24th Sep 2022, 5:26 pm | #1 |
Weller TCP from the dump
Hi all. Just managed to whip this Weller TCP1 and base from our local “ re-cycling “ centre when the rubbish police weren’t looking. Looks all intact but haven’t done a check or ( god forbid) plugged it in yet. Not that there is much to go wrong.
24th Sep 2022, 5:35 pm | #2 |
Re: Seller TCP from the dump
Truly excellent iron's
"Behind every crowd, there's a silver Moonshine" |
24th Sep 2022, 8:02 pm | #3 |
Re: Weller TCP from the dump
Well saved!
or maybe I should say Weller saved........
Martin BVWS member GQRP Club |
24th Sep 2022, 8:27 pm | #4 |
A steal!!
Great irons. First used one in 1968, still using them since that date! Rob
24th Sep 2022, 8:34 pm | #5 |
Excellent irons, well worth saving. Looks like it just needs a good clean.
They used to be made in Horsham, not far from me... |
24th Sep 2022, 9:34 pm | #6 |
Ahh, Hubris strikes! We have 24 volts ac at the PSU output plug, we have 13 ohms continuity across the supply pins of the iron plug. Unfortunately the iron does rather get carried away with itself. The iron certainly heats up, but unfortunately doesn’t stop heating. The temperature regulation has failed. I tried a known good tip from my 50 volt GPO/BT version and it’s still the same.
That’s a couple of evenings entertainment sorted out!
24th Sep 2022, 9:35 pm | #7 |
Well done
I wouldn't like my chances at our local dump. It's absolutely bristling with cameras and operatives—never seen anywhere so over manned !!
Chris |
24th Sep 2022, 9:40 pm | #8 | |
Peter |
24th Sep 2022, 9:57 pm | #9 |
Does it heat up if you have no tip fitted?
There is a suppressor capacitor across the thermostat switch which may have shorted (seen that a couple of times) or of course the contacts may be stuck closed. |
24th Sep 2022, 10:33 pm | #10 |
There is a magnet assembly inside that regulates the heat. Its easiliy removable and replaceable.
I havent owned a Weller for many years. I beleive its called the Curie point temperature control. The switches are not that cheap, but last for ages. I used own a factory where I had 30 girls all using Wellers, pehaps once in two years one of those switches failed. The tips alas, dont hold out that well!! Good score !!!!!! Joe |
24th Sep 2022, 11:09 pm | #11 |
Sometimes, unsubtlety IS the answer.
(The thermostatic switch can be opened and the contacts cleaned. They are usually held together with a bit of yellow Kapton tape.) David
24th Sep 2022, 11:12 pm | #12 |
Perhaps David is correct, but my own memory said the magnet had lost its oopmhh.
Joe |
25th Sep 2022, 1:33 am | #13 |
Switch assemblies are not cheap but you may be lucky and find that the little cover over the contacts is loose or the capacitor is short circuit.
E-bay is more expensive than Farnell. https://uk.farnell.com/weller/005102...eller%20switch |
25th Sep 2022, 6:50 am | #14 |
I've not come across a weak magnet yet, but I've used TCP1s at work for decades.
I have come across the little hex screw that holds the moving contact bar to the stem from the magnet coming loose and you get an iron which doesn't heat. Some of the beefier variants on the TCP1 use the same switch design at mains voltage. When an iron stuck on, the usual fix in the lab, as Peter said, was a controlled-intensity smack on the bench. If that didn't do it, we kept spares in stores, so in went a new switch. In later years we sometimes had to open switches and have a go at the contacts if switches weren't readily available. David
25th Sep 2022, 7:32 am | #15 |
Surely if the magnet is weak it won't close the switch and the iron won't heat up at all?
The switch is open when no tip is fitted. When you fit the tip, the magnet is attracted to the special alloy slug on the back of the tip, this pulls the contacts closed. Thus the element heats up. When it gets up to temperature, said alloy reaches its curie point, the magnet is no longer attracted, the contacts open, the element turns off, etc. |
25th Sep 2022, 4:55 pm | #16 |
I have one at my workbench, but don't get much chance to sit there right now. Recently, the iron started refusing to heat up. A gentle tap would often start it, or sometimes just lowering the tip once out of holder. If it came on, it behaved all the time I was at the bench. If it would not respond, I just left it a while, and then could usually get it working by the above methods. Last week, it refused completely, so I dug out a spare unit from my soldering iron spares box, a label suggesting it was good to go. I popped a tip on it, but realised I needed a plug for it. There was a new one in my box, but of course I need a hot iron to solder the leads. There was a spare, new switch in the box, so I intended to fit that to No. 1 iron, but of course I need a hot iron for that.
As soon as I get a few minutes, I will get out one of my Weller guns, and fix both of the others. Les. |
25th Sep 2022, 10:50 pm | #17 |
Hi all. Thanks for all the comments. I removed the sleeve that secures the bit, and and the magnet is still quite strong. I'm away from home on a course from tomorrow, but fear not readers, I have brought the iron and meter, tools etc. with me to fiddle with in the evenings. Stay tuned............
25th Sep 2022, 11:26 pm | #18 | |
26th Sep 2022, 12:14 am | #19 |
That embryonic reputation is gaining ground fast here!
Steve.
26th Sep 2022, 6:19 am | #20 |
You can clean the contacts with electrical spray sprayed onto a bit of thin card, don't use wet & dry paper. I've had one tip go non working, IE the little magnet failed, it was one of the crap Mexican ones though that last about a month.
Also had the Rifa X cap fail in one of my TCP irons, finding a similar size one to replace it is tricky as is getting the heating assembly back on the handle, it only goes on one way. Hours of fun & amusement for kids of all ages as they say. Andy.
