1st Sep 2022, 4:53 pm | #61 |
Re: Grundig tk 23 L speed issue
It's reasonably easy to check the speed of your tape recorder by using a measured length of tape.
To do it, preferably on a tape that isn't of any importance to you, make a mark on the back of the tape somewhere near the start of the tape. You can use a chinagraph pencil, a wax crayon or a marker pen. Measure along the tape 190.5cm from the mark you have made and make a second mark at that point. Thread the tape onto your tape recorder and line the first mark up with the exit point from the head cover. Play the tape and measure the time until the second mark appears at the exit point from the head cover. If the tape is running at the correct speed, it should take 20 seconds. If it is running fast it will take less time and it will take longer if running slow. The test should allow you to determine if it is the Akai or the Grundig that is running at the wrong speed. Paula |
1st Sep 2022, 5:55 pm | #62 |
Thank you Lawrence. Learn something new every day!
Graham, you're spot on. In trawling through Facebook, I can see the 50/60Hz control is between the spools. Paula, you're a star. Your recommendation should nail the issue. Chris Last edited by simpsons; 1st Sep 2022 at 6:04 pm. Reason: Additional information |
1st Sep 2022, 7:41 pm | #63 |
The TK 23L and all its numerous associated series siblings are not idler drive.
The motor pulley drives a belt that directly drives the flywheel, the capstan being part of the flywheel. There is a single rubber tyred idler wheel that is driven by the motor pulley and then the idler wheel drives the Take Up reel table in Fast Forward wind. David |
1st Sep 2022, 7:59 pm | #64 |
Most single motor decks require an idler somewhere to obtain the opposing direction wind / rewind.
An exception was the EMI TR50 series where the take up was B wind (oxide out) but then it used idlers to the spools anyway..... |
1st Sep 2022, 8:09 pm | #65 |
For the Grundigs in question the motor pulley directly drives the Supply reel table in Fast Rewind.
David |
1st Sep 2022, 8:43 pm | #66 | |
1st Sep 2022, 8:45 pm | #67 |
Result!!
24*50/60 = 20 . or 20*60/50 = 24 .
1st Sep 2022, 8:49 pm | #68 |
The akai as far as I know does not have a 50hz/60hz selector
1st Sep 2022, 8:51 pm | #69 |
This is the Akai
1st Sep 2022, 9:17 pm | #70 |
I have never seen a 4000DS that does not have the 50Hz/60Hz adjustment, all mine have it.
Post a photo of your rear panel ident label. David |
1st Sep 2022, 9:34 pm | #71 |
Here you have them mate
1st Sep 2022, 9:43 pm | #72 |
I got it a few years ago in a barter and the previous owner told me that nothing had ever been done to it. Since I didn't have another one and it worked well, I've been leaving it but I've been wanting to do a set-up for a long time. This may be a good time
1st Sep 2022, 10:21 pm | #73 |
Hi Ubaldo
My Spanish isn't too good but should I be you, finding it was the Akai that was faulty, which at least could record and playback OK, made me think "maldito." Chris |
1st Sep 2022, 10:21 pm | #74 |
So your 4000DS machine is 50Hz only but appears to be running like a 60Hz machine.
Checking one of my dual frequency 4000DS's I see that the flywheel and also the motor pulley has 2 steps of slightly different diameter. For 50Hz running the drive belt runs on the smaller step of the fly wheel and the larger step of the motor pulley and the complete opposite for 60Hz running. So if (maybe a big if) your machine has the same 2 step flywheel and 2 step motor pulley, then one feasible explanation could be that at some time the drive belt has been replaced/disturbed and manually incorrectly fitted on the 60Hz steps. The photos show the belt position on the flywheel, could not see the motor pulley well enough to take photo but you can feel the different step diameter and the belt should go straight across (not at an angle) from the flywheel to the motor pulley. First photo is 50Hz with the belt on the smaller step of the flywheel and second photo is 60Hz with the belt on the larger step of the flywheel. David |
2nd Sep 2022, 10:12 am | #75 |
2nd Sep 2022, 10:14 am | #76 |
The Spanish mains frequency is 50Hz.
2nd Sep 2022, 10:26 am | #77 |
I want to thank everyone for your help and apologize for my mistake. I'm going to repair my Akai and I'll tell you
2nd Sep 2022, 6:02 pm | #78 |
Just for completeness of information.
The 50/60Hz dual frequency Akai 4000DS in addition to the mechanical 50/60Hz setting also has an electrical 50Hz/60Hz switch setting. When switched to 60Hz the voltage supply to the motor/run capacitors is increased from 100V to 120V and the 0.5uF run capacitor is disconnected from the 2uF run capacitor that it is paralleled to in 50Hz setting (the 2 run capacitors are in a dual can), i.e. 50Hz = 2.5uF, 60Hz = 2uF. David |
14th Jan 2023, 11:44 pm | #79 |
Hello again. Finally the problem was the Akai. I took it to do a set-up, belts, lubrication, adjustments etc and some capacitors that were out of value. Now it works correctly and the recordings are heard perfectly on both the grundig and the Akai. Thanks to everyone for the tips
15th Jan 2023, 11:33 am | #80 |
Good news, well done.
David |
