16th Dec 2022, 9:55 pm | #1 |
Questions on 160/80 metre AM transmitters.
I have the circuit here for the AT5, but I am confused over the circuit around V1 the VFO
For the EF80 as shown, I can see that g2 (pin 8) is connected with R2 and C3 g1 (pin 2) is connected to R1, C2 and L1.Anode (Pin 7) connected to R3 and C6.. But the squiggle that shows where C4 and C5 go is unclear. I am guessing that these are connected to pin 8 the g2, so effectively connected to R2 and C3. Also that g3 is ls strapped to the cathode. Can anyone verify this is correct, or what things should be connected to. Lastly am I correct in thinking that the oscillator is running with the g2 as the anode as it were and that the true anode is giving a buffered output to V2, not sure what this modified Vackar VFO is? Adrian Last edited by AdrianH; 16th Dec 2022 at 10:03 pm. |
16th Dec 2022, 10:30 pm | #2 |
Re: Quick question on the CODAR AT5, if anyone has one to hand.
There is a photo of the underside of the AT5 chassis on the G4AQB website.
https://g4aqb.files.wordpress.com/20...g?w=1024&h=768 That photo seems to confirm that your understanding is correct. I think V1 is configured as an electron coupled Vackar. Exactly what the modified bit is, I don't know. The G3PDM receiver used a Vackar circuit with what was described as the original capacitance ratios. This circuit is doesn't use the same ratios, so that could be the modification. I'm sure that someone on the forum will have a more definitive answer. Paula |
16th Dec 2022, 10:38 pm | #3 |
Thanks I will have a look.
Adrian. |
16th Dec 2022, 11:28 pm | #4 |
Hi a better circuit checked with my at5 Mick
16th Dec 2022, 11:57 pm | #5 |
Thanks Mick, that is a lot better circuit.
Adrian |
17th Dec 2022, 6:47 am | #6 |
Electron-coupled amplifier stage (sometimes called 'transitron'). Notice that neither the anode nor the cathode are coupled into the tuned circuit. The tuned circuit is a pi-section which could be as per Vackar, depending on value ratios.
It's quite a neat circuit, getting a degree of isolation to the output more than a non-transitron circuit would give. The amateur radio world gets a lot too fixated on applying names to oscillator circuits. It's better to look at them and visualise their operation. Also, ask yourself about the usual elephant in the room; what controls the amplitude? David
17th Dec 2022, 8:39 am | #7 |
17th Dec 2022, 11:18 am | #8 | |
The full text relating to the 47k resistor mod:
17th Dec 2022, 12:21 pm | #9 |
If someone can let me know which Short wave mag date it is I will try to find it.
The project is going very slow mainly due to other things I have on order that seem to be taking weeks for RM to deliver. Adrian |
17th Dec 2022, 12:54 pm | #10 |
Please let's not turn this thread into a discussion about strikes at Royal Mail.
17th Dec 2022, 1:16 pm | #11 |
Test report, schematic etc, Codar AT-5, Short Wave Mag. August 1965:
http://www.g4kfk.co.uk/Codar_AT-5_Tr...SWM_196508.pdf Plus some mod's: http://www.g4kfk.co.uk/Codar_AT-5_Mo...s_by_G3UUR.pdf Lawrence. Last edited by ms660; 17th Dec 2022 at 1:27 pm. Reason: link added |
17th Dec 2022, 1:44 pm | #12 |
17th Dec 2022, 4:03 pm | #13 |
Sorry for mentioning RM, I will consider my knuckles rapped.
Thanks for the links to the magazine and articles. Adrian |
17th Dec 2022, 5:29 pm | #14 |
In the 1965 SWM review on page 337, there's a comment that on 80m, the 12W from the AT5 invariably got through OK on contacts which had been kicked off with a 100W Tx, which is telling!
How critical would the matching be of the centre-tapped winding on the transformer used for the modulator? I'm wondering about whether the transformer from a Pye Ranger could be used, using the centre tapped winding originally used by the push-pull EL90's in the Ranger modulator ? B
Saturn V had 6 million pounds of fuel. It would take thirty thousand strong men to lift it an inch. Last edited by Bazz4CQJ; 17th Dec 2022 at 5:37 pm. |
17th Dec 2022, 6:03 pm | #15 |
The matching is 'good enough' with pretty much any 1:1 audio transformer. It assumes that the average DC current through the PA is something close to the average DC in the 6BW6 audio-output stage - get around 45mA flowing in them both and the matching is good-enough, and the magnetic fields from the static DC component balance-out in the transformer same as they would in a push-pull audio amp.
Remember we're not talking hi-fi here! In times-past I did something very similar with a transmitter using an AUY10 as the RF amp and a NKT404 as the audio amp. Coupled together using a 12-0-12V winding on a little power-transformer, with a neon across the 240V primary to indicate modulation. Yes - Germanium PA stage and class-A modulator! Both nice TO3 cased transistors, whole thing put out about 10W for 3A current draw from a 12V battery. [will remain quiet about the frequency...]
17th Dec 2022, 6:54 pm | #16 |
Thanks for that. Somewhere I have three of those oil-filled "bean-can transformers" from early Rangers. They are physically a bit bigger than the small transformer in the original AT5, but seems like they might be OK for a home-brew version. There's a third winding on them, which I think was intended to provide feedback in to the AF pre-amp to provide level-control? I've never seen the circuit for them.
B
17th Dec 2022, 10:18 pm | #17 |
Bazz, I don't think they were oil filled. Just potted, maybe resin or just shellac coated windings inside the can. A bit like the W30AM ht inverter transformer in a half "coke can" size.
You are correct, the third winding was used for feedback to the af compressor circuit. Rob
17th Dec 2022, 11:58 pm | #18 | |
I can't remember where I found this, but I have a note in one of the pdf's re the modulation transformer:
18th Dec 2022, 12:46 am | #19 |
Re the Ranger transformer, interesting. I think I have one of the half-coke size transformers too, don't think I knew it was an inverter transformer.
Seems though the original transformer was a slightly unusual component(?), but it did not make any special contribution.
20th Dec 2022, 7:36 pm | #20 |
Another question on the AT5,
Looking at the circuit at the coil and cap on the output of the second EF80, described as doubler for the the 3.5 MHz band. I have always thought of a coil and capacitor in series as a rejector circuit, in that it would appear as low impedance at it's resonant frequency, in which case if it was tuned at 3.5 MHz it would shunt output to ground, not double it, so wondering if the coil and cap is broadly tuned for 1.9 MHz, or have I got it wrong again? Adrian |
