#61 | |
![]() Quote:
#62 | |
![]() Quote:
And sorry, I had a typical transistor-oriented IF secondary impedance ~100-200 Ohm in my head. Last edited by nemo_07; 30th May 2022 at 6:14 pm. |
#63 | ||
![]() Quote:
#64 | ||
![]() Quote:
I managed to do RF sweep of RF frond end of a 4 gang FM double gate FET tuners with high Z probe but have not been successful with valve FM tuners. Great caution must be taken with valve tuners. I am starting to build the dual gate FET version of the 6-gang tuner. It should be easier to test and align without worrying about the high voltage or frying the measurement equipment. But it will be still tricky to align those double tuned amp stages because we still have high impedance in the I/O of the filters. Quote:
#65 | ||
![]() Quote:
But to visualize the bandwidth of the front end you will need a "panorama" bandwidth at the detector (or to kill the IF transformer selectivity). A simplest way would be to replace the IF transformer at the mixers plate by ~1k Ohm resistor and to use a cheapest version of Hi-Z 1:1000 probe consisting of series connected 1pF/500V mica and 1000pF (plus a Si diode for additional DC leak protection, if you insist). This, of course, would require few orders higher generator levels- Last edited by nemo_07; 30th May 2022 at 10:05 pm. |
#66 |
Regenfreak, It would help if you didn't cut quoted text so closely and left in the bit that says who you're quoting. It makes the thread a lot esier to follow. Where this bit is missing we sometimes get other preople thinking it was something they said and the confusion just explodes.
#67 | |||
![]() Quote:
not enough power level in its RF generation output. Last edited by regenfreak; 31st May 2022 at 5:09 am. |
#68 | |
![]() Quote:
#69 | |
![]() Quote:
If you use it with a 1m long piece of high quality coax cable, it will show ultra-low loading, pretty good amplitude flatness and essentially constant, nearly zero phase shift, from ~10MHz(-3dB low corner) well into GHz range, provided C2 (1000pF) is a leadless (chip) type and the diode is a small signal low capacitance type (no Schottky). With its ~1pF (C1) input it would detune a bit IF tanks, but completely the front end. With its insertion loss of ~60dB and your TinySA (noise floor -102dBm @ 30kHz RBW, max sin output -6dBm) the max. available span for selectivity check would be ~36dB for a cold tank, increased by a gain (if any) in the hot state. Removing the C2, you get a "narrow band" (a sort of high pass amplitude response with a slope ~20dB/decade) variant 2, with IL~50dB @10MHz and ~30dB @100MHz, and varying phase shift (not suitable for VNA measurements, but still usable for narrow band scalar sweeps). The possible span will improve by ~10dB @10MHz to ~30dB @100MHz (for cold unit). Loading @100MHz will be noticeable. Now, adding a 0.1pF/500V (C01) in series to C1 makes up the variant 3. The IL will jump to ~70dB @10MHz to ~50dB @100MHz, but the span for hot unit with some gain would be usable. And now you'll get virtually no loading @10-100MHz band, and max. detuning @100MHz less than -200kHz. Would it be a crack enough? |
#70 | |
![]() Quote:
I have 0.1pF smd capacitors but if you put two wires a few mm apart, its stray capacitance would be much bigger! In the measurement of unload Q of a single tuned LC resonator with capacitive coupling wires (like in a cavity resonator) for I/O using a spectrum analyzer with tracking generator ( I use NWT200), all you need is to introduce about -20 to -30db IL for the capacitive coupling wires for the measured Q to be unload (Qo). Please see the equations and graph of Qu/QL versus attenuation in db (red line). |
#71 | |||
![]() Quote:
If you put a probe at hot end of 100MHz tank you get excessive detuning, unless the tip capacitance is ~0.1pF or less. The high IL is the consequence, not prerequisite. You wanted Hi-Z probe with Lo-Z output, but found nowhere. So, here you've got a proposition. Take it or leave it. Anyway, you are free to experiment with values of your choice. Quote:
Or am I to believe that fabricating 0.1pF SMD capacitors is a pure nonsense? BTW. It (C01) doesn't have to be SMD type. If you find and get a leaded 0.1pF one, the apparent paradox of wires will ... disappear. Right? |
#72 |
Going back to the idea of having 50-ohm I/O bandpass filters, I have acquired some MMIC Gali-51+, MAR-1, Mar-2 Mar-4, 6 and 11. Theses have Darlington configuration internally matched to 50ohms. The advantages of 50ohm I/O impedance is easy to align with VNA or sweep generator. I thought I could explore the use of passive ring diode mixer like SBL-1+ or active double-balanced Gilbert cell mixer/oscillator NE602.
In order to test the feasibility of the ideas, I built the fixed tuned MMIC cascade amp with Gali-51+ with double-tune capacitive coupled bandpass and inductive coupled bandpass. It is working ok. Furthermore I made a variable tuned MMIC amp using a 7-gang air gang variable capacitor. It is too lossy and difficult to tune to my liking. After all, it seems not a good idea. When it comes to variable tuned MMIC cascade amplifier, it is impossible to obtain the end coupling caps matching 50ohm I/O impedance across the whole FM band. The Hi-Z to 50-ohm transformation is frequency dependent. To add to the complication, the nodal frequencies are much higher than the filter center frequency in 50 ohms matched version, this makes it impossible to obtain an exact analytical solution that simultaneously satisfies all the constraints: acceptable bandwidth, impedance matching and tracking correctly across the FM band. So I am going back to the high Z double dual gate FET project. Attachment 3-4 is the testing of SBL-1+ with my new poorman's 100MhZ FY6900 signal gen. Attachment 6 is my 300 ohms to 50 ohm balun. I tested with 300ohm resistor, I got SWR of 1.4 at FM band. I am working on a new version that will give SWR close to 1 at VHF. I am hoping to get a combiner and will measure the IP3 two tune measurement of an amplifier. |
#73 | |
![]() Quote:
The problems with MMICs, like for any BJTs, are intermodulations and spurs. Diode mixers are not much better in this respect. ... But you might put a MMIC or two in use to boost the dynamic range of the Hi-Z probe we've talked about. This balun doesn't look good. Low insertion loss requires tight coupling, what means good intimacy of wires involved over the whole length of winding. Think of them as of a micro-transmission line. To wind a good 300 ohms to 50 ohm (6:1) balun is not a trivial task. You would better take a 4:1 one and use ordinary resistive matching. If you need isolated primary to secondary, 300 Ohm to 75 Ohm balun (or 200 Ohm to 50 Ohm), you would start with 3 pieces of thin enameled copper wire, ~10 cm long, as convenient. Twist them together (about 1 full turn/cm length), then wind through the core few turns (say 6), cut the ends to the required length. Now, the ends of one of the wires will be the 75 ohm side. The other two will be connected in series (take care of phases), common point serving as mid-tap, both other ends as 300 Ohm balanced ends. You may look at the Figure 2 here: https://www.minicircuits.com/pdfs/MPD_Transformers.pdf This is a 4:1 balun wound on a toroidal core. Note, how the separation of primary versus secondary terminals was solved, whereby all 3 wires pass exactly the same path around the core. NB. For sake of core losses its volume should be kept as small as possible. High permeability material is advantageous. |
#74 | ||
![]() Quote:
My current 1: 6 balun is based on this design: https://pa1ejo.wordpress.com/2020/05...50-to-300-ohm/ His one has SWR of 1.33 at 10MHz and approx. 2.0 at 100MHz. Mine has SWR = 1.4 at 100MHz which is not bad. I use BN61-1502 binocular core. I am going to build the 5 wire version based on a web article. Annoyingly his web site is down now: https://vk6ysf.com/balun_6-1.htm I am waiting for the multi-color ribbon cable to arrive on the post. I bought a T130-17 for this. I dont need to make 1:4 balun as I have some ready-made micro smd 1:4 ones lying around. Previously I purchased them to make a crystal tester for VNA. PS I have ordered a RF power splitter with -35db isolation so the two ports do not see each in the IP3 measurement. |
#75 |
Actually the SWR (attached )of my 6:1 balun looks better than the one in the article.
#76 |
Be careful not to judge baluns entirely on VSWR. Loss can be important.
A 50 ohm resistor or 75 ohm has wonderful VSWR! David
#77 | |
![]() Quote:
vk6ysf web site is still down. His design his 5 windings Ruthroff voltage transformer and is relatively easy to wind. It has a measured VSWR of 1. This is an alternative 5-windings 6:1 design which shows a VSWR of about 1. It is more complicated to wind than vk6ysf version. http://www.spirat.com.au/vk5zvs/pic32.htm |
#78 |
#79 |
Thanks, one I left in my collection at HP.
#80 |
At last I have completed the dual gate FET version of the 6-gang tuner ( 2 x 3SK45 plus BPJ mixer and oscillator). After simple alignments of the oscillator and the antenna coil, I have powered it for the first time. Similar to the valve version, it is tracking perfectly and working brilliantly with excellent sensitivity and selectivity. It sounds amazing even I have not adjusted the two bandpass stages. I simply connected to it to the IF input of my DIY valve stereo FM tuner. I can get full stereo MPX for all the weak and strong stations across the FM band,. It is one of the rare occasions a DIY project that worked the first time in the first power-up, it is very satisfying! So the project has been a success.
The unload Qu of the front end tank is measured to be 130. In the design calculations, I chose lower I/O impedance (approx. 5.3K ohms) for the solid state variable tuned bandpass filters on purpose. I have used coil tappings for all the input and output bandpass stages to reduce loading effect of the dual gate FETs on the LC tanks. The positions of the tappings are just rough guesses....It is very complicated to calculate the tapping points of the coils. I have read the below IEEE paper by Klein and I can struggle to understand the design calculations involving I/O conductance, admittance, impedance and stability criteria. But the author showed how the coil tappings can be determined in his example calculations: Mosfet tuner design by Klein, 1970, Taxes Instrument: https://ieeexplore.ieee.org/document/4079818 I have used 0-1pF silver plated piston trimmers for the bandpass coupling capacitors. |
