Old 16th Jan 2020, 9:24 pm   #301
FERNSEH
FERNSEH's Avatar
Default Re: Baird T5 restoration project.
That's the other side panel re-veneered. The left side panel will be the one with the on-off switch.
DFWB.
FERNSEH is offline   Reply With Quote
Old 25th Jan 2020, 10:29 pm   #302
FERNSEH
FERNSEH's Avatar
Assembly of the side panels has started. The Attachment shows the inside of the right side panel.
DFWB.
Old 26th Jan 2020, 11:08 am   #303
line sync
Keep up the good work david , your doing a great job.
Robin
line sync is offline   Reply With Quote
Old 29th Jan 2020, 5:25 pm   #304
FERNSEH
FERNSEH's Avatar
First picture. That wasn't too difficult after all. Today I refitted the timebase controls door ball catch to the front panel.
Second picture.
Over the weekend the left side panel was reassembled. Also the cabinet floor plinth. Not too sure about that one and it's possible a new one might be have to be made. The old plinth had received some attention from the woodworms.
DFWB.
ID:	197973   Click image for larger version
Old 30th Jan 2020, 6:02 pm   #305
mark pirate
mark pirate's Avatar
No point in risking it, after all the hard work you have put in the last thing you need is a re infestation!
Mark
mark pirate is offline   Reply With Quote
Old 30th Jan 2020, 10:21 pm   #306
FERNSEH
FERNSEH's Avatar
"No point in risking it, after all the hard work you have put in the last thing you need is a re infestation!" Mark.
Hi Mark,
It's an easy enough part to replicate. Took a look at the reassembled plinth this morning and it is a horrible looking thing, and as you say there might well be some wee things living in it.
DFWB.
Old 31st Jan 2020, 2:46 pm   #307
beery
beery's Avatar
DFWB.
Well certainty the plinth has to be very strong on such a heavy set. Maybe a new one would be safer even just from a structural point of view.
Andy
beery is offline   Reply With Quote
Old 1st Feb 2020, 5:49 pm   #308
FERNSEH
FERNSEH's Avatar
At last it's beginning to look like a Baird T5 again.
DFWB.
Old 7th Feb 2020, 10:39 pm   #309
FERNSEH
FERNSEH's Avatar
Final assembly of the cabinet started today. The cabinet parts shown in the attachment have been glued into position. The timebase controls door opens and closes as it should.
DFWB.
Old 8th Feb 2020, 11:18 pm   #310
FERNSEH
FERNSEH's Avatar
The left side panel was fitted today.
The cabinet floor was test fitted but will not be screwed and glued into position until all the guide blocks for the two power supply units are fitted.
DFWB.
Old 12th Feb 2020, 5:56 pm   #311
FERNSEH
FERNSEH's Avatar
It's the new cabinet floor that is receiving attention to today. With a little fettling it's now a perfect fit. But before it is screwed and glued into position the wooden blocks which locate the two power units must be fitted first.
The cabinet floor certainly stiffens up the cabinet structure.
DFWB.
ID:	198879   Click image for larger version
Old 14th Feb 2020, 2:20 pm   #312
FERNSEH
FERNSEH's Avatar
I now have to determine the exact positions for the Power supply units and the central wooden block that supports the focus coil assembly.
DFWB.
Old 22nd Feb 2020, 10:49 pm   #313
FERNSEH
FERNSEH's Avatar
Real progress today. At last this is for real and not test fitment of parts.
Apart from the blocks which are screwed and glued into position and used to locate the panels all the other parts are removable to do any servicing or replacement.
When did you ever see a spirit level used to repair a TV set?
DFWB.
ID:	199539   Click image for larger version
ID:	199540   Click image for larger version
ID:	199541   Click image for larger version
Old 22nd Feb 2020, 11:08 pm   #314
Freya
Freya's Avatar
A fine achievement so far, keep it up
Stephen
Freya is offline   Reply With Quote
Old 23rd Feb 2020, 1:49 am   #315
FERNSEH
FERNSEH's Avatar
Hi Steven,
The job for next week will be to drill holes in the upper panel for the controls and tuning scale. Also, more cabinet trim parts to fit. It really is looking like a T5 now.
DFWB.
Old 26th Feb 2020, 6:05 pm   #316
FERNSEH
FERNSEH's Avatar
More progress today. The control panel assembly is complete and has been test fitted into the cabinet. Not much more to do to the cabinet now.
DFWB.
ID:	199755   Click image for larger version
Old 26th Feb 2020, 6:40 pm   #317
peter_scott
peter_scott's Avatar
It's going to look very good!
Peter
peter_scott is online now   Reply With Quote
Old 27th Feb 2020, 11:17 am   #318
FERNSEH
FERNSEH's Avatar
Hi Peter,
There is almost enough spare parts left over to construct another T5. Just have to go looking for another wreck to rebuild.
The loudspeaker doesn't look very nice but it does work OK. Makes a good sound.
DFWB.
ID:	199780   Click image for larger version
Old 27th Feb 2020, 6:48 pm   #319
FERNSEH
FERNSEH's Avatar
The cabinet mirror lid was one of the many original parts which was salvaged and refurbished.
DFWB.
Old 27th Feb 2020, 10:53 pm   #320
Heatercathodeshort
Heatercathodeshort's Avatar
What an epic journey! The men in white coats are just around the corner waiting to pounce. The cosmetic parts of a restoration is always the most difficult.
Seriously, well done! John.
