Old 13th May 2022, 8:22 pm   #1
Helder Crespo
Helder Crespo's Avatar
Default Plating on Bush TV22 steel parts and screws?
Does anyone know which type of plating was used for steel parts and screws in the Bush TV22 (and surely in many other TVs and radios of the same period)? The photo below shows parts from the TV22 Mk.2. Some of the parts have a yellow tint to them (they all came from a late Mk.2 scrap chassis). Now, I tend to clean parts that have excessive rust (mostly screws), usually by wire brushing and sometimes sanding, which removes the rust but also the remains of the original plating. Today I was thinking that doing this can actually be dangerous in case the screws are cadmium plated.
- Helder
Helder Crespo is offline
Old 13th May 2022, 8:43 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Plating on Bush TV22 steel parts and screws?
Do not think those bits are cadmium plated, unless someone knows better?
HamishBoxer is offline
Old 13th May 2022, 9:01 pm   #3
Freya
Freya's Avatar
Could equally be zinc plated with a chromate element, this produces the same yellowing effect and was widely used.
Stephen
Freya is offline
Old 13th May 2022, 9:11 pm   #4
Helder Crespo
The yellowing seems to be oxidation, as there are parts that don't show it on the back.
Old 13th May 2022, 11:10 pm   #5
emeritus
I still have a few NOS cadmium plated bolts and their finish looks nothing like the items in the photo.
emeritus is offline
Old 15th May 2022, 9:43 am   #6
Helder Crespo
Thanks, but there also seem to be cadmium plated NOS bolts with a finish that looks very much like that on the 2BA bolts and washers in my TV22s, e.g., here:
https://www.ebay.co.uk/itm/154516616...mis&media=COPY
I guess that in practice it may be hard to distinguish old/dull zinc from old/dull cadmium. Perhaps the best way to test this (other than by X-ray spectroscopy) is by building a small "battery" with the help of some electrolyte and another metal with a well-known electrode potential - I remember reading about this somewhere (perhaps here on the forum).
- Helder
Old 15th May 2022, 9:57 am   #7
stevehertz
stevehertz's Avatar
In my Thorn Automation days the company made equipment for the admiralty and the standard finish for all chassis parts was 'cad & pass', in other words cadmium plated and passivate dip. It looked a gold/yellowish colour with a 'petrol on water' kind of rainbow effect here and there. My guess is that is what you have there. In fact now I think about it there was an album by the band Family in the early 70s called 'Bandstand' where the cover was a true photo of a Bush TV 22 front and back, it even had a 'celluloid' screen!. And on the back cover the rainbow effect on the chassis is plain to see.
stevehertz is offline
Old 15th May 2022, 10:17 am   #8
Helder Crespo
Thanks, but I think the effect seen in the album photo is mostly due to colour grading / artistic liberty from the sleeve designers, as it is mostly noticeable in the chassis itself but the chassis is plain aluminium in all TV22 vintages/models.
- Helder
Old 15th May 2022, 10:20 am   #9
Heatercathodeshort
Heatercathodeshort's Avatar
The finish code for EMI 1937. Bush probably used the least expensive bolts just for light assembly. J.
Heatercathodeshort is online now
Old 15th May 2022, 10:32 am   #10
Helder Crespo
Thanks John. So most parts are plain, others WN, and only a couple of them C&P (quite possibly the cadmium + passivate dip mentioned by stevehertz); there are also some Red xyz. Any idea on what WN means? Something nickel perhaps?
- Helder
p.s. - Just noticed the finishing codes below...
Old 16th May 2022, 9:31 pm   #11
peter_scott
peter_scott's Avatar
Hi Helder,
Thanks to Jac Janssen we do have the complete set of EMI finishes.
Oops, John got there first.
Peter
Name:	EMI finish codes.jpg
peter_scott is offline
Old 16th May 2022, 10:23 pm   #12
Helder Crespo
Originally Posted by peter_scott View Post
Hi Helder,
Peter
Thanks Peter!
This is even more comprehensive than John's table. Is Bush/Rank supposed to have followed EMI's finishes? If so, then i believe the most likely finish for the parts I mentioned is White Nickel.
- Helder
Old 17th May 2022, 6:43 pm   #13
Heatercathodeshort
EMI were crazy with their over the top detail for something that was obsolete after 10 years. It probably had a lot to do with their collapse of domestic radio and TV production. J.
