27th Dec 2022, 6:41 pm | #101 |
Re: Quick question on the CODAR AT5, if anyone has one to hand.
Here's my first AM rig, Topband only. I built it in 1980, during my lunch breaks in the workshop at British Gas. The VFO is a 6C4 running at half frequency.
I used to power it from the power supply I'd kept from a dismantled Rigonda Symphony radiogram. The modulator uses a QQV03-10 in push pull. The modulation transformer is a HT transformer. It used to get me all round Europe on CW ( when I was keen ) Hasn't been powered up for about 20 years. Don't all laugh at once! Cheers Aub
27th Dec 2022, 7:01 pm | #102 |
Very nice Aub. I wish I had facilities of bending metal better than just in a vice!
Here's my 60 metre copy of an AT5 for the AM channel on 5317 kHz: |
27th Dec 2022, 8:13 pm | #103 |
That's very good Ian. Looks like the AT5 power supply next to it. I must make something for 60.
73 Aub
27th Dec 2022, 8:46 pm | #104 |
A Nice couple of rig's there guys
"Behind every crowd, there's a silver Moonshine" |
6th Jan 2023, 10:13 pm | #105 |
There's another one of my old favourites in here:-
https://worldradiohistory.com/UK/Pra...PW-1966-11.pdf Good old F.G. Rayer. He must have had a shed full of 160 and 80 AM rigs This one has a beefier modulator. Cheers all Aub
7th Jan 2023, 4:37 am | #106 |
Is that modulator a bit OTT? I've just mailed Ian re the bean can circuit. My recollection is that a pair of EL90's quite easily provided "full" modulation for the 03-10 and would probably do the same for a 5763 or 6BWB PA .
B
7th Jan 2023, 9:49 am | #107 | |
7th Jan 2023, 9:55 am | #108 |
Yes, the EL90s should be more than enough for the QQV03-10 or the other valves. I suppose that modulator was a bit OTT but it's nice to have some grunt in reserve.
All the best Aub
7th Jan 2023, 10:03 am | #109 | ||
Cheers Aub
7th Jan 2023, 10:12 am | #110 |
Ed wound me a mains transformer for use as a modulation transformer.
I've sourced the 100 pF variable cap for the VFO. It's the 140pF 600V "Eddystone" variable cap I'm having problems finding. I doubt I'll be able to build it on the small chassis Rayer specified. I try things first before bending up the chassis. Probably best if I start a new thread on this rather than take this one off topic.
7th Jan 2023, 10:47 am | #111 | |
B
7th Jan 2023, 11:08 am | #112 |
Re: Questions on 160/80 metre AM transmitters.
When I first thought about this project I just built a mod section using parts from an old TR1998/STR9X a VHF Aircraft TX/RXThat was driving a TT15 Valve for output, as in this circuit.
That uses two EC90's as output and driven by a EL90. HT 250 Volts and -11 Volts on the grids of the EC90's Unfortunately the transformer labelled 2T2 was open circuit, the wires had corroded, but the output transformer 2T3 with thicker wire was still OK. I thought I could still use the idea driving the two EC90's with an ECC83 in a phase splitter circuit and an EF91 pre-amp, basically like the typical Mullard audio amp circuit, but there must be something particular with the transformer driver as I could not get the required swing. This was my circuit. I note once again that the November 1966 PW posted by Aub, again uses a driver transformer, so I am guessing that it must take the grids positive and as such drive the outputs harder sinking more current through the output transformer and bigger swings etc. I would appreciate knowing if that is correct. Also I am quite happy if others post ideas, projects within this thread as I am finding lots of interesting comments on low HF transmitters, perhaps there could be other stations to talk to if enough get built, dug out of cupboards etc. Perhaps change the main Title to something suitable such as Questions on 160/80m transmitters ? Adrian |
7th Jan 2023, 11:16 am | #113 |
Thread title changed at OP's request.
Should we restrict this to valved transmitters?
7th Jan 2023, 11:31 am | #114 |
I am not too bothered, I guess we can keep this one valve, I know there were also Transistor circuits coming out in the 60's, so perhaps someone could start a transistor one if required.
Then there is still the Home made section for people's builds. Adrian |
7th Jan 2023, 4:22 pm | #115 |
Thinking about modulators again. In the Topband transmitter that I posted the pictures of in this thread, I used a push-pull modulator as the single EL84 I'd been using when I first built it, didn't seem to produce enough audio. Over the years, I've wondered if the insufficient mod was more due to core saturation of the half wave mains transformer I was using as a mod transformer, rather than the power itself. I changed the circuit to push pull, using a 250-0-250 mains transformer with a QQV03-10 deployed for audio use. This worked very well. I suppose the issue of core saturation went away due to being push-pull.
Aub
7th Jan 2023, 4:37 pm | #116 |
I guess if the magnetisations from the currents for the single EL84 and the PA valve flowing through the modulation transformer were additive it could have caused core saturation.
Reversing the phase of one winding would have the magnetisations cancel each other out and so reduce the risk of saturation. That's the cunning thing about the Codar-type autotransformer approach, which allows the use of a seemingly-very-small transformer.
7th Jan 2023, 4:52 pm | #117 | |
He certainly did! After his death a quantity of his sets were acquired by my old friend Howard Turner(RIP) of Centre Electronics Birmingham, and within a day or so of the purchase an irate relative called at the shop and said they should not have been sold and demanded their return. They were all returned except I believe for 1 set which had already been sold on. I wonder where they all are now? Kind regards Dave |
7th Jan 2023, 6:46 pm | #118 |
Hi All,
Since the thread has run onto Top Band/80m TXs other than the AT5, I have attached some pix of a very nice TX I used to own. It came from the estate of G3NHU but was built by G3HRK and used mobile with a Command set RX. The mechanical construction was first-rate, the set ran a 6AQ5 PA, modulated by a pair of the same and used an ex-SCR522 mod transformer and several other ex-military components. I passed it on to a VMARS member a couple of years ago. Belated HNY to all. 73 Roger/G3VKM |
7th Jan 2023, 6:46 pm | #119 |
Very interesting. Yes, where are they now? He also did designs for 4 metre and 2 metre AM rigs. I've got a 2 metre one somewhere, but I won't post it in this thread 😄
Aub
7th Jan 2023, 7:52 pm | #120 | |
Aub
