15th Nov 2022, 2:59 pm | #1 |
Ferguson 387RG - Loud Humming (constant)
Hi all,
In 2019 I bought this lovely radiogram at auction. I cleaned it up, new cartridge, etc. It was working lovely. About a year ago it developed a very loud hum/buzz (very loud!) when powered on. Regardless of whether it was on radio mode or record playing mode, the hum was constant, even if the volume was set to minimum. I've bought service manuals from service-data but it's a bit above me when it comes to capacitors and valves. Any idea what might be the problem? I've taken the back panel off, I'll post some pictures below. |
15th Nov 2022, 3:28 pm | #2 | |
Re: Ferguson 387RG - Loud Humming (constant)
Alternatively there are members here who will be able to guide you through the process.
15th Nov 2022, 3:38 pm | #3 | ||
I can probably get some family members to help with the electrical side. But I wouldn't know where to start with ordering replacements. I'm working my way through the service manual, but it'd a little tricky. I was thinking of posting some screenshots so as to be guided to finding the right part, but as the manual was bought from service-data I don't want to publish any screenshots which may go against the rules. |
15th Nov 2022, 3:53 pm | #4 |
Having a look at the service manual, I think I've found the part. Could anyone confirm?
I'm assuming it's the silver thing in the final picture: 40-40-32-MFDS [EDIT] - Okay, so according to another thread. The silver canister contains the 3 smoothing caps. Is it possible to order replacements for these? As a whole, or would I need to order 3 separate caps? Thanks! Last edited by peanut369; 15th Nov 2022 at 4:18 pm. |
15th Nov 2022, 4:57 pm | #5 |
You may have trouble in finding an original "three-in-one" can today. Best to order 3 seperate ones, ideally rated at 350V. But if you have no real experience of these, do get a local Member to fit them. There are lethal voltages here.
Edward. |
15th Nov 2022, 5:13 pm | #6 |
Yes, I couldn't find any online. So I'll have to go the route you mentioned. Thanks Edward
15th Nov 2022, 5:23 pm | #7 |
Almost certainly, the smoothing caps have died. The standard solution is to replace the old double or triple cap with several modern caps on a tagstrip underneath the chassis (the modern caps will be very much smaller).
This isn't a difficult job, but it does need basic soldering skills and at least beginner level electronics knowledge. However, if this radiogram is unrestored then there will be other components that will be on the point of failing and need to be replaced. If this isn't done, the performance will steadily deteriorate until you get an expensive failure like an output transformer, or even a fire. Getting professional help is probably the best way forward. |
16th Nov 2022, 9:16 am | #8 |
Thanks Paul! That makes complete sense now.
And yes, you're right, there's a small blob of goop on the cabinet frame underneath the mains voltage adjustment, so I imagine it'll begin to fail soon. If it lasts me just 3 months through this winter then I'll be happy. |
16th Nov 2022, 10:41 am | #9 |
It is actually a nice, usable radiogram with VHF FM. It would be a shame to run it into the ground by not replacing the other essential capacitor(s). You have done the first step by researching and correctly identifying the cause of the hum.
Have a look at this thread https://vintage-radio.net/forum/showthread.php?t=131732 and this information https://www.vintage-radio.com/repair...ut-stages.html which give information about the most problematic capacitor. If you can get the person who is going to replace the smoothing caps to replace this one as well then the set should be a lot safer. The capacitor itself will probably only cost a pound or two.
Paul |
16th Nov 2022, 7:30 pm | #10 |
What I do is to replace the cap with a 50+50+50uf in one can which I keep in stock.
6th Dec 2022, 2:57 pm | #11 |
I've managed to find a direct replacement (see attachments)
But, underneath the cap is 4 terminals, not 3 as was on the original. And there's no markings, colour codings on the capacitor. Do I have a way of finding out which is which? Have I bought a capacitor that someone has re-stuffed? Or is the 4th terminal perhaps used for attaching the cap to the board as support? |
6th Dec 2022, 3:06 pm | #12 |
I wouldn't be inclined to trust a capacitor dating from 1963 unless you have a means of testing it for electrical leakage at the full working voltage and can measure the capacitance of each section.
Tag 3 is probably the common negative with the other tags used as designated on the can. I'll hazard a guess that the tags number clockwise from the gap, but you'd need to check with a capacitance meter to be sure.
6th Dec 2022, 3:18 pm | #13 |
It isn't re-stuffed but, as StationX says it is old. Unlike valves, electrolytic capacitors deteriorate with age and lack of use. It will need reforming if it is at all viable.
It would be better to replace the original with new discreet capacitors. If there is nobody nearer I can test and try to reform it at its working voltage but in view of postage costs it may be better to write it off to experience and buy new capacitors from a reliable source such as CPC, RS or Cricklewood Electronics. I would be a little wary of Ebay if the capacitors you see on there are a lot cheaper as there are many fake ones around.
Paul |
6th Dec 2022, 3:26 pm | #14 |
Thanks Graham and Paul. Definitely a write-off as experience. Thank you for offering to reform it Paul.
I think you're right, 3 new separate capacitors is the way forward. Thank you! |
6th Dec 2022, 9:08 pm | #15 |
Hi, you should be able to get modern , separate caps easily and fit them under the chassis.
While you are on, change all the waxies to save trouble later Ed |
6th Dec 2022, 9:23 pm | #16 | |
Three separate caps is the best way as already suggested, but for a long, reliable life, it should be serviced properly.
7th Dec 2022, 12:18 pm | #17 |
You really need to note this. If you don't change some of the wax capacitors all your work will be in vain. Been there had the transformer rewound!
Paul |
5th Feb 2023, 8:52 pm | #18 |
Thanks everyone. I've finally got an hour or two to research this.
Looking at the service manual...."THAT capacitor" I believe is : 0.02uF (22nF) 150 V. Audiocoupling (F.M.) Is that correct? (Service manual screenshot attached). Finding the components online: I'm looking online at RS components as they have a local store. For THAT capacitor. I honestly don't know if I'm correct assuming it's the 0.22nF cap. If it is, would it be a film capacitor or a ceramic capacitor? And would 160V do? I can't find a 150v one. https://uk.rs-online.com/web/p/film-capacitors/1854123 Smoothing Caps: Needing 40 / 40 /32 @ 275V. Would 3 of these do? They're 47uF @ 250V https://uk.rs-online.com/web/p/alumi...citors/9213218 Wax Caps: According to the manual, one of the wax caps is "4uF Electrolytic 150V. Ratio det. stabiliser" Would the following work? https://uk.rs-online.com/web/p/alumi...citors/1620722 Thank you in advance |
5th Feb 2023, 10:19 pm | #19 |
Others have more expertise then I do and I defer to any more expert opinions on this but..
I don't have the circuit diagram of your set to hand but I do have one for a 384U which I assume is similar. The audio coupling cap in that one is 0.01uf. The equivalent on yours is C50. It is described as V5 CG (control grid) coupling. The .02 described as Audio Coupling FM doesn't actually HT on it as far as I can see. Having said that, I see from other threads on this set that the capacitors are Hunts Moldseals. These are particularly troublesome and you should replace them all. They are brown cylindrical plastic ones and often split where the two halves were joined. I have gone down the route of only replacing bad ones on a Bush FM set and more failed as it was brought into use so I replaced them all. I would replace the smoothing electrolytics with one of the same voltage or higher. Using lower rated ones is a bit risky. By definition an electrolytic capacitor is not a wax one. They have different construction and different failure modes. The one you link to would be suitable. Watch out the polarisation - unusually for electrolytics the positive of the one in that situation goes to ground. The one already fitted may be ok. Looking at other threads about similar sets a solid state selenium rectifier rather than a valve rectifier is mentioned. Those can cause problems including hum. Apparently they give off an awful, unforgettable smell when they fail. I have never experienced this but it is something to think about replacing if yours has one.
Paul |
5th Feb 2023, 10:23 pm | #20 | |
