28th Aug 2022, 1:59 am | #21 |
Re: Can you help identifying these lamps
I thought I should do the obvious thing .Try one . Although the voltage is 14 volt they are quite bright going down to 10 volt. Andy
I bet that car doesn't have a suppressor. |
28th Aug 2022, 6:15 pm | #22 |
The first thing that entered my mind was airfield lighting, 14V is common as is 28V but the bayonet cap suggests otherwise.
Rick, the annoying object roaming the forum. |
8th Sep 2022, 3:21 pm | #23 | |
Christmas or other decoration bulbs of about the bulb size illustrated usually have smaller caps such as SBC or SES. That is what made me think of military or wartime civilian use. Such as interior lighting of a bus or railway carriage. Would have to be BC to be a drop in replacement for the peacetime 12/14 volt 20 watt lamps. |
8th Sep 2022, 4:51 pm | #24 |
Gerry used to have a large wooden drawer labelled 'Nasty Bulbs'! It contained all sorts of odd bases, sizes, shapes, colours and voltages. It was fascinating to sort through.
There must have been thousands more for all special needs. My guess is advertising sign, the letters picked out by the small bulbs. John. |
14th Sep 2022, 5:27 pm | #25 |
They are identical in appearance to ordinary coloured sign lamps.
The voltage is the oddity. Most shop/theatre signs are 240v. It isn't usual to run them in series strings, for the obvious reason that the whole sign goes out when one lamp fails. Fourteen volts is suspiciously like what you might find across a nominal 12v. lead-acid accumulator when on charge... |
14th Sep 2022, 10:52 pm | #26 |
I thought someone would know straight away and this would be a simple challenge. Some good ideas but know one knows for sure . Andy
15th Sep 2022, 2:11 pm | #27 |
Carnival parade float festoons would be my guess.
-- Graham. G3ZVT |
