20th Dec 2022, 11:17 am | #381 | |
Re: 6-gang FM stereo tuner heads
20th Dec 2022, 2:20 pm | #382 |
Note that there are some tiny/unrealistic component values in those lumped element matching networks. This stuff would often be done using printed/distributed traces on a PCB up at 2GHz.
I think the Q of 1.5 can be done quite neatly using 5 lumped elements and the element values are much easier to realise with this network. The shunt/series inductors could also double up as the bias feed to the amplifier. It's also possible to do it with 4 elements with a Q of 1.5 but the first shunt capacitance value becomes quite small. The network below has a wider response with a lower insertion loss and VSWR over a wider bandwidth. However, this might not be the design goal.
Regards, Jeremy G0HZU |
20th Dec 2022, 3:05 pm | #383 | |
Upon hearing graded-density, distributed structures for the first time, I have accidentally bumped into this scary book: https://www.microwaves101.com/uploads/MYJ-part-2.pdf Last edited by regenfreak; 20th Dec 2022 at 3:16 pm. |
20th Dec 2022, 5:48 pm | #384 | |
Try it with arcs to alternating sides and back to real. Let there be an equal number of arcs on each side. Make the ratiometric change in impedance be equal for each arc and back. So is the ratio of Z overall is x and you have y arcs, then the ratio of Z for each arc and return arc becomes the yth root of x. Try this and watch the Smith chart as you sweep the frequency variable. The arcs to the opposite sides vary inevitably, but tend to cancel much of each others disruption. The end point lurks around your target Z over a wider frequency range. So you get a better breadth of match. You can use Q arcs to decide how far your trips out each side go. One of those tricks to keep up your sleeve for special occasions. David
20th Dec 2022, 5:57 pm | #385 |
I used a similar ladder network in the drain circuit of the CPH3910 JFET LNA that I designed to vover the VHF FM band. JFETs generally have fairly low gm so then tend to get used in narrowband amplifier circuits. I had to design a wideband matching network in order to get about 12dB gain across the VHF band with a ~2dB noise figure.
I had a quick go at measuring the gain and noise figure with my 50 ohm spectrum analyser and the result is shown below. It looks like it is slightly detuned at the top end but probably still OK. This is partly due to the LNA being designed for a 75 ohm system. The design goal was to achieve a sensible gain (12dB) across the whole of the FM band whilst also achieving some selectivity against out of band signals. The noise figure is about 2dB when measured in a 50 ohm system as in the plot below. It should be about the same in a 75 ohm system but the gain response should be improved slightly when tested in a 75 ohm setup. The LNA runs from +10V but would work anywhere from about +8V to +12V. It draws about 10mA from the power supply.
20th Dec 2022, 6:23 pm | #386 | ||
20th Dec 2022, 7:10 pm | #387 | |
and can you post the schematic? Thanks |
20th Dec 2022, 7:22 pm | #388 |
In case anyone is interested, I'm using the classic Fritz Dellsperger Smith chart program here:
https://www.fritz.dellsperger.net/smith.html This program has been around for many years. The demo version is limited to just five circuit elements which is a bit of a shame. I can get a slightly better response with the revised network below but the centre capacitor value value reduces to about 0.35pF. I can't show a six element network with this smith chart program, but I can draw in the sixth element by hand on the chart. See the diagram below. I think this is the kind of thing David was referring to.
Regards, Jeremy G0HZU Last edited by G0HZU_JMR; 20th Dec 2022 at 7:41 pm. |
20th Dec 2022, 11:55 pm | #389 |
There's Lance Lascari's LLSmith programme. Last seen on this RFDUDE website. That's pretty useful, rater old in operating system terms, but isn't hobbled in terms of elements.
21st Dec 2022, 4:06 am | #390 | |
My first attempt with the 6-element networks had a much better symmetric sweep response. I didn't read the instructions of Simsmith and still managed to get it working. I have had very little experience using it. Last edited by regenfreak; 21st Dec 2022 at 4:15 am. |
21st Dec 2022, 8:27 am | #391 |
Here is my 1st attempt to try Q<1 with 8 elements, following the intuition of the mole in the aforementioned Hunger Games; matching Z = 61-j90 to 50 ohm, centred at 1Ghz, sweeping from 500Mhz to 1.5GHz.
In the first arc, it is inside the Q-circle of 1.5. The other arcs are inside the Q=0.64 circles. The Q circles can be variable in the steps... |
21st Dec 2022, 9:26 am | #392 |
Here is a quickie multi-stage matching of a real broadband power amp based on the Z = 10.5 + 1.25j, Q = 0.85 of this random paper that I have come across, centred at 1.6G, sweep 0.5-2.5G:
https://link.springer.com/chapter/10...319-61382-6_21 The SWR looks a bit wonky. This one involves the crossing of the real axis. |
21st Dec 2022, 10:17 am | #393 |
That's almost the trick. You get better frequency compensation with an equal number of arcs to each side of reality.
For a power amp, it's beneficial to do a lowpass section first, then there is less harmonic energy radiated by the later sections, and less gets induced in the final output. Also keeps loops carrying harmonic current smaller. There are plenty of tricks. David
21st Dec 2022, 3:12 pm | #394 | ||
You need to think about those little connection pads on the PCB that connect those lumped parts together. The network I provided takes all this into account. Try building the 2GHz networks on a real PCB and you will find that my original network will perform well. The inductances will have to be tweaked slightly and the 0.5pF cap might become 0.35pF but the network will still end up looking like the original network. The final L match could be flipped to a shunt C series L to give a better lowpass response if that was desired? It would also increase the bandwidth slightly but it would still give a fairly lopsided response.
Regards, Jeremy G0HZU Last edited by G0HZU_JMR; 21st Dec 2022 at 3:37 pm. |
21st Dec 2022, 4:17 pm | #395 |
Here's the 5 element network with a shunt C series L as the final two elements. This trades the low side rejection for a less lopsided response. I think I've copied your 6 element circuit across OK and I've compared the response out to 10GHz. Both simulations assume lumped components and no PCB layout effects.
Of course, there's no right or wrong network here because there is no spec target for symmetry or bandwidth. Sometimes asymmetry can be a good thing or a bad thing and having some extra bandwidth can be a good thing or a bad thing. I think all of the shunt capacitors in your network would have to be replaced with printed shapes if it were built on a PCB. Both networks would lose bandwidth once transferred across to a real PCB layout so the network design might have to be revisited to correct for this. I've changed the trace colours to green and blue in the plot below. This makes it easier to view.
Regards, Jeremy G0HZU Last edited by G0HZU_JMR; 21st Dec 2022 at 4:24 pm. |
21st Dec 2022, 5:08 pm | #396 |
If the PCB material (and material thickness) was suitable, the other matching option would be to use a simple 145 ohm PCB trace about 80degrees long at 2GHz. This would give a similar bandwidth to your 6 element LC network. It would probably be about 20mm long. The trace width would be quite narrow, especially if the PCB material was fairly thin.
It could be squished into a hairpin shape to save on PCB space. I think I would prefer to use lumped parts for this task though.
22nd Dec 2022, 3:41 am | #397 | ||
Thanks. Anyway, the impedance for the amplifier was a fictitious value used as an example for learning. Keysight ADS software uses an optimiser to take all the labour and guesswork out of humans. You can specify and reject small component values in the optimisation: https://youtu.be/XpR6uoKYfF4 I have noticed that the series and parallel inductors combination allows tricks like crossing the real axis. Usually, it comes with the price of disrupting the symmetry of the frequency response. The L-network of the L and C pair tends to preserve the symmetry as they cancel each other disruption in each step of the multi-staging zig-zag walk. Quote:
The Q may be divided into 3-section transformations with different resistive transformation ratios. So you start off the mole walk with a large Q, and the Q gets smaller in each section. They obtain different values of Qs from ADS optimiser based on purely resistive to resistive transformation. However, I got the equation Q = SQRT [ SQRT(n) - 1 ) ] from somewhere that I can't remember where... There is something called Chebyshev broadening technique that I have been messing around with the SimSmith. Last edited by regenfreak; 22nd Dec 2022 at 3:58 am. |
22nd Dec 2022, 7:29 am | #398 |
I have tried to play with the three-section Qs aforementioned.
Here I have applied two approaches using a purely resistive source 5 ohms to 50 ohms, centred at 850MHz, sweep from 700MHz to 1Ghz. Case 1, two sections, constant Q = 1.5 (attachment 1 and 2) Case 2: three sections with Q1 = 1.68, Q2= 1.08, Q3 = 0.48 (attachment 3 and 4). Initially, I got the Qs from the table in attachment 5 based on ADS simulator optimisation, coming from: https://www.highfrequencyelectronics...09_Bichler.pdf Resistive ratio is 50 to 5 = 10:1 in the table. However, the Q3 of 0.58 has not worked out, and I have fudged the Q3 to 0.48 to get the mole back home. I guess how it works, right or wrong. Note that it is less symmetric than the two-section version with a fixed Q , more like a low pass... The graphical method has taken away all the horrendous and tedious maths behind the transformations, and I can see the beauty of the whole thing. Last edited by regenfreak; 22nd Dec 2022 at 7:35 am. |
22nd Dec 2022, 9:05 am | #399 |
It's one of those things where you start to see the shape of the forest and where you're going, when before you just seemed to be surrounded by trees.
In an RF team I was once part of, there was a bunch of people forming a not-too-serious rock group. I suggested the name: "Crosby, Stills, Matthei, Young and Jones". David
23rd Dec 2022, 1:24 am | #400 | |
