Reply
Old 7th Feb 2021, 12:57 pm   #1
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Gram motor speed indicator disk scans
This cardboard is disk approx 12cm diameter, published by Bernards and cost 10p back in the 70s.
It relies on the slight flicker of filament lamps to give the strobe effect, 50Hz one side and 60Hz the other side.
Scans attached, 600DPI.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is online now   Reply With Quote
Old 14th Oct 2021, 9:24 am   #2
hansomcommon
hansomcommon's Avatar
Default Re: Gram motor speed indicator disk scans
Thank you Paul, I was looking for a disk speed scan!
hansomcommon is offline   Reply With Quote
Old 16th Oct 2021, 11:05 pm   #3
majoconz
majoconz's Avatar
Works very well under one of those confounded CFL desk lamps - thanks Paul.
Cheers - Martin ZL2MC
majoconz is offline   Reply With Quote
Old 17th Oct 2021, 10:37 pm   #4
Sideband
Sideband's Avatar
They work very well under a neon lamp as well
Sideband is offline   Reply With Quote
Old 23rd Oct 2021, 12:34 pm   #5
Graham G3ZVT
Graham G3ZVT's Avatar
I recently found mine languishing in a drawer.
ID:	244014 Click image for larger version
Graham.
G3ZVT
Graham G3ZVT is offline   Reply With Quote
Old 23rd Oct 2021, 2:24 pm   #6
paulsherwin
paulsherwin's Avatar
Be careful with CFLs or LEDs though - they may not strobe at 50Hz, depending on the power supply arrangements. A traditional fluorescent should be OK though.
paulsherwin is online now   Reply With Quote
Old 13th Feb 2023, 9:30 pm   #7
Avinunca
The VinylEngine website is a good place to find these and apps are available for smartphones to use with them.
Avinunca is offline   Reply With Quote
Old 19th Aug 2023, 6:38 pm   #8
GeraldSommariva
GeraldSommariva's Avatar
good information , help me with my speed problem
GeraldSommariva is offline   Reply With Quote
Reply
