4th Apr 2022, 11:24 am | #1 |
Sound to light converter, my second build.
Back in 1973 I built the Practical Wireless sound to light converter.
https://worldradiohistory.com/UK/Pra...PW-1973-04.pdf is first part of four. My version was for stereo (just doubled up all except psu) and included the light dimmer option as well. A lot of parts were bought from John Birkett, at Lincoln. His "1A unmarked triacs" were very cheap...and worked fine. The 6 way, plus power switch bank complete with buttons was also from him, 25p I think! I bought two. I used 8 pole miniature (Jones or Cinch) connectors for mains feeds to the 3 75W reflector spotlights mounted on one board to sit either end of the sideboard near the stereo speakers. My "hi fi" was a Philips cassette player/recorder with matching speakers, together with a Garrard deck on wooden plinth with cover. The cassette speaker cable output fed into the STL (sound to light) and then straight out to the speakers. Thus the STL was in parallel. The STL audio filter circuits had bass (red), middle (green) and treble (blue) channels feeding the triacs which were individually dimmable by the 6 left hand pots on the front panel, using unijunction transistors. The 2 right hand pots being the sound level controls, left and right. Thus the amp volume could be adjusted independently and the STL also to compensate for different speaker levels. The switch bank Right hand button was mains power on-off. All buttons were latching, no interconnect. The 6 buttons to the left were each an independent override of the STL circuit. This was so that each channel colour could be adjusted with the lamp "on" at whatever maximum brightness level you wanted to preset. Overall, this system worked extremely well. Each set of 3 spots were angled up at slightly pointing to different positions along the of top of wall/edge of ceiling that overlapped. So good was the colour effects, one dark night, our lounge curtains were almost fully closed and I was playing Pink Floyd "Echoes" track. We lived in a bungalow with a field opposite and a path at the right hand side of it. Suddenly a very loud banging on our front door. It was our neighbour, Don, very out of breath. He had been walking his dog on this path and whilst returning had seen these flickering colours and had ran back to tell us our house was on fire! Honest! My desire now is to build a new STL, as the original is too big to fit into my "new" hifi rack. Part stripping does seem to be a shame, so I intend to start from scratch. I think I have all the parts in stock. Just the switch buttons (my wanted thread) that are a small problem. Unfortunately, I must have given away my original second switch bank as I cannot find it. Would have been so useful. I attach some pictures of the original unit. You may notice I used single 741 as I didn't have the dual ones specified. The triacs are those 2 rows of 3 on left hand end, mounted in push fit heatsinks on aluminium angle. The drivers with pulse transformers are at the right hand end. The unijunction transistors and associated components being mounted on a busbar above the 6 dimmer pots. The mains transformer top got broken when I took it apart several years ago to look inside. The unit has been on a shelf in my garage since around the early 1980s and was quite filthy. It was built in 1973, when I was around 21. I do HOPE my construction standards today will be a bit tidier and safer than the original. But it WORKED WELL! I will update as my work hopefully progresses. Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd Last edited by Cobaltblue; 4th Apr 2022 at 11:34 am. Reason: title |
4th Apr 2022, 11:29 am | #2 |
Re: Sound to light converter, my seond build.
More pics. Last 2 are a triac board from a junk sale. Just ordinary dimmer/speed controls with bipolar driver transistors. Will most likely be used in a modified condition in my new build STL. It is unknown condition, 50p I think from a junk sale. The triacs are 500piv 12A.
Rob
7th Apr 2022, 5:07 pm | #3 |
Re: Sound to light converter, my second build.
It seems to be possible to buy high brightness coloured LEDs
dc |
7th Apr 2022, 5:32 pm | #4 |
Hi Dave, I know nothing about the requirement of dimmable leds and if this basic triac circuit would be suitable, bearing in mind the constant variations of the music driving them?
In our kitchen refurbishment we had dimmable leds fitted, just a wall switch rotary one. Thanks, Rob
8th Apr 2022, 1:40 am | #5 |
A standard triac drive won't successfully drive mains LED globes as in the sound to light unit.
You need a trailing edge triggering circuit - lot of messing about. |
6th May 2022, 4:58 pm | #6 |
Agreed, mains LED's would be a pain.
However, dc drive with a 'switching current source' would work, plus you don't have to mess with mains voltage / triacs etc. |
6th May 2022, 9:53 pm | #7 |
Thanks for the ideas. However, I intend to keep it original, as I still have the original spotlights, though some colours are a bit flaky.
Currently been collecting everything together. I think I have it all now. I did try using a paper template for veroboard layout of the input and filter section, but it is just too tedious. Far easier I think to actually place parts and work things out as I go, cutting the tracks last of all. Rob
14th May 2022, 6:19 am | #8 |
That schematic is almost the same that Popular Electronics published as an article in the late 60's or early 70's, IIRC.
I actually have the one I built back then. They are a lot of fun. Mine fit nicely in a 10" x 4"x 6" aluminum cabinet with mass room to spare. One of my very first projects. It used audio output transformers as the pulse transformers. |
14th May 2022, 4:08 pm | #9 | |
PS replied here because I am unable find the wanted thread. John.
My favourite text message "I'll be there in five minutes, if not read again" |
21st Jun 2022, 9:14 pm | #10 |
I have several PAR38 lamps in a shed somewhere. Let me know if they are of interest via PM.
20th Aug 2022, 10:14 pm | #11 |
Ill root out my light chaser tomorrow and post pics up. Highly dangerous, built on veroboardb in an unearthed enclosure and I couldnt afford bulgin connectors so used a choc block for the light ouputs. I didnt know any better at 14. Still it did the trick with a plank with 6 batten lampholders and coloured spotlights.
21st Aug 2022, 7:37 pm | #12 |
Yes Steve, in my original post there are pictures of the internals. Veroboard with mixture of mains and the low voltage dc rails. BUT needed 4 screws removing to access. The only other concern was the 8 way Painton/ Cinch sockets that had rhe actual controlled mains output for the lamps.
With my new version I am undecided as to what type output sockets to use for the 240v lamps. Rob
22nd Aug 2022, 7:21 pm | #13 |
The 8 pin shrouded bulgin seemed to be a standard lightbox connector. You could have two lots of 3 channel outputs and two neutral returns per connector. Readily available on ebay it seems .
Still havent rooted mine out yet |
22nd Aug 2022, 8:59 pm | #14 |
Too much for me!! I have many types of connectors here without spending that amount. Thanks for the info anyway. Somewhere I do have a cable with one of those 8 way attached. My original used 8 way Painton/cinch, the small ones. Still have the BC lampholders and cables in the garage, plus the spots.
Thanks, Rob
22nd Aug 2022, 9:21 pm | #15 |
As promised, in all its dusty dangerous glory.
Judging by the rilgaine rubber sleeving and ptfe equipment wire, I must have made it at work as an apprentice, probably when I worked in the air combat simulator. I think it was an everyday electronics design. Standard 555 and cd 4017 firing c106’s. The transformer came from a stripped japanese radio. All inadequately earthed and heatsinked, but it did the job. I had a plank with 6 batten lampholders on it and some coloured 60 watt bc spotlamps. Im quite tempted to knock another lamp board/box together or see if there are any gathering dust on ebay, although Im not even sure if the spotlamps are still available nowadays. And it lives https://youtube.com/shorts/aY384qDAAX8?feature=share Also the “high brightness” monitor leds aren’t by todays standards |
22nd Aug 2022, 9:23 pm | #16 |
And some more pics, not sure why the appear rotated when uploaded
22nd Aug 2022, 9:55 pm | #17 |
Found some suitably dangerous light boxes, and been googling bulbs. R80 bulbs only seem available in es nowadays. Id have to go sign lamp or 60 watt normal coloured bulbs in bc
https://www.ebay.co.uk/itm/Set-of-2x...-127635-2958-0 What was I saying about having no time when retired |
23rd Aug 2022, 8:24 pm | #18 |
Interesting, but not having narrow band filters to trigger according to frequency input of music? The one I built has very good audio filters and channel output colours track the input frequency.
Just put it back in the garage again today, pending pcb circuit design from Chris. Rob
24th Aug 2022, 8:38 am | #19 |
Have you thought of using strings of incandescent Xmas lights?
Quite a choice of colors available, and dirt cheap (at least here) at garage sales, and often free. |
24th Aug 2022, 9:22 am | #20 |
The unit has bass, mid and treble filters for left and right to provide drive to the respective single colour. In stereo, as my original is built, it is a very impressive display using spotlights in a dim room.
It is not random flashing. Rob
