Old 24th Jun 2022, 11:30 pm   #1
phildil
Default Sony Trinitron CRT TV fault
Hello Everyone,
After two decades service, my Sony CRT Trinitron TV is now faulty.
Model: KV-32CS70B
When powered up it goes into standby and doesn't exit the diagnostic stage. The red flashing light sequence is initially two (over current protection) then goes to three (over voltage protection) when the remote control ON button is pressed.
I'd like to save the TV from the tip ...erm the recycling centre.... if I can.
Can anyone help, please?
ta
phil
phildil is offline
Old 25th Jun 2022, 8:32 am   #2
agardiner
agardiner's Avatar
Default Re: Sony Trinitron CRT TV fault
Have you carried out a good initial internal inspection? Maybe worn electrolytics in the power supply. Any bulging ones?
agardiner is offline
Old 25th Jun 2022, 9:39 am   #3
HamishBoxer
HamishBoxer's Avatar
I hope the 2 flashes is not loptx.
HamishBoxer is offline
Old 25th Jun 2022, 11:03 am   #4
Welsh Anorak
Welsh Anorak's Avatar
I think we have line output stage problems here. Firstly check the line output transistor for a short. Then if we're OK there turn on and see if you can hear (!) a rustle of EHT. If so then it can be the frame output IC loading the stage or, as said above, the LOPT.
Do also check for dry-joints on the regulators. Occasional capacitor failure, but not a go to on this chassis.
Funny how quickly you forget - saw it was a 32" and though 'oh, just a small one then'. Er, no, not in the days of CRTs!
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 25th Jun 2022, 11:59 am   #5
Maarten
The MCZ3001 IC or ICs would also break sometimes.
Maarten is offline
