3rd Jul 2022, 8:04 pm | #1 |
What is this device - a microphone ?
I think it came with a bunch of bits with a Sony Tape Recorder.
It is small (25mm x 20mm) and the flexible rubber cup at the front acts like a suction cup and will easily stick to a flat surface. It measures around 750 Ohms / 273mH Initially thought maybe a microphone but now not so sure because of the suction cup, maybe a transducer for measuring something or accelerometer etc. Only marking on it is "Japan" on the mini jack connector body. Does anybody recognise it ? David |
3rd Jul 2022, 8:11 pm | #2 |
Re: What is this device - a microphone ?
It looks like a telephone pickup - for connecting an external amplifier or recorder to hear or record a call.
It picks up the magnetic field either from the induction coil or the earpiece.
3rd Jul 2022, 8:12 pm | #3 |
Telephone pickup.
EDIT: Post crossed. Lawrence. |
3rd Jul 2022, 8:15 pm | #4 |
You stuck it onto the handset of your landline to make a recording of the conversation, David. I used one in the seventies when my mate Frank used to read the risque jokes from the local Rag Mag! The next day they were all around the school.
Regards, Ken. BVWS member Last edited by Kentode; 3rd Jul 2022 at 8:16 pm. Reason: Post triple crossed! |
3rd Jul 2022, 8:31 pm | #5 |
I thought i recognised it- as seen in episodes of The Sweeney, The Professionals, Smiley's People, etc!
Dave |
3rd Jul 2022, 8:34 pm | #6 |
Well done everybody, it makes sense now.
David |
3rd Jul 2022, 10:19 pm | #7 |
TV companies sometimes used them to record a conversation with some rogue trader back in the day, often held on with gaffer tape
Kevin |
4th Jul 2022, 7:39 am | #8 |
If I remember it only worked with certain older phones. J.
4th Jul 2022, 10:28 am | #9 |
Yes, presumably ones with quite a lot of stray magnetic field from the receiver (earpiece).
4th Jul 2022, 10:37 am | #10 |
I found that on the old 706/746 phones the best place to attach the coil was on the back of the phone itself alongside the cable entry.
By coincidence a dealer friend of mine gave me one just the other week, again he didn’t know what it was. Peter |
4th Jul 2022, 11:36 am | #11 |
That's clever, it must be picking up the field from the ASTIC.
4th Jul 2022, 12:38 pm | #12 |
The advantage of using the induction coil is that you don't have a second cable attached to the handset - especially if you're relying on the suction cup.
4th Jul 2022, 12:59 pm | #13 |
They work well with the open-core ASTICs in Telephone 232's and the like, not always as well with the later ASTICs used in the 700 series. But they were always worth trying.
Another (unofficial) use for them was to pick up the stray field round the audio output transformer in an AC/DC radio. Here of course you could try the pickup coil close to the transfomer inside the set. While the quality wasn't great, it had the advantage ove the other method of puting the tape recorder microphone in front of the radio speaker that the pickup coil was not affected by other noises in the room. |
