8th Dec 2022, 2:50 pm | #101 | |
Re: How do I convert hex files to binary for use in the MK14 mame VDU emulator?
8th Dec 2022, 3:12 pm | #102 |
Won't execute or won't start? You have to press 'Go' again to start the game running.
9th Dec 2022, 3:48 am | #103 |
9th Dec 2022, 9:24 am | #104 |
That's for the MAME guys to answer I think? Which keys on the PC represent the MK14 Go, Mem, Term, and Abort keys during MK14 run time?
9th Dec 2022, 11:18 am | #105 |
Most likely to be G, but there are not that many other keys to try on a pc keyboard so long as the wrong key doesn’t make it crash out.
9th Dec 2022, 11:29 am | #106 |
Big thank you to the mods
To avoid any future confusion over bad attachments I asked the mods to remove the bad ones from the earlier posts, and replace each with a pointer to the corrected file - which they've done, all attachments in this thread should now be 'good' Thank you mods Phil Last edited by Phil__G; 9th Dec 2022 at 11:45 am. |
9th Dec 2022, 1:41 pm | #107 | |
As there is no physical reset switch to press, I would also expect that pressing 'R' would be equivalent to pressing the reset button. Edit: well done to Phil and the mods for shorting out the wheat from the chaff. |
9th Dec 2022, 1:54 pm | #108 | |
Other keys are: MEM - cursor up ABORT - minus TERM - equals All keys can be easily reconfigured. Of course you can easily find this out for yourself if anyone actually reads documentation that I've linked to repeatedly. |
9th Dec 2022, 2:13 pm | #109 |
Sorry Pernod70, I haven't yet been able to allocate any time to installing or using the emulator personally, but I agree RTFM is pertinent advice for anyone who is actually using it.
How did you arrive at the default keys chosen to shadow the Go, Mem, Abort, Term keys? If I'm honest, the ones chosen are not in the first half dozen that I would have guessed. |
9th Dec 2022, 2:26 pm | #110 | |
All official documentation is at https://docs.mamedev.org/, and is reasonably well maintained. Basic usage info is at https://docs.mamedev.org/usingmame/index.html which includes accessing the internal User Interface which gives access to Input Settings, and a whole lot more. |
9th Dec 2022, 2:43 pm | #111 | ||
9th Dec 2022, 2:51 pm | #112 |
'F' when you are just about to collide with a 'Mine'. If you fail to 'deactivate' any of the mines, you're sent back to the start of the screen. Clearing a whole screen starts another wave - I think you might have to press 'Go' to start each wave. Each successive wave runs a little bit faster.
9th Dec 2022, 3:42 pm | #113 |
This is 1977 remember - dont expect an Xbox game with Dolby surround, total-immersion video and haptic feedback!!!
9th Dec 2022, 4:39 pm | #114 |
10th Dec 2022, 4:45 pm | #115 |
ive had a look at the debug command but cant see how you would create a bin file from hex. could you give me an example of how you did this? maybe use charset.hex as an example?
10th Dec 2022, 5:23 pm | #116 |
actually i just solved it with hxd, so no worries.
10th Dec 2022, 5:56 pm | #117 |
Well, I'd already typed a pageful of guff so might as well post it, though its much quicker to do than to describe
Actually charset is an awkward example as the Intel hex file has two parts. Taking the first part as an example (the second part is done the same way, with its own addresses): From the hex file we need three things for each part. Where the part starts, where it ends and the length. Visually reading the hexfile you can see that the first part of showchar is from 0880 to 08C5 - mental note! Find the code length by subtracting the first address used from the last and add one which in this case is 46h. (8C5-880+1) Using debug.exe that was supplied as part of MSDOS and these days needs to be run under DOSBOX - you'll need to set the right dos version with (say) "ver set 6 22" in dosbox... You run debug from the dos prompt with the hex file suffixed: debug charset.hex It loads the content of the hex file (both parts) as a binary into memory at the address(es) specified in the hex file, then replies with its own "-" prompt. You can see the code and confirm it looks like the hex file by typing -d880 (or wherever its loaded) Debug saves from location 100h (because its CP/M derived) so we need to move the code down to 100h using the M command: (move from start address, through end address, to destination) -m880 8C5 100 The code is now down at 100h where it can be saved. Give the binary a name using the N command: -ncharset.bin and set the code length in cx using the R command: -rcx -46 then you can write the binary using the W command: [be careful not to include any numbers here, just a 'W' and press return] -w Control/C to exit debug and a dir should show showchar.bin in the current directory. *or* Run HxD, drag across the required code, save as bin Last edited by Phil__G; 10th Dec 2022 at 6:16 pm. |
10th Dec 2022, 6:13 pm | #118 | |
10th Dec 2022, 6:19 pm | #119 | |
No probs, I was joshing, Sirius had asked too.
The short answer to the question... Quote:
Here are the two binaries (both must be loaded): Last edited by Phil__G; 10th Dec 2022 at 6:33 pm. |
