Old 31st Jan 2023, 5:06 am   #1
trobbins
trobbins's Avatar
Default Thurlby 1503 4+ digit DMM repair
Recently picked up a faulty Thurlby 1503 DMM that showed signs of working. As the user and the service manuals were on-line, and this is nearly a 5-digit DMM (from the start of the 1980's), I continued on....
The display and voltage rails were ok, and the voltage presented to the ADC section was being displayed accurately, and the Caddock input divider hybrids and selector switches all appeared ok. The issue was with the input stage signal processing, which used a rather special op-amp (ICL7614CPA) with extremely low pA level bias current and offset, and of course that opamp was the problem. Luckily the IC was in its own header, and I had a small batch of LH0042C that came within cooee of the ICL7614A specs. That recovered the analog input functions, although there was now some zero-input offset that the inherent zero offset trim couldn't zero out.
I swapped around some LH0042C to see if there was much change, and also added an offset trimmer to the LH0042C, and cleaned the pcb in that region, but alas no significant change to the zero offset. I couldn't easily identify if there was a further degraded part, so decided to brute-force the zero offset range. Zero offset adjust was based on applying a clocked squarewave voltage through a 2.2pF cap in to the ADC input, so I paralleled that with 33pF. That recovered the zero-offset function, although it changed a bit now and then, but allowed calibration of the ranges back to nominal 4.75 digit performance to within the last digit. It runs off a 12Vdc plugpack, or internal battery, so should come in handy.
Ciao, Tim
Name:	Thurlby 1503 front.jpg
ID:	272458   Click image for larger version
trobbins is offline
Old 31st Jan 2023, 11:24 am   #2
G6fylneil
Default Re: Thurlby 1503 4+ digit DMM repair
I've got one of those, I replaced the jack socket on the front when it's contacts became unreliable and the signal wasn't getting through to the display. I think this and its successors were successful because of the stability of the US made input dividers.
G6fylneil is offline
Old 31st Jan 2023, 1:18 pm   #3
Andrewausfa
Andrewausfa's Avatar
I have one too. I resuscitated mine with a new battery holder as the battery cells had leaked all over it at some stage in its life, luckily no board damage. Went to use it three (IIRC) weeks later and the brand new batteries had leaked ruining the new holder. Quite strange.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
