2nd Jan 2022, 1:47 pm | #101 |
Re: Fitting a mains plug.
In my first year at college, we were instructed to train a group of police officer cadets on how to wire a plug.
2nd Jan 2022, 2:20 pm | #102 |
Talking of shops wiring plugs, my dad bought a new fan heater sometime in the early 90’s and being the most non technical man then alive, asked the shop to fit a plug on it. I checked it later for some reason, and found not only had they used an old second hand plug, they had also wired the blue of the two core flex to the earth pin. Dads house didn’t have an ELCB at that time so the thing worked quite happily, but luckily I found the mistake quite quickly.
I used to be involved with a couple of mobile discos in the late 80’s and I remember having a couple of 3 pin round to BS1363 “Grelco” adaptors, and a 15 amp round to 4 way 13 amp( fused) strip. It was quite common to find round pin sockets still in use in village halls and the like, which of course were common venues.
2nd Jan 2022, 2:35 pm | #103 |
Rewireable American plugs are not that difficult to find, even the UK. RS sell them, for example. I have 20 or 30 of the Hubbell 234V ones in use on DEC computers in the next room and a box of spares.
Personally I'd like to see moulded plugs banned. They can't be repaired, the wiring can't be inspected and in some cases there's no proper strain relief on the cable. Generally on the rare occasions I buy anything new with a moulded plug, I cut it off, twist the pins so it can't go into a socket, and throw it away. And then wire an MK plug or Duraplug or similar onto the cable. |
2nd Jan 2022, 2:39 pm | #104 | |
https://www.electrium.co.uk/products...earch=&sortBy=
2nd Jan 2022, 2:45 pm | #105 |
The MK website indicates they are still making 2A, 5A and 15A round pin UK sockets. Only the 3 pin versions, though. And I think it was a bit of rather bad design that the 2 pin plug will not go into the live/neutral holes of the 3 pin socket (the pin spacing is different).
2nd Jan 2022, 2:46 pm | #106 |
I've noticed some pubs & restaurants used 5a socket for lighting, often on a dimmable circuit & it stops customers from plugging in phones for a free charge!
I always check the plugs on any second hand items, no horror stories yet but on one TV one of the wires was only staying in the pin by about a single turn of the screw.
2nd Jan 2022, 2:50 pm | #107 |
The 5 amp and 15 amp round pin plugs might still be used in theatre lighting.
2nd Jan 2022, 4:22 pm | #108 |
In the mid 80's before you had to sell stuff with a plug on I was in a HiFi shop in Cambridge and a lady came in wanting a lead for her cassette player, the bog standard figure if eight type. The shop assistant fitted an MK plug as a matter of course, free of charge (that must have cost more than the lead) saying "Don't worry madam, we always fit a plug free of charge", service like that? Brilliant!
2nd Jan 2022, 4:32 pm | #109 |
The 2A and 5A round-pin sockets [without a switch] were used in hotels etc for powering table-lights/bedside lights etc, controlled by a switch/dimmer by the bed so you could easily turn on/off the room lights while in bed. Some houses also had the same arrangement with 2 or 5A sockets controlled by a switch/dimmer separate from the main room-lights.
[These days hotel room lights often use 'smart' bulbs controlled from your phone using an app] Regarding 13A plugs and their failures - I've seen several instances where the springy copper fuse-clips are poorly riveted to the brass live-wire screw-terminal or the brass live-pin; on some you can easily rotate the fuse-clip on its rivet. You don't have to be a genius to see what happens when such a plug is used in a high-current application. In the past 'good quality' plugs used solid brass terminals and pins without the troublesome brass-to-copper riveted bit; I guess this fell out of favour because it meant the live lin had to have rather a long slot in it to provide the springiness to grip the fuse, and that would be problematic with the modern requirement for sheathed pins.
2nd Jan 2022, 4:51 pm | #110 | |
2nd Jan 2022, 5:38 pm | #111 |
Re: Putting on a plug.
2nd Jan 2022, 6:45 pm | #112 | |
Peter |
2nd Jan 2022, 6:49 pm | #113 |
The rooms we have had on our stays at Warners have often had the bedside lights connected to unswitched 5A sockets that are not controlled by a wall switch. As these are often the only ones conveniently close to the bed for using phone chargers etc, I used to take with us a short 5A to 13A lead and a WG 1950's 5A "Grelco" double adaptor that was used in the house I grew up in, so we can still use the bedside lamp. I subsequently bought a 3-way 5A adaptor at a pre-covid Harpenden that I now use instead of the two-way one. Using its two side sockets allows the bedside cupboard to be pushed back without fouling the adaptor, which is what happened with the two-way adaptor.
2nd Jan 2022, 10:32 pm | #114 | |
As for wiring a plug, where possible I use bootlace ferrules, makes the issue of stray strands dissappear and I think it makes for a neater job. |
3rd Jan 2022, 12:00 am | #115 |
Re post 109. Indeed, I think the spec for plugs was actually changed to cure this problem. The best type have a one-piece live pin with a split/forked end to accommodate one end of the fuse.
I have a few really old plugs that have the fuse receptacle fixed to the live pin by a screw. The problems with that are also obvious, but I do check them now & again and only use them for low demand appliances.
3rd Jan 2022, 12:59 am | #116 | |
I work in an industry that uses thousands of detachable cordsets under arduous conditions. I find without exception that sticking to good quality moulded versions improves reliability, despite much lower inspection and maintenance workload and hence lower lifecycle cost. The only situations in which I permit rewireable plugs are those where a strict specification of length is needed; as replacements on captive leads; where moulded sets cannot be obtained of sufficient length, or where on a custom assembly there is more benefit to be gained from having the other end moulded. Suppose a cordset touring the world has a life of 2 years and is likely to be inspected every 3 months, that's a minimum of 8 times the plug has to be opened just for checks. If we have to make the cordset from scratch and maintain it, the total cost of ownership is about six times the price of a moulded one despite being a less durable solution, as even the best rewireable connectors are typically less impact-resistant than good moulded ones. Faults (often end-user-induced) are quite often found in rewireable plugs. Under low current usage, internal faults in moulded plugs are vanishingly rare. I could count on the fingers of one hand all the bona-fide intermittent rivets I've seen with an inventory of thousands of IEC cordsets in circulation, compared to hundreds of loose screws. No maintenance possible but no maintenance needed! Last edited by Lucien Nunes; 3rd Jan 2022 at 1:12 am. |
3rd Jan 2022, 9:52 am | #117 |
A decent Volex cordset is vastly superior to probably 90% of hand wired plugs, plus thst cordset has probably been properly tested before being sold, whereas how many hand wired cords have been tested?
3rd Jan 2022, 1:16 pm | #118 |
Seeing the pictures in post #80 reminded me of eight or nine years ago when I was asked to "be the electrician" and lay power to three marquees for a conference.
This consisted of two armoured cables, one to a chain of extensions feeding a pair of strip lights on each marquee pole, the other to supply power for the public address equipment and a band. This had been done in previous years by a qualified electrician - and before you ask, I was told by the organizers that this had been Risk assessed and was OK. So, first things first, I thought let's look at the cables. All the outer sheaths seemed OK. Next, take the plugs apart to check the connections. Some were nice and tidy, but there were examples of all three of those pictures referred to above, but even worse, of the fifteen or so extensions, three had the screw from the earth pin not just loose but out and rattling around inside. On checking the 2- and 4- way sockets on the other end, yes you guessed, the same sort of thing. When I was asked to do the same job the following year, I checked the plugs and sockets again - two or three leads looked different - more lose screws and one screw found to be missing. It pays to be thorough! When I got home, I checked all my extension leads and they were all OK. Anyway, a slightly belated Happy New Year to you all. Stuart.
Half my stuff is junk - luckily, my wife doesn't know which half! |
3rd Jan 2022, 1:40 pm | #119 |
Many years ago, I was working as stage crew, there was a giant strobe unit (possibly 1500w) that needed the plug dealing with, the cable was rubber type and needed replacement, I did the best I could to get it to a safe condition before it went on the gantry, the show must go on.
Rick, the annoying object roaming the forum. |
3rd Jan 2022, 2:29 pm | #120 | |
My wife begs to differ & gets very annoyed if I use, the word 'Plug-top'. But then, she actually boils kettles.... (molten metal all over the worktop?) David. |
