1st Jan 2022, 11:49 am | #61 |
Re: Putting on a plug.
I don't like the idea of a 5A fuse when the appliance runs at 2kW (which equates to over 8 amps). Maybe the fuse won't blow but would run pretty hot. Yes, I accept that the fuse is to protect the cable, but must be adequate for the running current of the appliance.
1st Jan 2022, 12:00 pm | #62 | |
Don’t worry, though; it’s a common mistake. |
1st Jan 2022, 12:21 pm | #63 | |
1st Jan 2022, 1:13 pm | #64 |
How can you put a fuse in the wrong way round?
Please enlighten me!
Best Regards, Peter. |
1st Jan 2022, 1:15 pm | #65 |
He was joking. As you say, it doesn't matter.
1st Jan 2022, 1:16 pm | #66 |
Was he?
I'm not so sure...
1st Jan 2022, 1:37 pm | #67 |
Fuse orientation is critical, the electrons can only flow in one direction but not the other
Rick, the annoying object roaming the forum. |
1st Jan 2022, 1:42 pm | #68 | |
Personally I don't like running plug-fuses anywhere near their rated current: I've seen too many examples of this causing the fuse-clips to overheat with distinctly-negative outcomes both for the plug and the socket into which it is plugged; hence I only use 3A and 13A fuses.
1st Jan 2022, 1:57 pm | #69 |
What's wrong with 5 amp fuses?
I like them very much. Very useful. I bought a toaster several years ago, and the sticky label on the plug said "Fitted with a 5A fuse", which I thought was unusual, but very correct at the same time. Appliance manufacturers tend to fit 3 amp or 13 amp,don't they? Although, I bought an LED 40" television in 2016, which has a 5 amp fuse in the plug, which I've never been terribly happy about. Why would such a low current appliance be fitted with a larger fuse? The flex is just your standard two-core 0.75 mm. I've never changed the fuse - but it's always niggling at me that I really should replace it with a 3 amp one. Any thoughts?
1st Jan 2022, 2:07 pm | #70 | |
1st Jan 2022, 2:08 pm | #71 |
To be honest I've welcomed the fitted plug from a customer point of view.
Unfortunately I have lost my 'Black Museum' photographs of horrendously fitted plugs on equipment that came in for service. The most common fault was the neutral wired to the earth pin. This would produce a dead set when connected to my isolated bench! Terrible wiring with bare wires hanging out of the plug and always a 13amp fuse. The loss of income from the sale of plugs was noticeable. I used to sell literally thousands and I often wondered what my customers did with them all! Happy days. John. |
1st Jan 2022, 2:16 pm | #72 |
Quite a lot of modern stuff takes a significant switch-on surge; it's a characteristic of SMPS design. Using this sort of kit with a low-rated plug-fuse [they're not slow-blow!] can over time cause the fusewire to weaken - its resistance then goes up and it either fails-open or goes into heating-up mode.
In times-past I had to deal with a site where - during the obligatory PAT - the tester replaced the 13A fuses in the plugs with 3A ones without first seeking approval. These plugs were feeding a few hundred really-rather-large Trinitron CRT monitors on dealer-desks; a couple of weeks after the PAT had been completed we started having monitors fail to power-up in the morning, with blown plug-fuses. The degauss, which fired every time the monitor was turned-on, drew a few cycles of really-rather-heavy current until its posistor warmed-up; this was enough to fatigue the under-rated fuses to failure in a few weeks. Once the issue was identified I sent one of the team out to scour the local B&Q/Homebase stores and bring back every 13A fuse he could find, these were promptly fitted to every plug overnight. The techies were happy to be paid triple-time [London rates!] to do the work, the problem went away, the client [whose unit-of-downtime was dollars-per-minute] was happy, and he didn't employ that particular PAT-resting company again!
1st Jan 2022, 2:18 pm | #73 |
Thankfully, the coming of RCDs rapidly weeded out the transposed N and E connections.
1st Jan 2022, 3:32 pm | #74 |
I remember some plugs with colours on the inside to show which wire went where. And coloured sleeves on the power pins.
1st Jan 2022, 3:48 pm | #75 |
This passed without comment but I really enjoyed it - thanks!
"The best dBs, come in 3s" - Woody Brown |
1st Jan 2022, 4:15 pm | #76 |
1st Jan 2022, 4:28 pm | #77 |
I've used this for years and it works really well, although I'm going to include a loop in the earth wire from now on as it makes sense.
On a side note, buying good quality wire strippers which don't break or score the conductor strands are worthwhile, l know some on here use their teeth!
Regards, Ken. BVWS member |
1st Jan 2022, 4:30 pm | #78 |
I aquired a suprising number of items over the years as not working due simply to one or more loose wires in the plug. Every time I get something new (to me) the first thing I do is check the plug. It's very often a nice simple "repair".
Regards, Paul
...No, it's not supposed to pick up the World Service, it's not a radio! |
1st Jan 2022, 5:13 pm | #79 | |
Moulded plugs seem rather prone to another form of failure - where if they receive a sharp whack to one of the pins (like when winding-up an extension lead or letting a vacuum-cleaner retract its spooled-out flex) it can snap the brass bit off internally though the pin stays attached to the body of the plug. If you're lucky it's a clean break and the appliance fails; if you're unlucky the contact is intermittent, resistive, and eventually discloses itself in a shower of sparks and molten plastic.
1st Jan 2022, 5:59 pm | #80 |
I can remember the plug on the vacuum cleaner when I was a teenager.
Dad was asked to have a look at it. He wobbled the cable by the stop lozenge for the reeler and it revealed that the fault was elsewhere. It printed a black arrow on the wall pointing to the failed cord grip that had allowed the cable to pull out with audio. I am not immune from acquiring stuff with badly wired plugs. Three badly wired plugs by blunt screwdriver man |
