9th Jan 2022, 2:38 am | #21 |
Re: Blown capacitor.
MOV's are bi-directional and are designed to be fitted directly across the mains supply.
The size of breaker in the supply would make no difference to the device failing. What causes an MOV to fail is too high a supply voltage. |
9th Jan 2022, 2:43 am | #22 |
so there were 2 of these mov
1 blew the other was left. if you look at the picture i uploaded you will see the numbers on the mov now on my item it says just 175L20 but others have 175LA20AP and another has 175L20CP |
9th Jan 2022, 2:58 am | #23 |
hey wavesolder
well its a 240 unit and its wired as 240 this is the power / ratings from the manual POWER / RATINGS Amp Rating at 208V 31.3 Amp Rating at 240V 35.6 KW Rating at 208V 6.5 KW Rating at 240V 8.6 |
9th Jan 2022, 3:32 am | #24 |
so the only thing i could think it was the amp breaker.
1 wire from breaker to the device. everything done perfect. it blew the minute i plugged it back in. if it had been plugged and left i dont believe there would have been a problem |
9th Jan 2022, 3:41 am | #25 |
An MOV is typically used for transient suppression, and is a bidirectional (non-polarized) device. You will usually find them on the line side of the power supply. With the amount of lightning strikes you get in Florida it's not surprising to find it blown. Between that and the breaker, it probably saved the rest of the your device.
9th Jan 2022, 3:47 am | #26 |
The scenario I suspect is that a lightning strike or other large transient shorted the MOV and blew the breaker. After you replaced the breaker, the MOV presented a short across the AC line.
9th Jan 2022, 4:02 am | #27 |
i just installed 50a wire and breaker 9pm yesterday 75 degree weather clear skies
used 3 hours then unplugged. woke up in the morning to cook breakfast plugged it in and BOOM the minute the plug touched the outlet. all grounds and wires connected perfectly both ends. just boom |
9th Jan 2022, 4:05 am | #28 |
anyway thanks to you guys i will buy 4 of these monday and install.
fingers crossed i hope this fixes it im heart broken. if you guys didnt correct me and tell me this was a MOV i would have never been able to fix this. thanks so much forum fam |
9th Jan 2022, 9:47 am | #29 |
What equipment in the MOV fitted in?
9th Jan 2022, 4:38 pm | #30 |
A MOV, as others have said, is to suppress spikes in voltage, they are often used in digital multimeters. So, if your meter or power supply in your case sees too much voltage on the input, the extra voltage is shunted to ground through the MOV, it "absorbs" the extra power, think of it like a cartoon cat swallowing a stick of dynamite. Instead of getting blown to bits it just inflates with the only damage being a puff of smoke and a surprised look on the cats face.
In your case the MOV has seen too much dynamite, or voltage and has come to bits. Before fitting new ones and just plugging the power supply into the mains, you need to check for other faults further into the circuit or there's a chance you power supply might go BOOM. Hope that doesn't come across as too simplistic or patronising. Andy.
12th Jan 2022, 7:44 pm | #31 |
hello everyone
been trying to order this part and nobody seems to be able to tell me what the difference is between a 175LA20AP or a 175LA20CP |
12th Jan 2022, 8:41 pm | #32 |
Quite possibly nothing as far as electrical specs go. It could simply relate to mechanical aspects like lead length or materials used to plate the leads etc.
12th Jan 2022, 8:46 pm | #33 |
With a little use of Google and the information is all in these datasheets.
The Littelfuse AP range here:- https://datasheetz.com/data/Over%20V...atasheetz.html and the CP range here:- https://datasheetz.com/data/Over%20V...atasheetz.html |
12th Jan 2022, 8:52 pm | #34 | |
To quote from the datasheet linked to in post #6.
The 'P' following the 'A' or 'B' denotes lead free. I'd still like to know what equipment the MOV is fitted to. There's been a hint that you can cook your breakfast on or in it?
12th Jan 2022, 9:22 pm | #35 |
Re: Blown capacitor. Actually an MOV.
CP = C-lll series so far as I can make out.
Lawrence. |
12th Jan 2022, 9:25 pm | #36 |
-It's good that all 4 are being replaced, as being subjected to spikes on the mains over the years they age in the process- like a cat using up one of it's lives!
dave |
12th Jan 2022, 9:38 pm | #37 |
12th Jan 2022, 10:52 pm | #38 |
https://www.appliancepartspros.com/g...ap3191843.html
cooktop https://www.ebay.com/itm/28456507680...AAAOSwSqhhtSG1 this is the power board ASM |
12th Jan 2022, 10:56 pm | #39 |
For $775 I would expect the whole stove !!!!! My god that is expensive !!!!.
Sorry, just my thoughts. Joe |
12th Jan 2022, 10:59 pm | #40 |
