13th May 2022, 8:22 pm | #1 |
Plating on Bush TV22 steel parts and screws?
Does anyone know which type of plating was used for steel parts and screws in the Bush TV22 (and surely in many other TVs and radios of the same period)? The photo below shows parts from the TV22 Mk.2. Some of the parts have a yellow tint to them (they all came from a late Mk.2 scrap chassis). Now, I tend to clean parts that have excessive rust (mostly screws), usually by wire brushing and sometimes sanding, which removes the rust but also the remains of the original plating. Today I was thinking that doing this can actually be dangerous in case the screws are cadmium plated. - Helder |
13th May 2022, 8:43 pm | #2 |
Re: Plating on Bush TV22 steel parts and screws?
Do not think those bits are cadmium plated, unless someone knows better?
13th May 2022, 9:01 pm | #3 |
Could equally be zinc plated with a chromate element, this produces the same yellowing effect and was widely used.
13th May 2022, 9:11 pm | #4 |
13th May 2022, 11:10 pm | #5 |
I still have a few NOS cadmium plated bolts and their finish looks nothing like the items in the photo.
15th May 2022, 9:43 am | #6 | |
https://www.ebay.co.uk/itm/154516616...mis&media=COPY I guess that in practice it may be hard to distinguish old/dull zinc from old/dull cadmium. Perhaps the best way to test this (other than by X-ray spectroscopy) is by building a small "battery" with the help of some electrolyte and another metal with a well-known electrode potential - I remember reading about this somewhere (perhaps here on the forum). - Helder |
15th May 2022, 9:57 am | #7 |
In my Thorn Automation days the company made equipment for the admiralty and the standard finish for all chassis parts was 'cad & pass', in other words cadmium plated and passivate dip. It looked a gold/yellowish colour with a 'petrol on water' kind of rainbow effect here and there. My guess is that is what you have there. In fact now I think about it there was an album by the band Family in the early 70s called 'Bandstand' where the cover was a true photo of a Bush TV 22 front and back, it even had a 'celluloid' screen!. And on the back cover the rainbow effect on the chassis is plain to see.
15th May 2022, 10:17 am | #8 | |
- Helder |
15th May 2022, 10:20 am | #9 |
The finish code for EMI 1937. Bush probably used the least expensive bolts just for light assembly. J.
15th May 2022, 10:32 am | #10 | |
- Helder p.s. - Just noticed the finishing codes below... Last edited by Helder Crespo; 15th May 2022 at 10:34 am. Reason: added p.s. |
16th May 2022, 9:31 pm | #11 |
Hi Helder,
Thanks to Jac Janssen we do have the complete set of EMI finishes. Oops, John got there first. Peter |
16th May 2022, 10:23 pm | #12 | |
This is even more comprehensive than John's table. Is Bush/Rank supposed to have followed EMI's finishes? If so, then i believe the most likely finish for the parts I mentioned is White Nickel. - Helder |
17th May 2022, 6:43 pm | #13 |
EMI were crazy with their over the top detail for something that was obsolete after 10 years. It probably had a lot to do with their collapse of domestic radio and TV production. J.
