for me to make a mess of, got the mini 'dachs' taking up my waking and sleeping hours at the moment tho'.
