Old 6th Sep 2022, 7:54 am   #21
Freya
Freya's Avatar
Default Re: Standards Converter recommissioned.
Hi David,
Would like to see your circuit please to compare chip choice for the interpolator / line store compared to the MK2 dinosaur, think the MK2 was redesigned to use the mach210-20 CPLD which cut down on the chip count to a mere 18!
Stephen
Freya is offline
Old 8th Sep 2022, 8:40 am   #22
HamishBoxer
HamishBoxer's Avatar
stevehertz, was your modulator made by David Grant I wonder back in the 80's? If so a top class piece of kit, as was the standards converter.
HamishBoxer is offline
Old 8th Sep 2022, 11:39 am   #23
FERNSEH
FERNSEH's Avatar
Interpolation, done at analogue levels from the DACs. Been thinking about doing a digital solution but to be honest I just haven't got the time to get around to doing something about it.
History of the converter. The project started in the autumn of 1984; the plan was to have a workable converter ready for the close-down of 405 of transmissions in January 1985.
But wasn't to be so because I developed a serious health issue and it wasn't until the autumn '85 the project was restarted.
The period between 1980 to the early 1990s was the busiest time I've ever experienced in the TV trade.
DFWB.
FERNSEH is offline
Old 8th Sep 2022, 4:13 pm   #24
Heatercathodeshort
Heatercathodeshort's Avatar
How I remember those incredible years! I was placing bulk orders to Toshiba for colour TV and VCRs. Looking through my old stock books I once ordered 24 X 12" mono portables and sold them all in 14 days. Great times never to return.
I built the David Looser modulator David. It still works fine. Your standards converter stood alone in 1984. Absolutely amazing! John.
Heatercathodeshort is offline
Old 8th Sep 2022, 5:32 pm   #25
TonyDuell
Originally Posted by FERNSEH View Post
You're welcome to the circuit diagrams of both converters.
DFWB.
I'd be very interested in seeing these circuit diagrams too if you're prepared to make them available
TonyDuell is offline
Old 8th Sep 2022, 10:48 pm   #26
radiomarktv
Hi David, thank you for sharing your converter with us, a great achievement.
Can you be credited as the first person to produce a home built 405 line standards converter?
I too would like to see the circuit diagrams if ok with you.
Mark.
radiomarktv is offline
Old 9th Sep 2022, 7:52 am   #27
Electronpusher0
I too would love to see the circuit diagrams.
PM sent
Peter
Electronpusher0 is offline
Old 9th Sep 2022, 1:23 pm   #28
FRANK.C
FRANK.C's Avatar
As far as I understand apart from the BBC David was the first to produce a working 625 to 405 line converter and led the way for others to follow.
It was an incredible achievement to build something as complex as a standard converter from TTL. Getting it to work at the speeds required for the converter couldn't be easy especially not having a PCB and using vero board.
It had to have taken a huge amount of work and great commitment especially when no one had done it before.
David showed it could be done. Thereby making it easier for anyone after that.
Frank
FRANK.C is offline
Old 9th Sep 2022, 11:28 pm   #29
FERNSEH
FERNSEH's Avatar
I will be pleased to show to all those interested the circuit diagrams of the two standards converters I constructed in the mid nineteen-eighties.
But I'll need time to redraw the diagrams and descriptions of the workings of the circuits.
DFWB.
FERNSEH is offline
Old 13th Sep 2022, 10:00 pm   #30
FERNSEH
FERNSEH's Avatar
Peter Scott wrote: "I think the set is not doing justice to your converter"
Hi Peter,
A regular client brought his Decca DM45 in for repair. The set has a frame timebase fault.
Using a 625 line Test Card C generator as the signal source for the converter, the 2.5Mc/s definition bars can clearly be seen and the 3meg bars also.
The Marconi VT161 was struggling to resolve the 2.5meg bars. Also, the stability of vertical details is bad.
Let's see what the picture looks like when the Decca is repaired.
DFWB.
FERNSEH is offline
Old 13th Sep 2022, 11:28 pm   #31
peter_scott
peter_scott's Avatar
Hi Peter,
DFWB.
' Love it!
Go for it David.
Peter
peter_scott is offline
Old 17th Sep 2022, 11:23 am   #32
FERNSEH
FERNSEH's Avatar
Attached picture was taken from the screen of the Decca DM45. Showing the 2.5Mc/s definition bars. Camera captures only one picture field.
DFWB.
FERNSEH is offline
Old 17th Sep 2022, 1:09 pm   #33
peter_scott
Got to get rid of the overshoot on the step response though.
Peter
Old 17th Sep 2022, 2:09 pm   #34
FERNSEH
FERNSEH's Avatar
Hi Peter,
the video waveforms at the control grid of the video amplifier valve and the grid of the sync separator.
Clearly, the video amplifier needs some attention.
DFWB.
ID:	264864   Click image for larger version
FERNSEH is offline
Old 17th Sep 2022, 5:15 pm   #35
peter_scott
Strangely the first photo (video amp??) looks quite well controlled. Can you probe the video amp anode?
I just looked at the circuit. I see the sync separator grid probably looks much the same as the video amp anode. What happens when you adjust VR10?
Peter
Old 17th Sep 2022, 9:06 pm   #36
FERNSEH
FERNSEH's Avatar
After replacing C48 in the video amplifier the over-shoot effect has gone.
However, there is a slight loss of definition. The 8.2K anode load resistor has risen to 11K. That component will be replaced.
VR10, the white spot clipper is inactive.
DFWB.
ID:	264884   Click image for larger version
FERNSEH is offline
Old 17th Sep 2022, 10:20 pm   #37
peter_scott
Excellent! That test card image must be looking much healthier now.
Peter
Old 17th Sep 2022, 10:21 pm   #38
murphyv310
murphyv310's Avatar
Hi
Check C49 for correct value it may have drifted low reducing HF correction.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 20th Sep 2022, 10:53 am   #39
FERNSEH
FERNSEH's Avatar
The first attachment shows the converted picture on a Bush TV62. That set needs some attention having not been switched on for ages.
The second attachment shows the divider network employed to produce the 405 and 625 timing pulses.
DFWB.
ID:	264996   Click image for larger version
FERNSEH is offline
