Reply
Old 27th Sep 2019, 6:25 pm   #61
Karen O
Default Re: 'THAT' Capacitor. What is it?
We do not speak of that capacitor of which we do not speak
Karen O is offline   Reply With Quote
Old 27th Sep 2019, 7:39 pm   #62
Radio Wrangler
Radio Wrangler's Avatar
Some explanation for Horacebatchelor....
Usual sorts of valves come with an anode, a cathode, and one or more grids.
Normally, the anode is at a high positive voltage with respect to the cathode. Several tens of volts to a few hundred and even more in high power jobs.
The real work of the valve is to pass current internally from its anode to its cathode and to allow that current to be controlled. The anode is connected to circuitry which uses the variations in the valve current to pass the amplified signal to the next stage, or to make sounds in a speaker.
This sounds OK? It's what everyone says and it agrees with convention. But convention got it wrong! A long time ago, people looked at basic electrical circuits and said "Something is flowing around and around it... that's why it always has to make a loop in order to work" so the idea of electric current was born and people had the idea of little things carrying small amounts of positive electric charge coming out of the anode terminal of a battery, flowing along wires through the bulb and switch of their basic circuit and back into the battery via the negative terminal. All seemed well. It explained what they saw. Then along came trouble, the valve. Some of the things it did threw the convention of the direction of electric flow straight down the pan. Yes there were things flowing, but they moved in the OPPOSITE direction to what people thought and they carried NEGATIVE electric charge. Well, it was a 50:50 chance and the guessed flow direction was wrong. We have been living with this whoopsie ever since.
So let's look at that valve again. The heater heats the cathode to a high temperature. Heat means rapid vibration on a tiny scale. Hot enough to shake electrons (the moveable carriers of negativity) loose from their parent atoms in the cathode.
Like charges repel and unlike charges attract.
The electrons try a bit to repel each other and spread out to form a cloud around the cathode. They like the anode and would like to zoom off, accelerating right until they smash into that anode. They can feel the high positive voltage on the anode attracting them. THis is how a diode valve works. The hot cathode can emit electrons, the cold anode can't.
If we put a grid or grille of fine wire near to the cathode and make it several volts negative, the repulsion from it can oppose the attraction from the much further-away anode, and leave the electrons hanging about near the cathode, repelling others back to the cathode.
This is called the control grid, or grid 1 if there are others. Its proximity to the cathode compared to the distant anode means that small voltage changes on the grid can oppose large voltage changes on the anode. This is what gives the valve gain.
So in valve in normal use the amode may be a few hundred volts more positive than the cathode, and the control grid needs to be several volts more negative than the cathode.
In ye olde days, sets had special 'grid bias' batteries to provide the needed negative voltage. They were found rather inconvenient. So they had the idea of using a resistor in the cathode circuit, so the cathode current would make the cathode run several volts positive of chassis potential, and the grid was biassed to chassis potential. This loses a little efficiency but adds a lot of convenience.
The cathode and anode are carrying real current, but the control grid is carrying none. Electrons don't go there, it is more negative than where they came from, it repels them. So the grid is very easy to drive and bias... you have to control its voltage, but it doesn't take any noticeable current. So you can bias it through big resistor values, which reduces the load on the signal coming from the preceding stage.
So when one valve is driving another, the anode of the first valve is hanging around some rather high voltages, but the grid of the second valve has to be around chassis potential. The cheapest, simplest coupling that will pass the AC signal and yet block the huge DC difference is a capacitor. THey work well and give you great bandwidth.
BUT if the capacitor goes electrically leaky... say moisture gets into it, it only takes a very tiny amount of leakage current to drive the grid of the following valve positive. This opens that valve up to pass its full current.
In most stages, a leaky coupling capacitor will stop the set working and will shorten the life of the following valve. Not good, but not a disaster.
BUT if the capacitor blocking the DC to the grid of the audio output valve goes leaky, the output valve is designed for large currents and has lots of current available to it. This valve will take damage and the high current can burn out output transformers and even entire power supplies.
Audio output valves are expensive, there is high demand from the audio fraternity pushing up prices for spare glassware.
Audio output transformers are very expensive and harder to find than valves.
So, leakage is important in ALL coupling capacitors between stages, but the coupler to the audio output stage puts a lot more at risk. Calling it 'That capacitor' isn't a very good name. It's the expurgated version. Usually they get the benefit of a good fruity adjective applied to them.
Hope this cuts through some fog and confusion.
Radio Wrangler is online now   Reply With Quote
Old 27th Sep 2019, 7:59 pm   #63
HamishBoxer
HamishBoxer's Avatar
Simple answer,"that capacitor" is better off called output valve grid coupling capacitor.Also known as G1 (the grid that is).
Hope this helps.
HamishBoxer is online now   Reply With Quote
Old 27th Sep 2019, 8:35 pm   #64
TrevorG3VLF
TrevorG3VLF's Avatar
If a capacitor is blown apart, then find out what components it is connected to. Easy if it is a couple of valves, not so easy if it is in a tone control circuit.
Look on the circuit diagram to find its value and voltage rating. Replace with a similar capacitor, higher voltage capability will do no harm.
Do only one change before checking that you have not made a wiring error or you will soon get very lost.
TrevorG3VLF is offline   Reply With Quote
Old 28th Sep 2019, 12:30 am   #65
Graham G3ZVT
Graham G3ZVT's Avatar
If you have a set where a capacitor has blown apart, there is a good chance it was wired directly across the mains, perhaps with just the on/off switch intervening. If that's the case, you can snip out the retirements and forget about it for the time being.
Graham.
G3ZVT
Graham G3ZVT is online now   Reply With Quote
Old 30th Sep 2019, 1:14 pm   #66
Maarten
Is the mains suppression cap also known as "that other capacitor"? :P
I'll get me coat.
Maarten is offline   Reply With Quote
Old 30th Sep 2019, 6:33 pm   #67
Herald1360
Herald1360's Avatar
Not as far as I know- it doesn't generally do anything worse than blow its end off and maybe take out a fuse or if it's a yellow RIFA create a n'orrible stink. It doesn't quietly munch its way through other expensive components.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline   Reply With Quote
Old 24th Jan 2020, 2:15 pm   #68
Calmore
Ok, so what do you replace "that" capacitor with? A yellow polyester of suitable voltage/capacitance?
Calmore is offline   Reply With Quote
Old 24th Jan 2020, 5:33 pm   #69
Station X
Station X's Avatar
They will certainly do the job as will any modern cap of suitable value.
You may find this thread useful:-
https://www.vintage-radio.net/forum/...ad.php?t=88767
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 24th Jan 2020, 6:10 pm   #70
Radio Wrangler
Yellow polyester is fine. Next value up or next value down should be OK if you can't get it exact.
But be sure the voltage rating is at least as high as the original part.
Avoid electrolytic capacitors. Avoid high density ceramic capacitors. These types can be leaky from new.
Old 24th Jan 2020, 7:20 pm   #71
...and the yellow polyester types have leads on them, easy to replace.
Old 23rd May 2020, 4:21 pm   #72
mancunian69
mancunian69's Avatar
I have found that with the set on if you pull the output valve and probe pin 2 for DC that will give you a good idea as the the condition of the grid feed cap.
This is for EL84 of course.
I would always replace this cap on sight, as they have a harder life than certain others.
mancunian69 is offline   Reply With Quote
Old 24th May 2020, 1:19 am   #73
Herald1360
Herald1360's Avatar
Pulling the output valve won't work for a series heater chain set with a valve rectifier though.
You'd get a nice looking but meaningless 0V
....__________
Old 24th May 2020, 1:22 pm   #74
ekjdm14
Indeed, although I do tend to subscribe more to the shango066 method of it'll either work or smoke, output grid couplers if wax, have to go before the set sees power since the rest of the parts are easier to source/fix if they smoke whereas OPT's and power amp valves are not.
Another bodge I've been known to perpetrate on sets to see if they're any good prior to proper work, is to just series the waxies with appropriate values on the assumption they're shorted anyway. Worst it's caused me so far is motorboating, and guarantees no DC where AC ought to be. (of course that's a case of do as I say not as I do, since it's a blatant bodge but suits me for very basic temporary testing)
ekjdm14 is offline   Reply With Quote
Old 24th May 2020, 1:32 pm   #75
Station X
Station X's Avatar
If I see positive volts on the control grid, I snip the lead from the cap to the control grid pin. Connecting a voltmeter between the disconnected end of the cap and chassis will show just how leaky the cap is/was. I've seen hundreds of volts there.
Old 18th Jun 2021, 2:12 pm   #76
toprepairman
AArrrgghhhhhh!!
Not always.
If it's a Rogers amp fitted with Mullard mustards.
I saw someone recently who replace all the mustards in what WAS a nice HG88 with modern yellow things, and made a proper dogs' dinner of it too.
A little knowledge and all that....
toprepairman is offline   Reply With Quote
Old 18th Jun 2021, 5:02 pm   #77
Station X
Station X's Avatar
I think most members here are aware that Mullard Mustards are among the most reliable capacitors ever made.
No one is advocating wholesale capacitor replacement or "shot gunning" as I believe the Americans call it. I prefer to call it "Compulsive Component Changing", but I wasn't the first to coin that phrase.
Old 18th Jun 2021, 5:52 pm   #78
stevehertz
stevehertz's Avatar
AArrrgghhhhhh!!
Not always.
Agreed about Mullard mustards, but I think the general notion of changing that cap on sight is more something that you would do with a vintage radio, not a later and probably built to a higher spec piece of British hifi equipment.
stevehertz is online now   Reply With Quote
Old 26th Sep 2022, 4:07 pm   #79
galanie
Fair enough
galanie is offline   Reply With Quote
Reply
