Old 19th Jun 2022, 1:31 pm   #41
dalekmoore2007
Default Re: Modeline experiments
I have the horizontal scan up i am going to need a position control to work out the amount the correct adjustment to the 5 ohm resistor .
Also will be experimenting with the 2 capacitors on the input and yoke coil
Scans about 10 khz as i will be trying 405 line first when i get the raster correct
ID:	259329   Click image for larger version
dalekmoore2007 is offline
Old 2nd Jul 2022, 12:14 pm   #42
murphyv310
murphyv310's Avatar
Hi.
Just wondering how many have got this to work successfully.
Recently I've been giving thought to how I want to proceed with the hobby itself and am thinking that if I keep just a couple of sets. The PC based standards conversion is really all I need, I have an ex ITV sound and vision band 3 test modulator that is a superb unit and the vestigial filter too so this would be my source of signal for band 3 and my rod pentode modulator for band 1. The PC is a Dell Optiplex 480 and I wonder if this is suitable with the appropriate graphics card?
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 2nd Jul 2022, 3:04 pm   #43
Graham G3ZVT
Graham G3ZVT's Avatar
As long as it has a PCI Express slot.
ATI Radeon HD 2400 XT cards are cheap on Ebay, don't forget you need the DMS-59 to VGA Cable.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 3rd Jul 2022, 9:08 pm   #44
peter_scott
peter_scott's Avatar
Hi Trevor,
I'm using a Dell Optiplex 780 with the HD2400XT sound card.
Peter
peter_scott is offline
Old 4th Jul 2022, 7:20 am   #45
Jac
Jac's Avatar
Hello Trevor,
I use a Dell Optiplex 755 with an ATI HD2400XT graphics card.
Only 4 GB memory (Windows 7 32 bit). and a 120 GB SSD.
These days I only use this for 819 lines, but it has been over two and a half years that it was in service. Must see soon if it is still working...
Jac
Jac is offline
Old 5th Jul 2022, 6:06 pm   #46
Jac
Jac's Avatar
I forgot to mention that I had quite a lot of help from Peter Scott in getting everything working properly.
In the end I did not use any additional circuitry to get the synch signals better. Just the simple circuit with resistors and a capacitor which I built into a VGA connector.
Jac
Jac is offline
Old 6th Jul 2022, 1:29 pm   #47
murphyv310
murphyv310's Avatar
Originally Posted by peter_scott View Post
Hi Trevor,
Peter
Hi Peter.
Mine is not a 480 but the same as yours a 780.
Thanks for the info.
Cheers,
Trevor.
Old 6th Jul 2022, 2:44 pm   #48
peter_scott
Hi Trevor,
I did try to see what the difference was but failed.
Peter
Old 7th Jul 2022, 12:07 am   #49
Graham G3ZVT
I use my main computer, an Optiplex 990.
Graham.
G3ZVT
Old 8th Jul 2022, 6:36 am   #50
dalekmoore2007
Originally Posted by murphyv310 View Post
Hi.
First up so sorry I have not been active here for a while, been working on the monitor, had a hell of time working out the deflection circuits, I had used them before but was just getting a small raster.
Now on mode line it's really all I need in the lower NBTV range we have other software or low def television, for me on modeline I am now able to experiment above 100 lines.
If we had old 405 line sets here I would use it for this but any thing below 625 I have to convert of make something. I will post up where I am up to today.
Old 8th Jul 2022, 6:40 am   #51
dalekmoore2007
After looking in my shed I found a dual display card! I never knew what it was because that dual VGA cable was missing so didn't know what the plug was! I might have got mode line going early if I knew. Scrapping old PC's in the past I forgot what I had!
Old 8th Jul 2022, 6:49 am   #52
dalekmoore2007
OK on the monitor side I only used the deflection push pull amplifier part of the schematic I posted a while back and knocked together another circuit to drive it. I looked into syncing the ramps today with an LM1881 and this baby has no problem with 405 line rates, so that works. Next I will look into modulation might have a picture to show next time.
ID:	260588   Click image for larger version
ID:	260589   Click image for larger version
Old 11th Jul 2022, 8:46 pm   #53
murphyv310
murphyv310's Avatar
Hi
Great progress indeed.
I've won a graphics card on Ebay for £0.99 and it's been dispatched, so hopefully later in the week I'll get started on this.
Cheers,
Trevor.
Old 16th Jul 2022, 4:40 pm   #54
murphyv310
murphyv310's Avatar
Hi.
I now have the graphics card and it's installed in my Dell Optiplex 780 and certainly operating.
Now to learn what to do next, the PC is dual boot between Windows 10 and Linux Mint 20.3.
How should I proceed now?
I also got a lead with the Graphics card that has two VGA female sockets.
Cheers,
Trevor.
Old 16th Jul 2022, 7:54 pm   #55
Graham G3ZVT
Can you confirm that the card you have is a ATI RADEON HD 2400XT?
Next step is to download Jeroni Paul's "Winmodelines"
http://www.geocities.ws/podernixie/h...deline-en.html
Then find a spare VGA cable, cut it in the middle, and use one half to make the
"VGA to composite video in black and white" cable
Here:
http://www.geocities.ws/podernixie/htpc/cables-en.html
Graham.
G3ZVT
Old 16th Jul 2022, 9:14 pm   #56
Graham G3ZVT
Also, the PC needs to see a VGA monitor on each port when booting up.
Whilst a VGA switch-box to switch between one monitor and the modulator is not essential, it does save a lot of messing swapping plugs.
Graham.
G3ZVT
Old 16th Jul 2022, 10:02 pm   #57
murphyv310
murphyv310's Avatar
Many thanks Graham.
I'm sure I've got the correct card I'll need to double check though.
Changing monitor plugs could be an issue so a switch box will be on the shopping list.
I'll work on this over the next few days.
Thanks again.
Cheers,
Trevor.
Old 17th Jul 2022, 4:23 am   #58
dalekmoore2007
Bit more progress on the monitor
I was going for control grid modulation but cathode seems a bit easier on this CRT to modulate only problem it dropped my raster size .
Now after seeing the screen i was wondering what was going on as 625 line mode line was showing all the desktop on my last tv ,but 405 only part of the desktop then i had a look at the settings in the 405 to 625 line and that made sense why i just had to view it ; )
Well that's the reason i used the desk top clock as a television subject .
i have a fair few problems to work out as you see but getting there .
ID:	261079   Click image for larger version
ID:	261080   Click image for larger version
ID:	261081   Click image for larger version
Old 17th Jul 2022, 4:42 am   #59
dalekmoore2007
Here's some video of the results so far 'a work in progress !
https://youtu.be/IkZBFUwLwaw
https://youtu.be/bFdC9xAJ7hk
Old 17th Jul 2022, 4:50 am   #60
dalekmoore2007
