Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
3rd Mar 2022, 1:57 pm | #21 |
Re: Forum Closing for Server Move 02/03/2022
Here in Deutschland the transition wasn't at all noticeable. Everything is working as it should, just a tad faster. In the past I have suffered different outcomes when a similar transition has happened, so well done Paul!
Eddie BVWS Member. Friend of the BVWTM |
3rd Mar 2022, 3:01 pm | #22 |
Wouldn't know you had changed anything! All OK here at work and probably at home as well.
4th Mar 2022, 12:52 am | #23 |
A smooth changeover for me in that the forum works nicely and I dind't need to log in again but the appearance has changed (for me at least) to a very stripped down and basic look. Perhaps it's a setting or my browser (Firefox) which is to blame?
I have attached a screenshot. Steve.
4th Mar 2022, 3:29 am | #24 |
No problems Downunder and noticeably faster, especially on clicking the 'Mark Forums Read' button.
4th Mar 2022, 7:43 am | #25 |
Definitely faster, which is great, but the internal search feature (not the google search) is still not working well and does not seem to be fixing itself.
- Helder |
4th Mar 2022, 10:24 am | #26 | |
Also changing DNS provider (dead easy in Windows) would probably provide a fix. Try the clean up first though. A web search will show how to do any of those things easily. |
4th Mar 2022, 10:46 am | #27 |
Thanks for your helpful tips - much appreciated - however this morning the site is back to its regular appearance without my doing anything. Happy days!
Steve.
4th Mar 2022, 10:46 am | #28 | |
Administrator
Hold down Ctrl and press F5 to force Firefox to do a full page refresh. |
4th Mar 2022, 10:54 am | #29 |
It can happen when your broadband connection glitches for whatever reason.
4th Mar 2022, 3:26 pm | #30 |
I had that display, curiously some time after the reopening not immediately. Clearing cookies for this site only cured it.
4th Mar 2022, 5:53 pm | #31 |
Hi
I just noticed that the internal search is now working well. Thanks Helder |
4th Mar 2022, 6:05 pm | #32 |
Administrator
Yes, now hopefully fixed, see https://www.vintage-radio.net/forum/...d.php?t=189139
8th Mar 2022, 7:56 pm | #33 |
Occasionally I browse the forum using an old Mac. When I click on a link to the forum I'm told 'this connection is not private'.
I think some members had a similar issue late last year. |
8th Mar 2022, 9:59 pm | #34 |
Administrator
That is probably an issue with an out of date and unsupported version of Safari on the old Mac, not correctly recognising modern SSLs. There is nothing I can do about that and nothing has changed with that aspect with the server move. All I can suggest is to try installing the latest supported version of Chrome or Firefox on the system and see if it helps.
9th Mar 2022, 7:27 pm | #35 |
No glitches noted here; I guess you did the usual 'thing' of setting a DNS TTL of a-few-hundred-seconds a bit before the swapover. At least you're not fussed by the class of 'stiff' net-paranoid environments which see a sudden mid-session change of server-IP-address as a reason-to-revoke-credentials-and-block.
9th Mar 2022, 7:37 pm | #36 |
Administrator
Yes, I set the TTL to 3600 seconds (1 hour) for a few days before, then changed it to 600 seconds (10 minutes) the evening before. I updated the A records on the old server as soon as the move was done, and people were here quickly. The forum remained closed on the old server and was only reopened on the new one.
I also updated the domain nameservers with the domain registrar to suit the new hosting but takes up to 72 hours to propagate (regardless of TTL) so people would have been using the DNS on the old server to get here for up to a few days. Overall it seems to have worked well and not upset anything that I'm aware of... |
10th Mar 2022, 11:04 am | #37 |
Administrator
As the move was over a week ago and there have been no significant issues, I'll close this thread now.
