31st Aug 2022, 5:41 pm | #21 |
Re: How would we design electronics to last 100 years?
It's in the spec, but max gold content 1% seems a lot! in a 1kg solder pot (not unreasonable) that'd be 10g of gold - £470 worth - there would have to be a lot of component leads de-golded to get that much...
It's all good stuff for 100 year lifetime though. |
31st Aug 2022, 5:48 pm | #22 |
The problem with the Mil spec crypto chips wasn't to do with the installation, it was apparently a process failure on the semiconductor die. Which apparently cost its manufacturer quite a lot in subsequent litigation with the US DoD procurement people and the large contractor who had built their radios around said chips.
31st Aug 2022, 5:53 pm | #23 |
I'm glad I asked now, the answers are fascinating.
If I understand them correctly we could not design a circuit to run for 100 years without service. How are we ever going to reach even our nearest star? (and I know our nearest star is the sun, I mean Proxima Centauri.) Peter |
31st Aug 2022, 5:56 pm | #24 | ||
Colin |
31st Aug 2022, 5:56 pm | #25 |
What about gold plated circuit boards, I hear you say. Well either the gold has to be abrasively removed from every solder pad, or the board has to be masked by the manufacturer to leave the solder pads un-plated and pre-tinned.
Of course the circuit board material is also important. It needs in particular to have low thermal expansion and low water retention. The whole problem with space is that you can't do a service visit, so over a mission lifetime there has to be zero failures. And that might be many tens of thousands of components, many km of wiring and perhaps a thousand connectors. Being hammered with cosmic rays and the garbage coming from the sun. Component prices? Bonkers. The highest space grade radiation hard FPGA? £80k a pop. The same part in commercial grade? A fiver. Every electronic component is four or five orders of magnitude more expensive that commercial grade parts. Craig
Doomed for a certain term to walk the night |
31st Aug 2022, 6:00 pm | #26 | |
Craig
31st Aug 2022, 6:15 pm | #27 | |
It could create the paradoxical situation that the "hi-rel" parts could actually be less reliable than the commercial parts, even though they might last longer. |
31st Aug 2022, 6:17 pm | #28 | |
But even at their speed, they would take 73,000 years to get to Proxima Centauri (they are currently a mere ~21 light hours away). Even using the crazy end of propulsion systems such as pulsed nuclear explosions to get to 5% of c, would take 85 years to get Proxima (actually one of a a triple star complex) the nearest of 100,000,000,000 stars in our galaxy. Craig
31st Aug 2022, 6:22 pm | #29 |
The data sheet of the Texas Instruments audio amplifier on a chip that I bought in the late 1970's, specified the life in terms of the number of power on/off operations (several thousand from memory).
Funnily enough, a fortnight ago the Icecrypt T5000 Set-top box I use with our pre-SCART Philips colour TV stopped working a fortnight ago, leaking 400V capacitor in the power supply section. No worries, I have an essentially unused Ferguson STB I can use while getting replacement caps from CPC.The Ferguson was fine for an hour and then started turning itself off and back on again every 10 mins: swollen caps! Two sets of capacitors from CPC and both working again, although the Ferguson now has distorted sound and is on the round tuit pile. |
31st Aug 2022, 6:31 pm | #30 | ||
But the mission I have most experience with is the Bepi Columbo mission to Mercury (I was project manager for one of the on-board instruments). Three times closer to the sun than the earth, no atmosphere, 17kW/m^2 solar radiation, and to do the science we need an active sun, where X-flares are good. So active devices have a tough time. There is no real shielding; the only thing on the MIXS instrument are electron diverter magnets the stop solar electrons from damaging the detectors. It has so far done two passes of Venus and two so far of six Mercury passes, due to go into polar orbit in 2025. But it looks like everything is still working four years after launch. Craig
31st Aug 2022, 6:53 pm | #31 |
Special relativity comes to the rescue. Google "twin paradox". Travelling at close to the speed of light the circuit would only need to last a couple of years (the time it takes to accelerate to nearly light speed and slow down again) although people back on Earth would have aged a lot more by the time it got back. But that's another question.
Stuart The golden age is always yesterday - Asa Briggs |
31st Aug 2022, 7:24 pm | #32 |
I do recall a case where the loss of at least one space probe (others here will certainly be more clued up about it than me) was ascribed to the failure of whizzo $650 transistors that had been ever-so-carefully designed and made, and subsequent investigation revealed that they weren't particularly wonderful after all. The mischief in me wondered if they'd have been better off fitting good ol' metal-case BC108s at 20 for a quid from Birkett's....
31st Aug 2022, 8:40 pm | #33 |
....There's Gold-Tin intermetallics as well as Gold-Aluminium? Every day brings a surprise for me.
Dave |
31st Aug 2022, 9:25 pm | #34 |
Perhaps it may be better to ask the question "How would YOU submit a tender or a spec to meet this criteria"?
The costs would at first glance, appear to be horrific without even looking in to them in any depth. |
31st Aug 2022, 9:49 pm | #35 |
Thinking about it, PCB's are an inherently unsatisfactory technology especially when you consider how prone they are to mechanical damage, contamination, corrosion....
I totally empathise with people who refuse to fly by wire (unless the wires in question are tough steel hawsers) Can we move forward from the PCB, if so, how? (Just putting it out there..) Dave |
31st Aug 2022, 11:26 pm | #36 |
Eventually, physics will come into play and we will no longer be able to make technology more powerful, faster and smaller but until then I guess we are stuck with technology that has a short life span. A 20 year old house is still 'new', a 20 year old car still serves it's purpose, a 20 year old mobile phone is scrap.
31st Aug 2022, 11:51 pm | #37 | |
Isnt it already being done with light? I mean laser diodes and optic fibre. Once again, I cannot get over the number of "Brainz " we have here. Designers of space instruments. Designers of test instruments I have never heard of. Just designers of anything!! . Someone else made a comment about gold and tin. Some here are pure solid gold, some ( especially myself ) are just tin. Another reason this forum is a massive repositry of knowledge, not only electronics, but most things scientific, or mathematical.. Thanks to all the very learned persons here, that have enlarged my tiny brain cell, to now, a much larger tiny brain cell. Joe |
1st Sep 2022, 12:27 am | #38 | |
1st Sep 2022, 5:11 am | #39 |
For the multi-generational starship problem on a longer journey or if the acceleration isn't enough to rely on special relativity, take a factory along with you and keep re-making everything and recycling as needed. Take an R&D lab and you ought to wind up with better stuff than you started.
1st Sep 2022, 8:02 am | #40 |
Science fiction soved these problems years ago.
In the city and the Stars by Arthur C Clark the master computer had been working for thousands if not millions of years. Likewise the film Forbidden Planet, the Krell computer had been working and maintaining itself for similar time periods. There have been so many instances of real life catching up with science fiction that long life of electronics may also catch up. When I posed the question I naively though I would get replies that set out the measures to take to make them last 100 years. Peter |
