3rd Mar 2022, 5:06 pm | #21 |
Re: BBC WS restarts SW services
Discussion of this is fine so long as we don't discuss the politics. Everyone has been responsible in that respect so far.
I've just tried to listen on a Grundig Concert Boy 225 and just got noise and interference. It's very much a domestic set though, and the environment is electrically noisy. https://www.radiomuseum.org/r/grundi...t_boy_225.html |
3rd Mar 2022, 5:10 pm | #22 |
3rd Mar 2022, 5:57 pm | #23 |
I've been trying to listen on my Yaesu FT897D and 14MHz dipole but not heard them.
Have also been listening on the supposed Russian military frequencies listed here: https://www.reddit.com/r/ukraine/com...o_frequencies/ and here: https://k0lwc.com/monitoring-the-air...nian-conflict/
3rd Mar 2022, 6:00 pm | #24 |
I am going to try 15735 tonight. Told our Polish lady about this, she is going to pass it on to those who need to know. She was very pleased as her brother is "putting up" a couple of Ukrainian families in his large house in Poland, top chap. Also she said that the Russians are given a load of drivel, this will tell some them a better (the best?) version of what is going on. Good old Aunty Beeb,
I realy feel for the Ukrainians, may this stop soon. |
3rd Mar 2022, 6:29 pm | #25 |
merlinmaxwell these are the schedules:
1400 UTC to 1600 UTC @ 15735kHz 2000 UTC to 2200 UTC @ 5875 kHz you will need to listen on 5875kHz not 15735kHz |
3rd Mar 2022, 7:28 pm | #26 |
Clear (but not strong) reception on the AR88 this afternoon in Cambridge, using the Wellbrook loop orientated to minimise local QRM. Interesting though that the character of fading made it sound pretty distant. Was I picking up a reflection?
Martin
BVWS Member |
3rd Mar 2022, 8:27 pm | #27 |
Regds, Russell W. B. G4YLI. |
3rd Mar 2022, 8:41 pm | #28 |
No Longer a Member
I would suggest that the average Ukrainian, much like a resident of this country, hasn't got a shortwave radio receiver.
3rd Mar 2022, 8:54 pm | #29 | |
https://www.latimes.com/business/tec...nisters-thanks
3rd Mar 2022, 9:21 pm | #30 |
5875kHz peaking S9 +40dB here. Huge signal. Carrier level seems topump with modulation so it seems to be a modern enhanced efficiency AM transmitter.
120 foot doublet into balanced ATU and ICOM IC7700. David
3rd Mar 2022, 9:24 pm | #31 |
There are an awful lot of radios with at least basic SW coverage still floating around, even if they've not been used on SW for ages. The USSR used SW a lot because of the distances involved, and many of the sets from that era have good SW performance.
3rd Mar 2022, 9:28 pm | #32 | |
Peter, you are right, my typo, listening on 5875 kHz now, not the best signal a lot of fade etc. much better in synchronous AM on the SSRplay, but then it isn't aimed at me, let's hope it is better (I am sure it will be) in the area aimed at.
I admit I am very worried about the situation (nukes et al) hearing the Beeb on shortwave is somehow comforting. |
3rd Mar 2022, 9:32 pm | #33 |
I think David in Fife must be much closer to the beam than most of us, though he has good kit.
3rd Mar 2022, 9:32 pm | #34 |
Paul (Sherwin) you have gladened my heart reducing my 1 in 10/100 estimate.
3rd Mar 2022, 9:37 pm | #35 |
I reckon about a third of my transistor sets have SW coverage, and more than half of the valve sets. I'd happily hand them out to the community in similar circumstances.
3rd Mar 2022, 9:48 pm | #36 |
Local QRM has come up and the signal has now started fading quite badly Fade dips are about 2 seconds apart. Difficult to follow with missing syllables.
Let's try faster AGC.... nope, slower is better. Wonder if the QRM is pumping my AGC?... Yes a bit, also some front end attenuation helps a bit. De-noising algorithm doesn't help. Looks like we had a good clear patch at 29:21 zulu. We're not the target area. I hope it's good and clear in both Ukraine and Russia where it's needed. It makes interesting listening. David
3rd Mar 2022, 10:25 pm | #37 | |
There'll be Optimod on there too.
3rd Mar 2022, 11:59 pm | #38 |
Thanks, Russel, that fits with what I saw. I was using a bandpass FFT with a small enough bucket size to discriminate between carrier and sideband energy on a waterfall display, so I could see the carrier ducking at the syllabic rate.
I think I'm a member of a very small club.... those who have designed a full-fat AM transmitter in the 21st century. It's amazing how the available power devices are all targeted at linear amplification. Low limits on negative gate swing (protection zener - note singular) prevents good Class-C operation. David
4th Mar 2022, 12:35 am | #39 |
From my limited experience of the eastern bloc, I'd think there is a significantly higher proportion of SW receivers than in the UK. I'd posit this would be especially likely in Ukraine since 2014 with disruption to communications and need for robust and resilient networks. The older technology will certainly be more rugged in this application, and I imagine there are plenty of Soviet-era sets around. I wouldn't be surprised if valve sets were also more prevalent. There are such enormous Soviet stocks of valves and the attitude is less urgently about the 'new'.
I, however, have no SW set in use so will have to dig one out and have a listen. Perhaps it is audible in Cornwall... |
4th Mar 2022, 9:10 am | #40 |
This certainly illustrates the utility of SW broadcasting as a fallback. Perhaps now we won't be so ready to shut down every single remaining transmitter? We need diversity in communications and a backup which isn't easily disrupted.
